Problem posting code
CNCMike
Hi Guys,
When I post code in MCX2 using the generic mill I get G54 X, Y, A rather than X, Y, Z. Our Fanuc control does not recognize this and gives me a P/S alarm 009 "Unusable character was input in significant area". Any ideas?
Thanks for help as usual!
Mike
Jerry, I am not sure what you mean?
Cadcam, I am posting a fixture for the job we are working on. It includes a pocket cycle, drilling cycles and a tapping cycle.
The values are given for X and Y. A is given the value 0. In the next line of code there is a Z value that gives the initial rapid to part height along with the H1 designation.
See the code below.
N1 G20
N2 G0 G17 G40 G49 G80 G90
( 1/2 FLAT ENDMILL TOOL - 1 DIA. OFF. - 1 LEN. - 1 DIA. - .5 )
( CONTOUR PROFILE TOP SIDE. )
N3 T1 M6
N4 G0 G90 G54 X.01 Y-3.4899 A0. S3000 M3
N5 G43 H1 Z1.
N6 Z.1
N7 G1 Z-.125 F5.
N8 X11.99 F30
Mike
Mike
Ps.
This is from the Generic Fanuc 3X post
# Misc. Values:
# Integers:
# mi1 - Work coordinate system
# 0 = Reference return is generated and G92 with the
# X, Y and Z home positions at file head.
# 1 = Reference return is generated and G92 with the
# X, Y and Z home positions at each tool.
# 2 = WCS of G54, G55.... based on Mastercam settings.
So if you set the 1st Misc integers to zero it will not post G54.
Mike
Ps.
# Misc. Values:
# Integers:
Jerry, I am using G54 work offsets.
Bill, I was using the "MILL DEFAULT" post, which gave me the A in the code. I just tried the "MILL 3-AXIS VMC.MMD" and the A is gone.
Now, is there an easy way to change from the default to the 3-axis without having to start over?
Thanks for all the help! Mike
Cadcam, No I am not trying to shorten the ops. This is a fixture I designed and generated tool paths for in MCX2. It is a short program so it fits in our controllers memory.
I will try to change the machine definition and see how it goes.
Mike
OK, here are two more problems I am having.
The tool change happens before the tool is called. If I start the program with T1 in the spindle the machine changes to which ever tool is waiting in the tool changer. If I start with T1 waiting in the tool changer, the machine performs the tool change, but then throws an alarm because it tried to call T1 which is now in the spindle.
If I bypass that by putting T1 in the spindle and skip past the M6 line the next tool change does the same thing. Rather than calling T2 it changes the tool then calls T2 again giving me the wrong tool in the spindle. See the code below. If I make the T1, T2, T3.... ect... on it's own line before the M6 everything works fine.
N1 G20
N3 T1 M6
N5 G43 H1 Z1.
N6 Z.1
N7 G1 Z-.125 F5.
N8 X11.99 F30
This is not as big a problem, but the machine does not go home during the tool change. It only goes to the Z home position. This is fine on most parts, but if the tool is long or the part is tall, I will need to move the tool change postion so the tool does not contact the part during changing.
Any ideas? Thanks again for helping a newbie!!
Mike
Going home really depends on the machine. What type of machine and what control is on the machine?
M06 on most machine will cause the arm to change. Might need to do /M06 so when you do have the tool in there you just turn on the block delete and when you do not you just turn it off.
BTW encase you do not know this / is block delete.
H
T
H
Mike have you tried running any of my code in the machine. as the layout is different.
Here is the beginning of one of them.
N100 G00 G17 G20 G40 G80 G90
N110 G91 G28 Z0.
N120 (SEMI ROUGHS PROFILE)
N130 M08
N140 T6 M06 ( 3/4 FLAT ENDMILL)
N150 (MAX - Z2.25)
N160 (MIN - Z0.)
N170 G00 G17 G90 G54 X12.7155 Y-1.6819 S5820 M03
N180 G43 H6 Z2.25 T2
N190 Z.6
