an mpmaster question
gcode
rotary_axis2 : c9k #Rotary axis selected in Multiaxis Drill and Curve 5 Axis, 0=X, 1=Y, 2=Z
This is a line from an X3 mpmaster post
Can anyone tell me why
rotary_axis2 is set to c9k
and what c9k does ??
and is this line the trick to getting
5 axis toolpaths to output properly
with a horizontal post?
Thanks Glenn. Glenn is right.
We use the C9K variable which just holds a value of 9999 because this is usually a value that you will be hard pressed to find in a variable.
We use 9999 to ensure a variable is initialized to some unique number that normally can not be gotten any other way.
We may use this as an initial value as in the above example or we sometimes use it to reset a variable say at the toolchanges to ensure we get it back to a known state.
Usually any variable that is assigned c9k (9999) will get another value assigned to it at some point during the posting process by some other method. In the above it gets its value from a parameter, but it could easily get its value from some mathematical calculation or even based on some logic test.
