Macro B (Haas) question
YoDoug®
Would this work? Not sure where you want to go after N9999 is done. I think this could get you close, though it's a little messy.
O0001 (MAIN)
IF [ #698 LT #699 ] GOTO 2;
N2 #100=9999;(SET 100 TO SEQUENCE NUMBER)
M98 P1000;(CALL SUB)
M30;
O1000 (SUB);
GOTO #100;(JUMP TO SET SEQUENCE NUMBER)
N9999;
M99;(RETURN TO P1000 CALL)
 IF [ #698 LT #699 ] GOTO 9999
N9999 M98 P1000
If you only put what you want in P1000 then you won't need to jump to a specific line number. Just another way of getting there. I don't believe you can use GOTO to jump to another program, it's only used to move around within a program.
Mazak will do this with H as the block number to go to in the sub.
M98 P1000 H9999
Fanuc will not do it. My solution was to use G65 instead of M98 and pass the line number as H.
O0001 (MAIN)
G65 P1000 H9999
O1000 (SUB)
GOTO #11
N9999
M99
You can do multiple sub calls to run different portions of the sub this way.
O0001 (MAIN)
G65 P1000 H10
G65 P1000 H20
G65 P1000 H30
G65 P1000 H40
O1000 (SUB)
GOTO #11
N10
GOTO9999
N20
GOTO9999
N30
GOTO9999
N40
GOTO9999
N9999
M99
Thanks guys, I think I have found a solution. However if you have a better solution to what I am trying to accomplish please share.
Here's what I'm doing. I have created a single part counting macro that can be used in all of our lathes and mills for both single cycle (m30) and multiple cycle (bar feed, m99) programs.
The programmer add a manual entry toolpath at the end of his program - G65 P9111 A100. B32.
A= total parts required, B= parts per bar if needed. The macro looks for a B value to count parts per bar as well as total parts. When parts per bar is reached one alarm is generated, when total parts is reached another alarm is generated.
The problem I was having was after the macro returns to the main program how to switch between M99 or M30 based on the B value in the macro. I just modified my master posts to out put a conditional check of a variable set in the macro if B value is present.
This is what the main program looks like.
 G65 P9111 A100. B33.
IF [ #696 GT 0 ] GOTO9999
N9999
#696 = 0
M99
Macro program=
 O9111
(PART COUNTER)
(#1-A = TOTAL PARTS)
(#2-B = PARTS PER BAR FOR LATHE)
(#695 = TOTAL PART COUNTER)
(#696 = M99-M30 RESET IN MAIN PROGRAM)
(#697 = TOTAL PARTS DESIRED)
(#698 = PARTS PER BAR)
(#699 = BAR PARTS COUNTER)
G103 P1
G04 P500
#697=#1
G04 P500
#698=#2
G04 P500
(ADD 1 TO TOTAL COUNT)
#695= [ #695 + 1 ]
G04 P500
IF [#698 EQ 0 ] GOTO100
G04 P500
(ADD 1 TO BAR PART COUNT)
#699= [ #699 + 1 ]
IF [ #699 EQ #698 ] GOTO101
N100
G04 P500
IF [ #695 EQ #697 ] GOTO102
IF [ #698 GT 0 ] THEN #696 = 1
M99
N101
#696= 0
#698= 0
#699= 0
#3000 = 500 (END OF BAR)
N102
#695= 0
#696= 0
#697= 0
#698= 0
#699= 0
#3000 = 501 (TOTAL PARTS REACHED)
