Speeds and Feeds
#Rekd™
Hi,
I am enraving a sign (10" x 20" x .062" 304 s.s.) .015" deep. I have tried both 2 and 4 flute solid cabide 1/4" 90 degree chamfer mills.
I have been running 3000 rpm, feed rate of 4 and a plunge rate of 2.5. The tip keeps coming of the endmill (it is to a perfect point to start with).
I am using a Daewoo DMV 3016L with a Fanuc control and drives.
Are my feed and speeds correct? Should I be using highspeed machining? I am running the file as a sub from my flash card.
Thank you
John Ford
Mastercam V9.1, Mill, Lathe, Wire, Design, Art, Engraving and MastercamX
I agree that you should ramp into the workpiece. I prefer to use engraving cutters that are not ground to a point, but are tipped off. Harvey is another manufacturer of engraving cutters, but I prefer to use their carbide drill/end mills to do my engraving with (we put a .010 flat on the bottom of the cutter) just because they are in the machine already to be used as chamfer tools.
I use the same principle as a regular end mill to get my speeds & feeds. Not sure what your max RPM on the machine is, but I am limited to 12K. I would start with .0005 FPT @ 94 SFM that would bring me up to 1196 RPM @ 12 IPM running the cutter at the full .015" depth (which gives it .030 Dia.). That was for a 2 flute tool. If your machine is allowed higher RPM's then keep experimenting with your SFM, but I would leave the FPT alone. Give 150 SFM a shot & see what those #'s look like.
[ 02-15-2006, 05:56 AM: Message edited by: robk ]
