engraving on haas machines
Avarillas
yes i do have a G47 but when i do the two strings
one is right and the next one increments.
can I use another parameter besides 599 with the same number?
I need to make them both the same
G47 P1(####) X0Y0 I90.J.140Z-.004F25.E25.
example 2220
2221
Try this
(1st two parts)
G47 P1(2220) X0Y0 I90.J.140Z-.004F25.E25.
#599=#599-1.
(2nd two parts)
G47 P1(2221) X0Y0 I90.J.140Z-.004F25.E25.
#599=#599-1.
and so on
I think you can subtract 1 from the counter to do two of the same numbers.
Here is a program we use to engrave a work order ID on a part.
You can ingrave any number have a look.
O0351
(PIN,HINGE ------ CC0351A)
(DRAWING NUMBER - D528-40218-200 )
(DRAWING ISSUE - F01 )
(PROGRAM ISSUE - A )
(PROGRAM CREATED BY MASTERCAM ON -02-08-02 -13:38 )
(PROGRAM MODIFIED ON - AT )
(PROGRAM STORED AS A MASTER 0N 6/09/02 )
(*** SETUP INFORMATION ***)
(OPERATION - )
(*** ROTARY TABLE SETTINGS ***)
(SET FIXTURE T23732 CENTRALLY ON ROTARY TABLE )
(SET G54 X & Y ZERO IS CENTRE OF ROTARY TABLE)
(SET Z ZERO TO 20MM ABOVE TOP OF COLLET CHUCK)
(SET THE PART IN THE COLLET CHUCK WITH THE FLATS)
(PARALLEL TO THE Y AXIS AND THE BLANK AREA TO BE ENGRAVED )
(FACING TOWARDS THE OPERATOR Y MINUS DIRECTION)
(*** WORK ORDER NUMBERING *** )
(SELECT THE WORK ORDER NUMBER BY )
(CHANGING THE SUB PROGRAM CALLUP OF)
(THE 5 DIGIT POSITIONS THAT THE MACHINE WILL GO TO)
(YOU CAN SELECT:- ZERO=O3510 ONE=O3511 TWO=O3512 )
(THREE=O3513 FOUR=O3514 FIVE=O3515 SIX=O3516)
(SEVEN=O3517 EIGHT=O3518 NINE=O3519)
( TOOL2 - END STOP TOOL )
N10G17G21G40G49
G90G64G80G94G98
G91G28Z0
M69
G28X0Y0A0.B0.
T2M06
G54
M69
G00G90X0Y0A0.B0.T1
G43H2Z10.
G01Z0F200.
M00
(LOOSEN COLLET AND SLIDE PART TO STOP)
G00Z50.
G91G28Z0
( TOOL1 - 1.MM BALLNOSE ENDMILL )
N10
G91G28Z0
M69
G28X0Y0A0.B0.
T1M06
G54
S10000M03
M69
G00G90X1.895Y-3.369A0.B0.
M68
G43H1Z2.M08
(FIRST DIGIT POSITION )
M98P3512
(SECOND DIGIT POSITION)
G90G00X.795Y-3.369
M98P3510
(THIRD DIGIT POSITION)
G90G00X-.305Y-3.369
M98P3516
(FOURTH DIGIT POSITION)
G90G00X-1.405Y-3.369
M98P3516
(FIFTH DIGIT POSITION)
G90G00X-2.505Y-3.369
M98P3516
G91G28Z0M05
G28X0Y0M09
O3510
(SUB PROGRAM FOR THE DIGIT 0)
G91 G00 X0.000 Y0.000
X-0.376
G01 Z-2.075 F50.
X-0.065 Y-0.014
X-0.062 Y-0.029
X-0.059 Y-0.058
X-0.053 Y-0.072
X-0.047 Y-0.094
X-0.038 Y-0.108
X-0.026 Y-0.115
X-0.018 Y-0.130
X-0.006 Y-0.130
X0.006 Y-0.130
X0.018 Y-0.130
X0.026 Y-0.115
X0.038 Y-0.108
X0.047 Y-0.094
X0.053 Y-0.072
X0.059 Y-0.058
X0.062 Y-0.029
X0.065 Y-0.014
X0.067 Y0.014
X0.062 Y0.029
X0.059 Y0.058
X0.053 Y0.072
X0.047 Y0.094
X0.038 Y0.108
X0.026 Y0.115
X0.018 Y0.130
X0.006 Y0.130
X-0.006 Y0.130
X-0.018 Y0.130
X-0.026 Y0.115
X-0.038 Y0.108
X-0.047 Y0.094
X-0.053 Y0.072
X-0.059 Y0.058
X-0.062 Y0.029
X-0.067 Y0.014
G00 Z2.000
X0.376 Z0.075
M99
O3511
(SUB PROGRAM FOR THE DIGIT 1)
X-0.391
G01 Z-2.075 F50.
Y-1.500
X0.176
G00 Z2.000
X0.215 Y1.500 Z0.075
M99
O3512
(SUB PROGRAM FOR THE DIGIT 2)
X-0.750
G01 Z-2.075 F50.
X0.750
X-0.700 Y-1.060
X-0.026 Y-0.051
X-0.018 Y-0.043
X-0.006 Y-0.058
X0.006 Y-0.050
X0.018 Y-0.043
X0.026 Y-0.051
X0.038 Y-0.043
X0.047 Y-0.036
X0.053 Y-0.029
X0.059 Y-0.022
X0.062 Y-0.007
X0.065 Y-0.007
X0.067 Y0.007
X0.062 Y0.007
X0.059 Y0.022
X0.053 Y0.029
X0.047 Y0.036
X0.038 Y0.043
X0.026 Y0.051
X0.018 Y0.043
X0.006 Y0.050
G00 Z2.000
Y1.212 Z0.075
M99
O3513
(SUB PROGRAM FOR THE DIGIT 3)
Y-0.462
G01 Z-2.075 F50.
X-0.006 Y0.087
X-0.018 Y0.072
X-0.026 Y0.072
X-0.038 Y0.065
X-0.047 Y0.058
X-0.053 Y0.043
X-0.059 Y0.036
X-0.062 Y0.022
X-0.067 Y0.007
X-0.065 Y-0.007
X-0.062 Y-0.022
X-0.059 Y-0.036
X-0.053 Y-0.043
X-0.047 Y-0.058
X-0.038 Y-0.065
X-0.026 Y-0.072
X-0.018 Y-0.072
X-0.006 Y-0.087
X0.006 Y-0.079
X0.018 Y-0.072
X0.026 Y-0.072
X0.038 Y-0.065
X0.047 Y-0.058
X0.053 Y-0.043
X0.059 Y-0.036
X0.062 Y-0.022
X0.065 Y-0.007
X-0.056 Y-0.007
X-0.056 Y-0.007
X-0.053 Y-0.022
X-0.047 Y-0.029
X-0.041 Y-0.036
X-0.036 Y-0.043
X-0.023 Y-0.051
X-0.015 Y-0.043
X-0.006 Y-0.058
X0.006 Y-0.050
X0.015 Y-0.043
X0.023 Y-0.051
X0.036 Y-0.043
X0.041 Y-0.036
X0.047 Y-0.029
X0.053 Y-0.022
X0.056 Y-0.007
X0.056 Y-0.007
X0.058 Y0.007
X0.056 Y0.007
X0.053 Y0.022
X0.047 Y0.029
X0.041 Y0.036
X0.036 Y0.043
X0.023 Y0.051
X0.015 Y0.043
X0.006 Y0.050
G00 Z2.000
X0.041 Y1.212 Z0.075
M99
O3514
(SUB PROGRAM FOR THE DIGIT 4)
X-0.626
G01 Z-2.075 F50.
Y-1.500
X0.626 Y1.002
X-0.750
G00 Z2.000
X0.750 Y0.498 Z0.075
M99
O3515
(SUB PROGRAM FOR THE DIGIT 5)
X-0.750 Y-1.500
G01 Z-2.075 F50.
X0.691
Y0.800
X-0.029 Y-0.050
X-0.047 Y-0.058
X-0.053 Y-0.043
X-0.059 Y-0.036
X-0.062 Y-0.022
X-0.067 Y-0.007
X-0.065 Y0.007
X-0.062 Y0.022
X-0.059 Y0.036
X-0.053 Y0.043
X-0.047 Y0.058
X-0.038 Y0.065
X-0.026 Y0.072
X-0.018 Y0.072
X-0.006 Y0.079
X0.006 Y0.087
X0.018 Y0.072
X0.026 Y0.072
X0.038 Y0.065
X0.047 Y0.058
X0.053 Y0.043
X0.059 Y0.036
X0.062 Y0.022
X0.065 Y0.007
X0.067 Y-0.007
X0.062 Y-0.022
X0.059 Y-0.036
X0.053 Y-0.043
X0.047 Y-0.058
X0.038 Y-0.065
G00 Z2.000
X0.050 Y0.231 Z0.075
M99
O3516
(SUB PROGRAM FOR THE DIGIT 6)
X-0.750 Y-1.500
G01 Z-2.075 F50.
X0.662 Y0.887
X0.038 Y0.050
X0.026 Y0.058
X0.018 Y0.065
X0.006 Y0.065
X-0.006 Y0.065
X-0.018 Y0.065
X-0.026 Y0.057
X-0.038 Y0.051
X-0.047 Y0.050
X-0.053 Y0.037
X-0.059 Y0.028
X-0.062 Y0.015
X-0.067 Y0.007
X-0.065 Y-0.007
X-0.062 Y-0.015
X-0.059 Y-0.028
X-0.053 Y-0.037
X-0.047 Y-0.050
X-0.038 Y-0.051
X-0.026 Y-0.057
X-0.018 Y-0.065
X-0.006 Y-0.065
X0.006 Y-0.065
X0.018 Y-0.065
X0.026 Y-0.058
X0.038 Y-0.050
X0.047 Y-0.050
X0.053 Y-0.037
X0.059 Y-0.028
X0.062 Y-0.015
X0.065 Y-0.007
X0.067 Y0.007
X0.062 Y0.015
X0.059 Y0.028
X0.053 Y0.037
X0.047 Y0.050
G00 Z2.000
X0.088 Y0.613 Z0.075
M99
O3517
(SUB PROGRAM FOR THE DIGIT 7)
G01 Z-2.075 F50.
X-0.750 Y-1.500
X0.750
G00 Z2.000
Y1.500 Z0.075
M99
O3518
(SUB PROGRAM FOR THE DIGIT 8)
X-0.406 Y-0.916
G01 Z-2.075 F50.
X0.059
X0.038 Y0.007
X0.062 Y0.022
X0.059 Y0.036
X0.053 Y0.043
X0.047 Y0.058
X0.038 Y0.065
X0.026 Y0.072
X0.018 Y0.072
X0.006 Y0.079
X-0.006 Y0.087
X-0.018 Y0.072
X-0.026 Y0.072
X-0.038 Y0.065
X-0.047 Y0.058
X-0.053 Y0.043
X-0.059 Y0.036
X-0.062 Y0.022
X-0.067 Y0.007
X-0.065 Y-0.007
X-0.062 Y-0.022
X-0.059 Y-0.036
X-0.053 Y-0.043
X-0.047 Y-0.058
X-0.038 Y-0.065
X-0.026 Y-0.072
X-0.018 Y-0.072
X-0.006 Y-0.087
X0.006 Y-0.079
X0.018 Y-0.072
X0.026 Y-0.072
X0.038 Y-0.065
X0.047 Y-0.058
X0.053 Y-0.043
X0.059 Y-0.036
X0.062 Y-0.022
X0.035 Y-0.007
X-0.026 Y-0.007
X-0.056 Y-0.007
X-0.053 Y-0.022
X-0.047 Y-0.029
X-0.041 Y-0.036
X-0.036 Y-0.043
X-0.023 Y-0.051
X-0.015 Y-0.043
X-0.006 Y-0.058
X0.006 Y-0.050
X0.015 Y-0.043
X0.023 Y-0.051
X0.036 Y-0.043
X0.041 Y-0.036
X0.047 Y-0.029
X0.053 Y-0.022
X0.056 Y-0.007
X0.056 Y-0.007
X0.058 Y0.007
X0.056 Y0.007
X0.053 Y0.022
X0.047 Y0.029
X0.041 Y0.036
X0.036 Y0.043
X0.023 Y0.051
X0.015 Y0.043
X0.006 Y0.050
X-0.006 Y0.058
X-0.015 Y0.043
X-0.023 Y0.051
X-0.036 Y0.043
X-0.041 Y0.036
X-0.047 Y0.029
X-0.053 Y0.022
X-0.056 Y0.007
X-0.029 Y0.007
G00 Z2.000
X0.347 Y0.916 Z0.075
M99
O3519
(SUB PROGRAM FOR THE DIGIT 9)
G01 Z-2.075 F50.
X-0.662 Y-0.887
X-0.038 Y-0.051
X-0.026 Y-0.057
X-0.018 Y-0.065
X-0.006 Y-0.065
X0.006 Y-0.065
X0.018 Y-0.065
X0.026 Y-0.058
X0.038 Y-0.050
X0.047 Y-0.050
X0.053 Y-0.037
X0.059 Y-0.028
X0.062 Y-0.015
X0.065 Y-0.007
X0.067 Y0.007
X0.062 Y0.015
X0.059 Y0.028
X0.053 Y0.037
X0.047 Y0.050
X0.038 Y0.050
X0.026 Y0.058
X0.018 Y0.065
X0.006 Y0.065
X-0.006 Y0.065
X-0.018 Y0.065
X-0.026 Y0.057
X-0.038 Y0.051
X-0.047 Y0.050
X-0.053 Y0.037
X-0.059 Y0.028
X-0.062 Y0.015
X-0.067 Y0.007
X-0.065 Y-0.007
X-0.062 Y-0.015
X-0.059 Y-0.028
X-0.053 Y-0.037
X-0.047 Y-0.050
G00 Z2.000
X0.662 Y0.887 Z0.075
M99
