Operation Manager problem
rdavidson
Can anyone explain to me why I cannot regenerate a mill path in Mastercam X2MRx SP1 and possibly help overcome this problem? This file has mill and WEDM operations. The times I have had this problem occur in the past I would delete the 1 or 2 WEDM Operations and the mill path would work. This file has several openings that I do not want to delete. The error message that I get is:
DrillCounterbore-G81G82
Operation is incompatible with your current MasterCam Product of level.
Thanks for any help with this problem.
rog
All of the mill operations are in the machine group for the mill and there are 3 toolgroups(bottom setup, top setup, and edge setup)in this machine group. The WEDM machine group is seperate with all of the wire paths in this group. I have tried regenerating 1 toolpath and all toolpaths in a toolgroup with the same result.
Machine Group 1 is for the mill operations. Each toolgroup is labeled as to the setup to preform and each nc. file is saved as the same as the toolgroup (i.e. Bottom setup toolgroup is Bottom setup.nc). Machine Group 2 has the WEDM machine defination and all WEDM toolpaths are in this machine group. I have noticed that when I close MX2 and then open it again that at the bottom of the screen in the tool bar the Mastercam tab opens in the mill definations and then quickly changes to the wire definations.
