protomx2 post
harleysport557
Ok same tool.
In the operations manager:
expand the second path "same tool paths"
click parameter icon
the tool parameter dialog pops up
click [ Change Nci ]
check the box [ Force Load Tool]
Ok
Ok
OK
regen
rinse, repeat. for all subsequent paths with the same tool
Sometimes you can Highlight all the tool paths and do a "Change Common Paramters" but that doesnt allways work.
-Keith
Using the mprotmx2 post I get:
PNT G20;
N10 ( SET NEW Z! );
N20 ( SET NEW Z! );
N30 ( SET NEW Z! );
N40 G101 XB-0.5114A YB+3.4394A XE-0.5114A YE+2.9394A TC0 F6.4 D0.5000 CR0.0 T1;
N50 G103 XB-0.5114A YB+2.9394A XE-0.0114A YE+2.4394A XC-0.0114A YC+2.9394A F6.4 TC0 D0.5000 CR0.0 T1;
N60 G101 XB-0.0114A YB+2.4394A XE+3.0531A YE+2.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N70 G102 XB+3.0531A YB+2.4394A XE+3.3031A YE+2.1894A XC+3.0531A YC+2.1894A F6.4 TC0 D0.5000 CR0.0 T1;
N80 G101 XB+3.3031A YB+2.1894A XE+3.3031A YE-2.5000A TC0 F6.4 D0.5000 CR0.0 T1;
N90 G102 XB+3.3031A YB-2.5000A XE+3.0531A YE-2.7500A XC+3.0531A YC-2.5000A F6.4 TC0 D0.5000 CR0.0 T1;
N100 G101 XB+3.0531A YB-2.7500A XE-3.0758A YE-2.7500A TC0 F6.4 D0.5000 CR0.0 T1;
N110 G102 XB-3.0758A YB-2.7500A XE-3.3258A YE-2.5000A XC-3.0758A YC-2.5000A F6.4 TC0 D0.5000 CR0.0 T1;
N120 G101 XB-3.3258A YB-2.5000A XE-3.3258A YE+2.1894A TC0 F6.4 D0.5000 CR0.0 T1;
N130 G102 XB-3.3258A YB+2.1894A XE-3.0758A YE+2.4394A XC-3.0758A YC+2.1894A F6.4 TC0 D0.5000 CR0.0 T1;
N140 G101 XB-3.0758A YB+2.4394A XE-0.0114A YE+2.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N150 G103 XB-0.0114A YB+2.4394A XE+0.4886A YE+2.9394A XC-0.0114A YC+2.9394A F6.4 TC0 D0.5000 CR0.0 T1;
N160 G101 XB+0.4886A YB+2.9394A XE+0.4886A YE+3.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N170 ( SET NEW Z! );
N180 ( SET NEW Z! );
N190 ( SET NEW Z! );
N200 ( SET NEW Z! );
N210 G101 XB-0.5114A YB+3.4394A XE-0.5114A YE+2.9394A TC0 F6.4 D0.5000 CR0.0 T1;
N220 G103 XB-0.5114A YB+2.9394A XE-0.0114A YE+2.4394A XC-0.0114A YC+2.9394A F6.4 TC0 D0.5000 CR0.0 T1;
N230 G101 XB-0.0114A YB+2.4394A XE+3.0531A YE+2.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N240 G102 XB+3.0531A YB+2.4394A XE+3.3031A YE+2.1894A XC+3.0531A YC+2.1894A F6.4 TC0 D0.5000 CR0.0 T1;
N250 G101 XB+3.3031A YB+2.1894A XE+3.3031A YE-2.5000A TC0 F6.4 D0.5000 CR0.0 T1;
N260 G102 XB+3.3031A YB-2.5000A XE+3.0531A YE-2.7500A XC+3.0531A YC-2.5000A F6.4 TC0 D0.5000 CR0.0 T1;
N270 G101 XB+3.0531A YB-2.7500A XE-3.0758A YE-2.7500A TC0 F6.4 D0.5000 CR0.0 T1;
N280 G102 XB-3.0758A YB-2.7500A XE-3.3258A YE-2.5000A XC-3.0758A YC-2.5000A F6.4 TC0 D0.5000 CR0.0 T1;
N290 G101 XB-3.3258A YB-2.5000A XE-3.3258A YE+2.1894A TC0 F6.4 D0.5000 CR0.0 T1;
N300 G102 XB-3.3258A YB+2.1894A XE-3.0758A YE+2.4394A XC-3.0758A YC+2.1894A F6.4 TC0 D0.5000 CR0.0 T1;
N310 G101 XB-3.0758A YB+2.4394A XE-0.0114A YE+2.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N320 G103 XB-0.0114A YB+2.4394A XE+0.4886A YE+2.9394A XC-0.0114A YC+2.9394A F6.4 TC0 D0.5000 CR0.0 T1;
N330 G101 XB+0.4886A YB+2.9394A XE+0.4886A YE+3.4394A TC0 F6.4 D0.5000 CR0.0 T1;
N340 ( SET NEW Z! );
N350 ( SET NEW Z! );
N360 ( SET NEW Z! );
N370 ( SET NEW Z! );
The ( SET NEW Z! ) is to act as a M00, the true MX2 with the mighty AGE3 "auto geometry engine" will pause and display the SET NEW Z message. Then you are to crank the handwheel for Z and press the button to continue. If the machine is an MX3 it may get upset with the ( SET NEW Z! ). You will need to use the mprotmx3 post for that one.
The arc errors could be post/cutter comp related I would never use full radius comp on this machine. If you want a good laugh try sending G code from MPFAN.pst to one of these and watch it run. Every time ccomp is applied the tool retracts to the "Saftey Height" to apply the comp then comes back down at feed rate eek.gif
Nothing is modal on the control so if your missing a XB YB on one of your arc "events" it will fault out.
harleysport557, have you tried to view the events that are causing the problem in the editor on the machine. See if anything stands out.
Allan
hello again
thank you for all the help. i have tried all of your suggestions but have had no success.
the following is code iget with my post.
N140 ( SET NEW Z! );
N142 G102 XB-3.219A YB+0.630A XE-3.250A YE+0.599A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N144 G102 XB-3.250A YB+0.599A XE-3.281A YE+0.630A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N146 G102 XB-3.281A YB+0.630A XE-3.250A YE+0.661A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N148 G102 XB-3.250A YB+0.661A XE-3.219A YE+0.630A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR-0.0 T1;
N150 ( SET NEW Z! );
N152 ( SET NEW Z! );
N154 G102 XB-3.219A YB+0.630A XE-3.250A YE+0.599A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N156 G102 XB-3.250A YB+0.599A XE-3.281A YE+0.630A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N158 G102 XB-3.281A YB+0.630A XE-3.250A YE+0.661A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N160 G102 XB-3.250A YB+0.661A XE-3.219A YE+0.630A XC-3.250A YC+0.630A F5. TC0 D0.1250 CR0.0 T1;
N162 ( SET NEW Z! );
N164 ( SET NEW Z! );
N166 ( SET NEW Z! );
N168 ( SET NEW Z! );
N170 G102 XB-2.500A YB+0.661A XE-2.469A YE+0.630A XC-2.500A YC+0.630A F10. TC0 D0.2500 CR0.0 T2;
N172 G102 XB-2.469A YB+0.630A XE-2.500A YE+0.599A XC-2.500A YC+0.630A F10. TC0 D0.2500 CR0.0 T2;
N174 G102 XB-2.500A YB+0.599A XE-2.531A YE+0.630A XC-2.500A YC+0.630A F10. TC0 D0.2500 CR0.0 T2;
N176 G102 XB-2.531A YB+0.630A XE-2.500A YE+0.661A XC-2.500A YC+0.630A F10. TC0 D0.2500 CR-0.0 T2;
N178 ( SET NEW Z! );
i find that ,if there is a - sign between cr-0.0 t2; you will get no in the continue line , if ther is no - you will get yes and the program will error out
how do i get post to put in -
don't get it.
could you put a sample file on the ftp to look at. I am using the mx2 post on the machine i have in my garage and have never had any trouble.
I would like to post the same file hear and see what i get. I know my machine likes to error out if using comp in machine not computer with mc when doing multiple direction arc moves.
