Changing "X- " to X+"
?Mark
We have a bunch of old programs we run on a mori lathe which have an opposite x axis direction then our new mori. Is there an editor that could handle flipping the program from x- to x+ together with adjusting G2 and G3 codes.
Any suggestion will be appreciated.
Regards, Mark
Mark,
I'm sure you could find a text editor with macro capability. But you could probably create a VB Script program (a more robust solution) in less time than it would take to figure out the macro programming for that editor.
Also don't forget about the 'I' on the G2/G3 blocks if you are using that format. You may need to flip the signs on them.
We started out a long time ago with some old Mori lathes.
They too were X- (away from spindle).
We have purchased many new Mori's and we just have parameters and what not changed to X- so we don't run into this.
Many of times I have to take a rotab program from a vertical and swap everything over to run on a rotab horizontal.
Is there a parameter on the machine to change the x direction.
No, it is hard wired.
We currently use cimco editor that came with mc.
Anyone aware if upgrade could handle this task?
Mark
I just flipped one like that the other day, it went from a vertical to a horizontal. im not sure there is a fool proof way. i just did one axis at a time
ie: changed all x's to x- which would give you x-- on some values then changed all x-- to x. same with y,i,j,k. i know there is a website with a utility on it i will also look for that
Thanks Roger I remember this, thats why i'm looking for something that is fool-proof.
As for vb scripting i just wish i had time to learn it...
The solution to change X G2 G3 ... one at a time works good when done one program at a time, this way we can visualy check if all looks good, but doing hundreds gives me headache just thinking about it...
Mark
I put this together pretty quickly so it might not be perfect but it seemed to work ok with what I tested it on. Feel free to play with it.
The script will prompt for an NC file, when run the script will create a new file called switched.nc and it will be saved to your NC folder depending on what module you run this from. You might want to edit the script to prompt for a new file name or parse the selected file and append something to the name so it is easily recognized.
Call Main
' Sub Declaration
Sub Main()
Dim strOriginal
Dim strSwitched
Dim strLineToRead, strCleanedLine
Dim FSO, fsoDirty, fsoClean
Dim intX, intXminus
Set FSO = CreateObject("Scripting.FileSystemObject")
' -- Prompt for a file
If AskForFileName("*.NC", mcFILE_ACCESS_READ, strOriginal) Then
' -- Make sure it really does exist
If FSO.FileExists(strOriginal) Then
' -- Open the File
Set fsoDirty = FSO.OpenTextFile(strOriginal)
' -- Build path to our output file
strSwitched = GetPathFromExtension("NC")
' -- You may want to expand on the name here....
strSwitched = AddBackSlash(strSwitched) & "switched.nc"
' -- Open our clean file
Set fsoClean = FSO.CreateTextFile(strSwitched)
With fsoDirty
Do While Not .AtEndOfStream
' -- Get a line from the file
strLineToRead = .ReadLine
If Len(Trim(strLineToRead)) > 0 Then
intX = InStr(1, strLineToRead, "x", vbTextCompare)
intXminus = InStr(1, strLineToRead, "x-", vbTextCompare)
' -- initialize
strCleanedLine = vbNullString
' -- Check for a minus first!!
If intXminus > 0 Then
strCleanedLine = Replace(strLineToRead, "X-", "X")
ElseIf intX > 0 Then
strCleanedLine = Replace(strLineToRead, "X", "X-")
Else
strCleanedLine = strLineToRead
End If
' -- Write to our file as is
fsoClean.WriteLine strCleanedLine
Else
fsoClean.WriteLine strLineToRead
End If
Loop
.Close
fsoClean.Close
End With
Call EditFile(strSwitched)
'Call EditFile(strOriginal)
Else
ShowString "Could not open file for editing"
End If
End If
Set FSO = Nothing
Set fsoClean = Nothing
Set fsoDirty = Nothing
End Sub
' Function Declaration
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
O'k now, I greatly appreciate your help but without soundng too stupid (wouldn't be a first time) what do I do with this file?
I understand its vb script and I know I can run it from within mc, but how do i do it?
Kind regards to guys from CNC Software
Mark
*NOTE*
If you downloaded FLIP.ZIP prior to 5:40pm (Eastern Time) there is a bug in that version of FLIP.VBS
I’ve replaced the FLIP.ZIP on the forum FTP with the corrected version.
The problem was here is this section of code...
If intIminus > 0 Then
strLine = Replace(strLine, "I-", "I")
strLine = Replace(strLine, "I", "I-")
End If
the line “ElseIf intX > 0 Then” should read “ElseIf intI > 0 Then”
