Please help an idiot (Surface Toolpaths)
Weyland
I'm trying to end up with a geometric
shape on the top (surface) of something.
The something is approximately a 2"
diameter, slightly domed piece of Aluminum.
The shape can be anything, but for this
excercise we'll call it a triangle that is just
a bit smaller than the diameter of the Aluminum part.
I have figured out how to project the geometric
shape onto the part I modeled but that's about it...
What I *WANT* to do, is cut away
everything that is NOT the shape, leaving
the shape as a raised "boss" if you will.
I can't figure out how to get it to cut EVERYTHING.
Everything I have tried leaves a bit of the existing part uncut.
Help?
Thanks for any help and time.
gcode- thank you for the prompt reply.
Yes, that is basically what I gleaned from the book I have.
(book is for MC9, but I'm using X)
One of the problems I'm having is that
I can't figure out HOW to project the NCI.
It doesn't seem to be an option...
... or rather, I'm not intelligent enough
to understand where it's wanting me to do it...
Can you tell me how?
I *THINK* what I want is basically Island Pocketingm
but I can't figure out how to do that in this situation...
Thank you.
First build a 2d toolpath that machines the 2d
shape you want.
Island pocket would work good... so would
a single 2d contour with 2 inches worth on multipasses.
Remeber that you'll be finishing your 3d part with a ball endmill so you stepovers will be small
(.01 - .025 depedning on the finish you want)
Then start a surface finishing project toolpath.
Choose you drive surface and close out the
geometry selection without choosing anything else.
Go to the "finish project parameters" page
of the project toolpath, choose NCI for projection type and select your 2d toolpath.
You're done.
Make sure you "ghost post" the 2D toolpath before you post the file.
"First build a 2d toolpath that machines the 2d
shape you want.
a single 2d contour with 2 inches worth on multipasses."
I did that, and saved it to its own file, both MCX and NCI.
"Then start a surface finishing project toolpath.
geometry selection without choosing anything else."
Okay, I did this. (I beleive...)
"Go to the "finish project parameters" page
of the project toolpath, choose NCI for projection type and select your 2d toolpath."
I beleive *THIS* is where I'm having difficulty.
*HOW* do I ACTUALLY do this, please?
Does the geometry need to be improted, somehow?
Do I need to draw it all over again?
I'm frustrated beyond belief.
Thanks.
"Did you create the 2D pocket first?
If so when doing the program of Surface finish project on the last tap you want to pick that pocket toolpath you made."
Yes, I created the 2D pocket and saved it as "triangle.mcx" and "triangle.nci".
What do you mean by "last tap"?
Thanks.
This all happens in the same file
1. make a 2d toolpath that cuts the shape you want
2. make a domed surface
3 start a surface project toolpath and choose
your domed surface as a drive surface.
Green check out of geometry selection
4 Go to the lat page of the surface project
toolpath and set it up like this
In your case the operation you select will be the 2D toolpath you've already created
THANK YOU SO MUCH!
Yes. That was yelling...
Thank you. Once I realized that I needed to
copy/paste the geometry over and do the pocket
operation *in the new drawing*, it all came together for me.
Rockin'.
I'm working with it now.
Thanks again for the prompt responses and
taking the time to explain these things to me.
It is appreciated.
Best,
Weyland
I sent Jay a file to upload to the FTP site.
I've only got V9 and X2 on my machine so I did a sample in V9 to make sure you could open it.
Its named NCI project.MCo9 and Jay will put it in the V9 folder.
I have it working... somewhat...
Actually, I'm pretty sure it's doing
exactly what is supposed to be doing, but
it's not *exactly* what I am seeing in my head.
It's making the radius of the basic
part, but leaving the triangle rather
"square" in height on top of the part.
Does that make sense?
I want the shape to follow the radius of the part.
In other words, the boss should maintain a constant height.
Is that clear as mud?
Thanks~!
"What you need to do is create surfaces
that define your shape and cut them with
a surface finish shallow toolpath."
Terribly sorry for being such a moron,
but I'm trying to learn, ahead of the class...
Can you explain "create surfaces that
define your shape" a little better for me?
I'm not clear on what you mean, there.
Thanks~!
I will run to work (5 min from here) and get the hasp and give whatever help you need...
Part of what makes this forum so da*n good.
Here's a guy going the extra mile to help someone out.
Weyland, there is no shame in not knowing.
Hopefully a couple of these fine people can get you going in the right direction
Matt - Thanks for the effort~!
Ocean Lacky - are you saying that I need to
model EVERYTHING, and loft the shape off the top
of the part, and THEN create the toolpaths and code?
That would suck...
(mostly because I don't know how to do it...)
John - looks like Matt's going the extra FIVE miles... (:>) (and I appreciate it.)
I'm not ashamed. I'm just being humble while asking for help.
I'm a Mcam newbie, and realize that people have
better things to do than lead me around by the
hand, so appreciate it when they decide to help.
I came here a while back, and got the same
great response to a request for help with
modifying a post to work with the school's V2XT.
(which runs awesomely now, thank you very much)
Thanks guys~!
Ocean Lacky - Yes~! The sharp corners are more what I was attempting.
If it's not too much trouble, can you
explain the steps involved in that to me?
If that's too much trouble, can you (or anyone)
point out a decent web tutorial if they exist?
Thanks guys. The help here is really excellent and refreshing.
Weyland
