Old Machine Work Offset
connormac
A machine at the company I work for has 6 offsets. Then you have to start using a G52 shift. How can I change my post to put it in that way (without doing it by hand).
instead of :
G54.1P1
I need:
G58
G52X#500Y#501Z#502
for : G54.1P2
I need :
G59
G52X#503Y#504Z#505
after G80 I need to put in :
G52X0.0Y0.0Z0.0
if the shift is called for.
Thanks for taking the time to look and for all the help biggrin.gifbiggrin.gif
Can you redefine the previous 6 work offsets?
Example
Start of program
G0G90G10L2P1 X Y Z
G0G90G10L2P2 X Y Z
G0G90G10L2P3 X Y Z
G0G90G10L2P4 X Y Z
G0G90G10L2P5 X Y Z
G0G90G10L2P6 X Y Z
Cut the first 6 parts
Middle of program Redefine 1-6
G0G90G10L2P1 X Y Z
G0G90G10L2P2 X Y Z
G0G90G10L2P3 X Y Z
G0G90G10L2P4 X Y Z
G0G90G10L2P5 X Y Z
G0G90G10L2P6 X Y Z
Cut the second 6 parts and so on,
Well you need to put some conditions in your post that will make this work. The pwcs part of the post handels workoffsets if not using the mi to make workoffsets. Here is the pwcs from Mpmaster:
pwcs            #G54+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level, force_wcs = zero
if sav_mi9 = 1, workofs = sav_workofs
if workofs < 0, workofs = 0
if workofs <> prv_workofs | (force_wcs & toolchng),
if workofs < 6,
g_wcs = workofs + 54
*g_wcs
else,
p_wcs = workofs - five
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs
Now if you want what you have there then the last part will look like this:
   else
if workofs = 7,
pbld, n, "G58", e
pbld, n, "G52X#500Y#501Z#502",e
if workofs = 8,
pbld, n, "G59", e
if workofs = 9,
pbld, n, "G58", e
if workofs = 10,
pbld, n, "G59", e
!workofs
So to handle the G80 we need ot put some logic here:
pcanceldc       #Cancel canned drill cycle
result = newfs (three, zinc)
if tap_feed = one & drillcyc = three, result = newfs (15, feed) #Cancel tap feeds with 4/3 decimal places
z = initht
if cuttype = one, prv_zia = initht + (rotdia/two)
else, prv_zia = initht
pxyzcout
!zabs, !zinc
prv_gcode = zero
if cool_zmove = yes & (nextop=1003 | (nextop=1011 & t<>abs(nexttool))), coolant = zero
pcan
if drillcyc <> 8, pcan1, pbld, n, "G80", scoolant, strcantext, e
if use_pitch & tapflg = 1, pbld, n, "G94", e
pcan2
tapflg = 0
if workofs > 6,
pbld, n, "G52X0.0Y0.0Z0.0 ",e
That should take care of it. I did not know if you wanted ot go to higher than 10 or just stop at 8 but this is a start and hope it points you in the right direction.
The way I have my post set up it is only for this machine. so I can have the post always do this if the WCS is greater that 6. I don't know if this matters any. Is thete any way I can change here:
# Word coordinate system code string select
sg53 G53 # Work coordinate system G code #0
sg54 G54 # Work coordinate system G code #1
sg55 G55 # Work coordinate system G code #2
sg56 G56 # Work coordinate system G code #3
sg57 G57 # Work coordinate system G code #4
sg58 G58 # Work coordinate system G code #5
sg59 G59 # Work coordinate system G code #6
sg54.1 [G58
G52X#500Y#501Z#502] # Work coordinate system G code #7
sg54.2 [G59
G52X#503Y#504Z#505] # Work coordinate system G code #8
But I get a error. does not know what G52 is.
I tried yours but it gave me an error about:
wcstype first, I changed it to wcs.
Well what they have in that post is the logic to call the vaule once the workofs variable is called. The way I did it does away with the need to define the G54.1p1 in this manner. We hard code the post to this and then there is no need to cal its predefined amount then place that vuale in the nc code. I supect you need ot mi1 to do workoffets and if you do make you not useing the workoffset in the toolplane page but use the misc values to assign workoffsets. Is this the case with this post?
If so I hate this way for the very reason you have to use Misc verse what Mastercam is now designed to do and that is use the value at the workoffet box in the toolplane and WCS plane box. I think you might be confued about WCS being greater than 6 making the G54.1p1 work WCS has to do with a prective view or way of looking and assigning the part realtive ot the postion of the part in realtion to the way you want ot machine it. If you are looking at the bottom of the part and use the right corner you are now using that WCS for the orgin, Zplane direction as well as the X plane and Yplane to machine the part realtive the origin of the part now. So when you say WCS it in all aspect of workoffsets has nothing to do with using G54,G55 or anyohter workoffset on the machine. The workoffet number you use which could be MISC method or Toolplane using the workofffet box for a vaule is what would be used here. I would say contact your dealer should be able ot do what you are asking very easy and quick or put up the PWCS part of the post and the pcanceldc part of the post os a better assemnt of what you use and do for workoffets can be made.
We can go either way with the post. if we do the same part in 4 vises we use mi1 like you are talking about. Or to do a progression we use the toolplane page. Iam willing to have a post just to do what I'm trying to do. It will go along with my 15 other posts.
Thanks for the help anyway.
Ok look here:
ptap            #Canned Tap Cycle
pdrlcommonb
#RH/LH based on spindle direction
if use_pitch, pbld, n, "G95", e
if use_pitch = 0,
pcan1, pbld, n, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout,
prdrlout, *feed, strcantext, e
else,
if met_tool, pitch = n_tap_thds # Tap pitch (mm per thread)
else, pitch = 1/n_tap_thds # Tap pitch (inches per thread)
prdrlout, *pitch, !feed, strcantext, e
pcom_movea
tapflg = 1
There are alot of swithes in the post to do it but I still added some thing to not turn on the spindle and things like that which are not really switched but are really custom things.
