Sending Program Crashes Computer
Chris91
We have recently purchased a new computer and have been running for 3 weeks with no major issues. In addition to running MasterCam on this computer we also send our programs to our 3 Haas CNC machines using DNC Software’s SE DNC via RS232 cables. We set up our DNC software with the same settings as the old computer and everything appeared to be working fine. Then this week something changed. It is now taking forever to send programs to one of the machines. 45 minutes to an hour for programs that used to take minutes. And, it is only happening on one of the machines. The other 2 are working fine. We tried to change some of the settings but each time we do that the program starts to load and then crashes the computer. We did get updated DNC software for the 64-bit machine. We are wondering if we need to update our driver for our USB connector. This particular RS 232 is connected to a USB adapter and then into a USB port on the computer. The other RS 232 cables plug into the serial ports.
Thanks for your help.
This is the error message that we are getting when the computer crashes:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.6
Locale ID: 1033
Additional information about the problem:
BCCode: d1
BCP1: 0000000000000068
BCP2: 0000000000000002
BCP3: 0000000000000001
BCP4: FFFFFA6009DF4A34
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
We are not sure what it means.
Start with the driver. If that fails, get a diagnostics tool from the device mfg. It is possible that something happened to the physical device when it was disconnected. (Shouldn't be the case, but we're talking about hardware so Murphy's Law applies.)
Poor cable placement/routing may cause errors / data loss on transfers but should seldom cause an OS or program crash. However, if the device sees something strange (noise?) and the device driver or firmware can't handle it, it could cause a device driver related crash. So, you're back to the device driver or damaged hardware either way.
Let us know what you find.
Mike - Old computer has already been dumped and set up in another department within the company.
Anthony - We ran the diagnostics on the drive and it came back fine. I should start over by saying that we can send programs to the CNC, it just takes awhile. When we try to change some of the settings in the DNC software that is when we start running into problems. We currently have our settings at the following (which work):
Parity Bit - Even
Data Bits - 7
Stop Bits - 1
Flow Control - XON/XOFF
Baud Rate - 115200
The following settings worked the fastest for us on the old computer but this is the setting that is causing the problem. We are able to get smaller programs out with this setting but the larger ones get anywhere from 40%-70% and the system crashes.
Parity Bit - None
Data Bits - 8
Stop Bits - 1
Flow Control - Xmodem
Baud Rate - 115200
Hi Chris,
The BCCode d1 error sounds like a USB driver issue. I have seen automatic MS updates effect communications in the past. Move this HAAS to a direct com port communication and see if the problem follows the machine or the usb port.
Ocassionally you will have trouble with HAAS machines because of the way they handle shield ground. Most communications gurus will tell you to use low capacitance braided shield cable and tie this shield to the shell or pin 1 of the CNC or the DB shell on the PC, serial hub, multiplexer, etc. (not connected to both sides.) If you are getting induced noise on the line and the shield is not grounded properly then it may be causing spurious noise to interrupt the UART on the machine during transmission. Although most likely - you would at some point get a parity error.
John Carpenter
www.WireFreeCNC.com
27 Quality Ave., Somers, CT.
