Engineering Change chook
thoskins
Hidy Ho Neighbors,
This is my first post. I have been reading alot of the information that you guys are putting in here. It has been very informative and helpful.
The work that we do is for General Motors. We build Die Cast Aluminum Tranmission Dies. One half of the die can weigh as much as 30,000 lbs.
Now the fella's at GM don't seem to be happy with their own work because they're changing there models all the time. The problem is that alot of our files have as many as 500 operations in them. And when they start throwing engineering changes at us it upsets the apple cart more often than not. We'll end up using two or three files to machine a Die.
My question is this....
Is it possible to create a chook to do boolean functions on surfaces. By this I mean to create a bounding box as it were around the surfaces and geometry that you want, and either keep or delete everything inside or outside the box.
Now I know you cam trim surfaces to planes and geometry but I need something that can work easily. Some of the guys here are fairly proficiant at making toolplaths, but when it comes to making surfaces and modifying models they start backing away from the table.
Any help would be greatly appreciated.
T.Hoskins
Wel if you have a good water tight surface model, you can create a solid out of it, then you can do this to the changed model, and so a Boolean Operation on it to see the changes.
You looking for something along those lines???
Thanks for the response guy's.
The only problem is that our local Mastercam Dealer told the higher ups that we didn't need solids. I have spoke to them a couple of times myself and they told me the same thing.
There response was that when you modify a solid that all of the toolpaths that are created on it become dirty. Hence you have to regenerate them. He also told me that using solids would slow down my processing time because the files are bigger. I know using solids to do boolean functions would be a heck of a lot easier but I really don't think I can convince management to make the transition to solids. sounds like I'm just SOL. curse.gifbanghead.gifcurse.gifbanghead.gif
thoskins,
Print out a few threads including this one and show them. They invented soids for a reason! I don't understand why the dealer said these things? I could go on and on but I am sure you will spark some interest with some others so.. just wait and listen.
Don't feel to bad, remember you work in a machine shop! I always have simalar things happen to me in machine shops.
Mike
