How to surface a Topographical map?
Eric S.
Hi,
What Version of MasterCam do you have? I think that you need Level 3 for full 3 axis machining. If you have that then you can machine it.
The hard part is to convert all those contour lines on the map to full 3-D geometry. THis would more than likely have to be done by hand. Then build all the surfaces that you need to drive a tool to.
My .02
-KLG
Thank you for the reply. I curently have MC 8.1 level 2. I have been messing around and discovered that if the mountains are drawn form a side view in layers on the Y axis, that it is possible to loft the contours to join them together. Then I can create toolpaths for the surface, but this seems like a lot of work! I have a file with the mountains split up in the Z axis (a regular topographical map view) and it would be nice if I could find a way ot use it. I need a surface that is like laying a blanket over the map (If it is posible. Which I think may not be with the level I have?) Thank You.
Ive been using Type3 for sometime & IMHO its the best in surface controls. But it gonna cost ya some bucks eek.gif
In Mastercam create a rectangular surface & use control points plainer in sliced horizontal or vertical sections to get a topo surface on the cheap. There you can grab a single c-point at a time & pull it vertically realitive to each contruction plain
[ 11-24-2001: Message edited by: Kenneth Potter ]
I took a look at the rhino pgm. it seems perfect, if I can figure out how to use it. The drape surface feature looks like it would work well, I only have a bunch of contours on diferent z planes, and I can not figure out how to put a mesh over it so I can drape a surface. Any help here would be greatly apreciated.
Eric, try the 'Patch' surface command. It's better than 'drape' for your application. Try it with and without 'start surf'. (for start surf, create a rectangular flat surf above or below your contours, 'rebuild' it with more control points and degree 3, then select it in the options window). Don't forget the F1 key for help.
When translating out to Mastercam, use IGES and look for 'Mastercam' setting.
Good luck, BerTau
Kenneth's method is what was used for this mountain a number of years ago.
Mountain
After the surfaces where made. Used Multi-surface contour to slice it at every 2 inch.
Each slice was a separate program and cut on a waterjet out of 2" thick aluminum plate.
Over 20 feet high.
It is located in downtown Toronto at Nathan Phillips Square.
[ 11-23-2001: Message edited by: Glenn Bouman from In-House ]
In Rhino you can import a free tool called Organic.
There you can turn on control points , move & delete knots, & Pull c-points with greater control with a another tool called nudge. It real sweet to use on the cheap. Alias Wave front i just simply give each control point a Z vector value in U V row & column By way of Ecell & Scripting wink.gif
Kenneth Potter
Cadcam - Jay are you there?
I tried to load a file for eric into your MC8 files, TaosNewMexico_surf.mc8. It seemed to load OK but when I looked the file size is 0. I've tried to load it again but all I get is 'Access denied to MC8' - BerTau
--Forget it, Jay, I messed up but now I think I have it. Can you please delete 3 files for me from the FTP site: in MC8 files - "TaosNewMexico_surf.mc8" & "MC8 files"
in MC7 files delete "MC7 files"
Thanks, BerTau
Thanks, BerTau
[ 11-25-2001: Message edited by: BerTau ]
In my humble opinion, I don't see the need to create one or more surfaces to do this. In fact, I can envision a pretty scary looking surface (and one that's a real bear to cut) if you try to fit it precisely to the topo lines of the map.
Why not just use 2D toolpaths (pocket & contour) since what you've really got are closed 2D curves at different heights?
Yes, I'll acknowledge that Rhino does have the tools to do this, whereas we don't, but I don't know if it's really necessary.
PDG
