tooltable & other header info
kkominiarek
This will be an ongoing Q&A thread for me.... so please check back often over the next couple of weeks as I will attempt to make my post almost perfect......I've been experimenting w/tooltable/bldnxtool/pwrrt/tcnt....I've read past threads to get this far.
1st problem ....tooltable/list at beginning of program.
*** this is what I have now....
O0000
(PROGRAM NAME - KTEST.NC )
(CUSTOMER NAME - Default Customer )
(DESCRIPTION - Default Description )
(TOOL LIST)
G20
G0 G17 G40 G49 G80 G90
T1 ( TOOL 1 - .75" ROUGHER )
( ROUGH 2"THRU HOLE )
M6
G0 G90 G54 X-12.8051 Y-3.5139 S2500 M3
G43 H1 Z3.
G5 P10000
( - .75" ROUGHER )
X-12.8051 Y-3.5139 Z.1
( - .75" ROUGHER )
G1 Z-1.45 F25.
( - .75" ROUGHER )
G41 D21 X-13.7851 F45.
( - .75" ROUGHER ).....................
T2 ( TOOL 2 - .75 E MILL )
( FINISH .830 DIM )
M6
G0 G90 G54 X-13.1801 Y-10.6962 S3000 M3
G43 H2 Z3.
G5 P10000
( - .75 E MILL )
Z.1
( - .75 E MILL )
G1 Z-.825 F25.
( - .75 E MILL )
G41 D22 Y-10.0962 F48.
( - .75 E MILL )
X-23.537
( - .75 E MILL ).....................
T3 ( TOOL 3 - .75 OD X 45 DEG C'SNK )
( MACHINE CHFR ON THRU HOLE )
M6
G0 G90 G54 X-12.8551 Y-3.5139 S3000 M3
G43 H3 Z3.
G5 P10000
( - .75 OD X 45 DEG C'SNK )
Z.1
G1 Z-.238 F50.
G41 D23 X-12.2551 F40.
( - .75 OD X 45 DEG C'SNK )..........
***this is what I want....
O0000
(TOOL LIST)
(TOOL 1 - .75 ROUGHER )
(TOOL 2 - .75 E MILL )
(TOOL 3 - .75 OD X 45 DEG C'SNK )
G20
G0 G17 G40 G49 G80 G90.......
What is causing the toolcomment to be posted after every line and not at the top?
this is section of my post, I put this "#" in front of #ptlchg, #ptoolcomment and #pbld
....these changes did not get rid of the tool comments after every line.
ptlchg #Tool change
pcuttype
toolchng = one
#if mi1 = one, #Work coordinate system
# pfbld, n, *sg28ref, "X0.", "Y0.", e
# pfbld, n, "G92", *xh, *yh, *zh, e
pbld, n, "M01", e
pcom_moveb
c_mmlt #Multiple tool subprogram call
pcan
pbld, n, *t, ptoolcomment, e
comment
Don, I actually have these same notes printed from the mcam forum....the problem is...i don't know....
it just doesn't code correctly....i think i'm following your examples to the "T".
could it be where these items are in my post?
where should tooltable be?
where should bldnxtool be?
thanks for taking time to e-mail me
my next question......
I want the post to prompt me for Print Number.
I have e-mailed my reseller to request post cd so I can have the list of all variables. But in the meantime can someone let me know what the variable for print number is?
examples....
scustname "Default Customer"
spartdesc "Default Description"
s???????? "Default Print Number"
I tried to create one called sprntnumb
this is what I had.......
# Start of File and Toolchange Setup
sprntnumb "Default Print Number" # initilize string variables for questions
fq 1 sprntnumb Enter print description: #format questions
pheader
"(PRINT NUMBER - ", sprntnumb, ")", e
# Misc strings
Was I close??????
this is out of a setup sheet but the same process should work in a post. This is what I use to input my work zero positions.
# DEBUG/PROGRAM SWITCHES, debugging and program switches
sxzero "CV Packing Surface"
syzero "Centerline Root"
szzero "Root Bottom"
sazero "Root Bottom facing spindle
# Question format statements
fq 5 sxzero Enter X Zero
fq 6 syzero Enter Y Zero
fq 7 szzero Enter Z Zero
fq 8 sazero Enter B Zero
pcollect # Collect info
q5
q6
q7
q8
pheader # File header
pcollect
pbld, "(X ZERO =)", sxzero, e
pbld, "(Y ZERO =)", syzero, e
pbld, "(Z ZERO =)", szzero, e
pbld, "(B ZERO =)", sazero, e
Storkman, I appreciate your help but I'm unfamiliar with adding questions/prompts to the post and what needs to be changed/added to what location in the post.
I've made numerous changes and nothing has worked.
I did order the post cd. Hopefully the cd has what I need on it. With a good "how to" section.
