Creating Tplanes for hole drilling
If so, how can I create an axis in the hole?
I'm not sure if this is the formal way to do it, but I used "Create Surface from Solid", and created surfaces out of the cylinder of each hole. I then un-trimmed these cylindrical surfaces, and created edge curves at the top and bottom, ie. arcs. I then created lines from center to center of these arcs.
With Hole axis you can make this process much faster. We can use solids or surfaces to create the Point and the Line. You can set the line above or below the point. The point come from the center of the cylinder, it can be an offset with a set amount. You also have the Circle option where you create a circle for the Hole you are using as well.
On the Mastercam Programming side I use this tool all the time. On the Verisurf side of things we use this tool a lot as well.
Browse to the bottom of the page for X3: X3 Downloads
Browse to the bottom of the page for X2: X2MR2 Downloads
