Yet another probing question
I am trying to set up a new post MPMaster with a custom drill cycle for probing an ID. I am upgradig from an older post without this capability.
I add this into my txt file the letters at the end are not there just here so you can see what they are related to
[drill cycle 10]
1. "PROBE"
2. "ABSOLUTE RETRACT" C
3. "CUTTER COMP" D
4. "PROBE HOLE SIZE" S
5. "UPPER TOLERANCE LIMIT" T
6. "LOWER TOLERANCE LIMIT" U
7. "EXTRA WORK OFFSET-UNUSED" V
8. "WORK OFFSET" W
9. "Z PROBE DEPTH" Z
10. ""
11. ""
And then I realized I have no way within the post to output the codes I need.
This is the code I need to output for my probe cycle
G00 G40 G49 G80 G90
T30
M06
M19
G00 G54 G90 X0. Y0.
M98 P8099
G90 G43 H30 G31 Z2. F80.
G65 P8010 C2. D0. S.75 T.005 U-.005 V0. W1. Z-.33
G4 P100
M98 P8098
G91 G28 Z0.
M01
Any assistance on this would be greatly appreciated
I suppose the my next question is.
Is there a way to output a line of code as such?
These are the local variables called out in the macros provided to us by the seller. Reading Steve's reply I get the impression that outputting them thru a custom drill command may not be possible.
I have seen some of the code that is being written for the Renishaw probes, the callouts seem to be quite different than what I am requiring.
Yes it will be possible and really not that bad to be honest. You have a couple options with this depending on how fancy and how functional you want the post to be. In all honesty in my humble opinion sky is the limits with custom drill, expect for the fact you have 20 places but could get fancy with mr and could maybe make 100's if not 1000's of possibilities with the drilling cycles for probing. I think your biggest limit is going to be remembering what they all do and are for.
Adding ot above here is what I did for a MPMASTER_FADAL post to have all the fixed subroutiens in the post kind of long but might help you figure this stuff out:
My defintions:
fmt  Q  2   peck1	   #First peck increment (positive)
fmt	 2   peck2	   #Second or last peck (positive)
fmt  I  2   pecki	   #Peck I Word (This is different for Fadals)
fmt  J  2   peckj	   #Peck J Word (This is different for Fadals)
fmt  K  2   peckk	   #Peck K Word (This is different for Fadals)
fmt  P  2   peckp	   #Feed Distance Before Peck
fmt	 2   peckclr	 #Safety distance
fmt	 2   retr		#Retract height
fmt  Q  2   shftdrl2	#Fine bore tool shift
fmt  Q  2   shftdrl	#Fine bore tool shift
fmt  Z  2   zdrl		#Depth of drill point
fmt  Z  2   tosz		#Drilling top of stock
fmt  Q  4   n_tap_thds  #Number of threads per inch (tpi) / Pitch (mm)
fmt  Q  2   thread_lead #Thread lead for Format 1 tapping
fmt  Q  2   pitch	   #Tap pitch (inches per thread) Q for Format 1  & F Format 2 on Fadals
fmt  R0 2   refht_a	 #Reference height (0) is added to work correctly for Fadals
fmt  R0 2   refht_i	 #Reference height (0) is added to work correctly for Fadals
fmt  R0+ 2   pocfeed	 #Feed Rate for Rectangular Pocket L9601 & L9602
fmt  R1+ 2   pocstep	 #Step Over for Rectangular & Circular Pocket L9601 & L9602 & L9801 & L9802
fmt  R2+ 2   pocwidth	#Overall Width for Rectangular Pocket L9601 & L9602
fmt  R3+ 2   pocheight   #Overall Width for Rectangular Pocket L9601 & L9602
fmt  R2+ 2   pocdia	  #Diameter for Circular Pocket L9801 & L9802
fmt  R0+ 2   engout	  #Clearence for Engraving
fmt  R1+ 2   engfont	 #Font for Engraving 0=Std Gothic, 1= Stencil Gothic, 2=Ser Std, 3=Ser Stencil
fmt  R2+ 2   engheight   #Height to Engrave Characters
fmt  R3+ 2   engangle	#Angle to Engrave Characters
fmt  R4+ 2   engser	  #Serlization Engraving
fmt  (   4   engword	 #Text to Engrave
fmt  Z  2	pocdepth	#Depth for Pocket Routines
fmt  Z  2	pocout	  #Clereance plane for Pocket Routines
fmt  Z  2	engout	  #Clereance plane for Engraving Routine
Then here is part of my drilling cycle:
pmisc1		  #Canned Misc #1 Cycle
  pdrlcommonb
  tloffno = t
  pcan1, pbld, n, *sg01, *pocdepth, *feed, *tloffno, e
  pbld, n, "L9601", *pocfeed, *pocstep, *pocwidth, *pocheight, e
  pbld, n, sg00, *pocout, e
  pcom_movea
pmisc2		  #Canned Misc #2 Cycle (User Option)
  pdrlcommonb
  tloffno = t
  pbld, n, "L9701", *pocfeed, *pocstep, *pocwidth, *pocheight, e
  pcom_movea
pdrill_2		#Canned Drill Cycle, additional points
  pdrlcommonb
  pcan1, pbld, n, pfxout, pfyout, pzout, pcout, prdrlout, dwell,
	feed, strcantext, e
  pcom_movea
ppeck_2		 #Canned Peck Drill Cycle
  pdrill_2
pchpbrk_2	   #Canned Chip Break Cycle
  pdrill_2
ptap_2		  #Canned Tap Cycle
  pdrlcommonb
  pcan1, pbld, n, pfxout, pfyout, pzout, pcout, prdrlout, strcantext, e
  pcom_movea
pbore1_2		#Canned Bore #1 Cycle
  pdrill_2
pbore2_2		#Canned Bore #2 Cycle
  pdrill_2
pmisc1_2		#Canned Misc #1 Cycle
  pdrlcommonb
  pbld, n, sg00, pfxout, pfyout, pfcout, e
  pcan1, pbld, n, *sg01, *pocdepth, *feed, e
  pcom_movea
pmisc2_2		#Canned Misc #2 Cycle
  pdrlcommonb
  pcom_movea
pdrlcst		 #Custom drill cycles 8 - 19 (user option)
  #Use this postblock to customize drilling cycles 8 - 19
  pdrlcommonb
  speedrt = speed
  if drillcyc = 8,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9201", *engout, *engfont, *engheight, *engangle, *engser, *engword, e
	 pcom_movea
  if drillcyc = 9,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L94", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 10,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L95", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 11,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9801", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 12,
	 pdrlcommonb
	 tloffno = t
	 pbld, n, "L9901", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	 pcom_movea
  if drillcyc = 13,
	 pitch = 1/n_tap_thds				# Tap pitch (Threads per Inch)
	 feed = speed
	 pdrlcommonb
	 pbld, n, "M05", "M90", e
	 pcan1, pbld, n, "G84", *sgdrlref, pfxout, pfyout, pfzout, pcout,
	 *feed, *pitch, strcantext, e
	 pcom_movea
  pcom_movea
pdrlcst_2	   #Custom drill cycles 8 - 19, additional points (user option)
  pdrlcommonb
  if drillcyc = 8,
	  pdrlcommonb
	  pbld, n, "L93", *pocfeed, *pocstep, *pocwidth, *pocheight, e
	  pcom_movea
  if drillcyc = 9,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 10,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 11,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 12,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 13,
	  pdrlcommonb
	  pcom_movea
  if drillcyc = 14,
	  pdrlcommonb
	  pbld, n, "L301", e
	  pcan1, pbld, n, pxout, pyout, e
	  pcom_movea
  pcom_movea
pcanceldc	   #Cancel canned drill cycle
  result = newfs (three, zinc)
  z = initht
  if cuttype = one, prv_zia = initht + (rotdia/two)
  else, prv_zia = initht
  pxyzcout
  !zabs, !zinc
  prv_gcode = zero
  if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
  pcan
  if mi7 = 1, "G80", "M47" , e
  else, pcan1, pbld, n, "G80", e
  pcan2
  #if tapflg = 1, ""
  tapflg = 0
  pretract2
As you can see i defined my L cycles like you would your above G65 and so forth and so forth for letter values for the other stuff.
Yeah it's possible. It's not even super difficult IMHO.
Personally I'd approach it with a Custom Drill Cycle and a Misc. Int. I'd use the Custom Drill Parameters to drive the variables and I'd use the Misc. Int. to drive the type of cycle (i.e. Bore, Rectangle, Rib, Boss, etc...)
And as always, remember to keep track of the mods you've made to the post in the "Revision Log" section of your post, and also, make a backup BEFORE beginning any Post Modifications.
I do it a different way. Since I have no Idea what offsets the operators are going to use I let the operator's macro choices run the program.
      if drillcyc = 13, # Probe edge finding cycle
if dwell = 0,
pbld, n, 35, no_spc, 91, no_spc, 91, no_spc, 91, no_spc, 35, no_spc,
"4130*20", no_spc, 93, no_spc, "-20", no_spc, 93, no_spc, "+7001", no_spc,
93, no_spc, "=", no_spc, 35, no_spc, "5321", e
"4130*20", no_spc, 93, no_spc, "-20", no_spc, 93, no_spc, "+7002", no_spc,
93, no_spc, "=", no_spc, 35, no_spc, "5322", e
"4130*20", no_spc, 93, no_spc, "-20", no_spc, 93, no_spc, "+7003", no_spc,
93, no_spc, "=", no_spc, 35, no_spc, "5323", e
pcom_movea
if dwell = 1,
pdrlcommonb
temp_y = ynci - .5
pbld, n, pdrlxy, e
pbld, n, "G65P9810", *depth, *feed, e
pbld, n, "G65P9811", *temp_y, e
pbld, n, 35, no_spc, "5322=", no_spc, 91, no_spc, 35, no_spc,
"136+", no_spc, 35, no_spc, 91, no_spc, 91, no_spc, 91, no_spc, 35, no_spc,
93, no_spc, 93, e
pbld, n, "G65P9810", *refht, *feed, e
pcom_movea
if dwell = 2,
pdrlcommonb
temp_x = xnci - .5
pbld, n, pdrlxy, e
pbld, n, "G65P9811", *temp_x, e
pbld, n, 35, no_spc, "5321=", no_spc, 91, no_spc, 35, no_spc,
"135+", no_spc, 35, no_spc, 91, no_spc, 91, no_spc, 91, no_spc, 35, no_spc,
93, no_spc, 93, e
pcom_movea
if dwell = 3,
pdrlcommonb
temp_y = ynci + .5
pbld, n, pdrlxy, e
"4130*20", no_spc, 93, no_spc, "-20", no_spc, 93, no_spc, "+7002", no_spc, 93,
no_spc, 93, e
pcom_movea
if dwell = 4,
pdrlcommonb
temp_x = xnci + .5
pbld, n, pdrlxy, e
93, no_spc, 93, e
pcom_movea
if dwell = 5,
add_z = shftdrl
pdrlcommonb
temp_z = znci - .5
pbld, n, pdrlxy, e
pbld, n, "G65P9811", *temp_z, e
pbld, n, 35, no_spc, "5323=", no_spc, 91, no_spc, 91, no_spc, 35,
no_spc, "137+", no_spc, 35, no_spc, 91, no_spc, 91, no_spc, 91, no_spc, 35,
no_spc, "4130*20", no_spc, 93, no_spc, "-20", no_spc, 93, no_spc, "+7003",
no_spc, 93, no_spc, 93, no_spc, "+", no_spc, *add_z, no_spc, 93, e
pcom_movea
This is what I got so far:
O0100 (1911HM1.NC)
#1=59 (WORK OFF.)
#2=1 (DEF EXT WORK OFF)
#3=1 (INC EXT WORK OFF)
#4=6 (WORK OFF RESET)
#5=5.732 (X MOVE TO NEXT POSITION)
#6=4.74 (Y MOVE TO NEXT POSITION)
(DATE - JUN-27-05)
(TIME - 11:10)
(T1 | 6MM PROBE | H1 | D1 | D0.2360" | | CUST 10....)
G00 G17 G20 G40 G80 G90
(T1 = MIN DEPTH = Z1.)
(T1 = MAX DEPTH = Z0.)
(CUSTOM PROBE CYCLE)
M117
T40
M06
G10L50
N20R1
N21R1
G11
G#1X0Y0
(X)G65P9110 R5.25 X0Y0Z-.2U11.5C1.S0W0Q0.0002F0
(Y)G65P9110 R2.75 X0Y0Z-.2U12.5C1.S0W0Q0.0002F0
(Z)G65P9130 Z0. I0J0K.5S0Q0.0002F0
G10L50
N20R5
N21R5
G11
G0G#1G90X0Y0
G10L20P#2X#5021
G10L20P#2Y#5022
G11
G0G#1G90X#5Y#6
G10L2P#6X#5021
G10L2P#6Y#5022
G11
#2+#3=#2
M117
T40
M06
G10L50
N20R1
N21R1
G11
G#1X0Y0
G10L50
N20R5
N21R5
G11
G0G#1G90X0Y0
G10L20P#2X#5021
G10L20P#2Y#5022
G11
G0G#1G90X#5Y#6
G10L2P#6X#5021
G10L2P#6Y#5022
G11
#2+#3=#2
The number of times its output is defined w/ 1 transform op. (1, 2, 12, or whatever you need.)
This is what I need to add:
G0G90G54.1P1X0Y0
M198 P1234
G0G90G54.1P2X0Y0
M198 P1234
G0G90G54.1P3X0Y0
M198 P1234
G0G90G54.1P4X0Y0
M198 P1234
Output the same # of times the probe data is.
The quest continues
[ 06-27-2005, 02:59 PM: Message edited by: Señor Hardmill ]
  • 1 month later...
In trying to add an automatic probing cycle to my post this is what I have so far
# Added Autoprobe ID Centering Cycle to Custom Drill Cycle 10.
#drl_prm1 # Custom Drill Parameter 1 - Retract C
#drl_prm2 # Custom Drill Parameter 2 - Cutter Comp D
#drl_prm3 # Custom Drill Parameter 3 -
#drl_prm4 # Custom Drill Parameter 4 - ID to be measured S
#drl_prm5 # Custom Drill Parameter 5 - Upper Tol. Limit T
#drl_prm6 # Custom Drill Parameter 6 - Lower Tol. Limit U
#drl_prm7 # Custom Drill Parameter 7 -
#drl_prm8 # Custom Drill Parameter 8 - Unused work Offset V
#drl_prm9 # Custom Drill Parameter 9 - Work shift offset W
#drl_prm10 # Custom Drill Parameter 10 - Z probe depth Z
pdrlcst
pdrlcommonb
if drillcyc = 10,
"*(PROBE ID)", e
n, pfxout, pfyout, pfzout, e
pbld, n, "G65P8010", *drl_prm1, *drl_prm2, *drl_prm4, *drl_prm5, *drl_prm6, *drl_prm8, *drl_prm9, *drl_prm10, e
pcom_movea
and in my post txt file I have
[drill cycle 10]
1. "ID PROBE"
2. "Z RETRACT"
3. "CUTTER COMP"
4. ""
5. "PROBE HOLE SIZE"
6. "UPPER TOLERANCE LIMIT"
7. "LOWER TOLERANCE LIMIT"
8. ""
9. "EXTRA WORK OFFSET-UNUSED"
10. "WORK OFFSET"
11. "Z PROBE DEPTH"
I must be missing something somewhere but I haven't been able to figure it out yet.
I have nmy values added in my custom drill parameter page but I am getting no output from them at all, this is all I Get
G00 G90 G54 X0. Y0. S2139 M03
G43 H1 Z2. M08
G80 M09
M05
G91 G28 Z0.
G28 Y0.
G90
Any ideas what I am missing??
Steve,
Thnaks that showed me that is was actually calling out cycle 9, so I changes the call out and that worked but...
Now I get
G65P8010 drl_prm1 2. drl_prm2 0. drl_prm4 .305 drl_prm5 .001 drl_prm6 .001 drl_prm8 0. drl_prm9 1. drl_prm10 -.25
It should be G65P8010C2.D0.I.305T.001U.001V0.W1.Z-.25
So it seems I need to define the drl_prm's as the appropriate letters the question is how.
I went in and did
drl_prm1 "C" # Custom Drill Parameter 1 - Retract C
but as soon as I did that I got a post error, tells me that was incorrect.
I have another post mod question
I am getting this for output
G00 G90 G54 X0. Y0. S0 M05
G43 H30 Z2. M08
M98 P8098
(PROBE ID)
(AUTO CENTERING CYCLE)
G65 P8010 C2. D0. S.305 T.0025 U-.0025 V0. W1. Z-.25
G04 P100
M98 P8099
G80 M09
M05
G91 G28 Z0.
G28 Y0.
G69
G90
This will work for me but I am still trying to clean it up a little bit more
Is there a way to have a modified tool change only on the custom drill cycles I have created.
I'd like to see if I could modify it to output as such. I was thinking about adding an "if" statement to the ptlchg_com block. Would this be the correct place to add something like this?
G00 G90 G54 X0. Y0. S0 M19
M98 P8098
G43 H30 Z2. G31 F80.
(PROBE ID)
G04 P100
M98 P8099
G91 G28 Z0.
G28 Y0.
G69
G90
You can modify it any way you like. Here's a tool change from one of my posts. Tool 4 is my probe. The window gets chewed up so we open the door to allow the probe to communicate;
      if stagetool >= zero,
if t = 4,
pbld, "M06", "T104", ptoolcomm, e
pbld, "M00", "(OPEN DOOR)", e
if t <= 5 & t <> 4, pbld, "M06", *t, ptoolcomm, e
else,
first_macro_tl = t - 6
if first_macro_tl = 0, "M06", "T", no_spc, 91, no_spc, 35, no_spc, "940", no_spc,
93, ptoolcomm, e
if first_macro_tl > 0, "M06", "T", no_spc, 91, no_spc, 35, no_spc, "940+", no_spc,
first_macro_tl, no_spc, 93, ptoolcomm, e
prvtool = t
this is what it puts out (the M06 lines);
G00 G17 G20 G40 G49 G80 G90 G94
G91 G30 X0 Y0 Z0
M06 T104 (4" LONG PROBE)
M00 (OPEN DOOR)
#930=4010
T01
M98P5002
M05
G91 G30 X0 Y0 Z0
M00 (CLOSE DOOR)
G91 G30 X0 Y0 Z0
M06 T01 (3" DIA FACE MILL FOR ALUM)
#930=4020
T[#940]
M[#926]
M[#927]
M98P5002
M09
M58
M05
G91 G30 X0 Y0 Z0
M01
G91 G30 X0 Y0 Z0
M06 T[#940] ( 3/4" FOUR FLUTE CARBIDE END MILL)
#930=4030
T02
M[#926]
M[#927]
M98P5002
M09
M58
M05
G91 G30 X0 Y0 Z0
M01
G91 G30 X0 Y0 Z0
M06 T02 (NO.2 CENTER DRILL)
#930=4040
T[#940+19]
M[#926]
M[#925]
M[#927]
M98P5001
M09
M56
M58
M05
G91 G30 X0 Y0 Z0
M01
G91 G30 X0 Y0 Z0
M06 T[#940+19] (1/8" TAPER LENGTH DRILL)
#930=4050
T03
M[#926]
M[#925]
M[#927]
M98P5001
M09
M56
M58
M05
G91 G30 X0 Y0 Z0
M01
I added this
if t = 30,
pbld, "M98 P8099", e
pbld, n, "G43", *tlngno, pfzout, next_tool, "G31", "F80.",
else,
pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e
and that got me this, just what I was looking fer'
N1 T30 (BLUM PROBE W/2MM BALL)
M6
(MAX - Z2.)
(MIN - Z0.)
M98 P8099
G43 H30 Z2. T1 G31 F80.
(PROBE ID)
G65 P8010 C2. D0. S.305 T.002 U-.002 V0. W1. Z-.175
G04 P100
M98 P8098
Thanks again to everyone for the assistance and direction
  • 18 years later...
