CAn Autocad Drawings be imported into MasterCAM
GreatGonzo
IGES (Initial Graphics Exchange Standard) is a standard file format used by many full-scale CAD systems. It is considerably more complex than other file formats. You can read, write, and scan (list) IGES files. IGES files use the IGS extension.
Notes:
¨ When writing IGES files containing solid entities, Mastercam writes the solids as surfaces.
¨ When reading files, you can control how surface trimming is handled.
¨ When reading files, all unblanked entities will be converted.
¨ The Mastercam IGES file converter supports IGES Version 5.3 and older.
if you don`t have a ".dwg" convertor in an older version of MC - then go with the .iges. In AutoCAD you simply type in at the command line. "igesout" to save and "igesin" to import. Before importing or exporting - at the command line, type "CMDDIA" and hit enter. Make sure you are set on #1. Also. type in "FILEDIA" and hit enter. Make sure you are set on #1. These settings will bring up your display optoins when you iges in or out.
