sub-programs
cnc@gci
Don't completely understand where you are going, but if you mean that you have a bunch of pockets [for example] across your part and you want to use subs to machine them, use Toolpath-Transform and select "create subprograms" or whatever the checkbox says
So your main you tant the following (essentially)
N1T1M6
G0G90G54X0Y0S10000M3
G0G43H1M8
M98P1001
G91G28Z0M9
M1
O1001(SUB)
G1X1.
M99
So on and so forth?
I just updated an MPSubrep post today. I'm adding on all the High Speed Machining Stuff, tool breakage detection, etc... ad infinitum. I'm bored and I'm babysitting a long cycle. biggrin.gif
...is this mpsubrep post that you updated going to be availaible for public use?
Right now it's machine specific (Toyoda HMC with a full 4th) so I don't imagine it would work for everyone so in a word no, it's not for public consumption. If a reseller were to contact me and request it for one of their customers I would happily part with it but end users... no sorry.
A sub program is a segment of code that is called from a Main Program via M98 or M198 for an external device such as a memory card or Dataserver.
See below;
O1000 (T-OP01)
(MCX FILE - POST TEST.MCX)
(POST - MPSUBREP_TOYODA)
(MATERIAL - ALUMINUM INCH - 2024)
(PROGRAM - T-OP01.NC)
(DATE - JUN-019-2009)
(TIME - 09:014 PM)
(PROGRAMMER - JOE MAMMA)
(X ZERO IS ....................)
(Y ZERO IS ....................)
(Z ZERO IS ....................)
(B ZERO IS ....................)
M1
(***** TOOL LIST START *****)
(T1 * 1/2 FLAT VARIMILL ENDMILL * CONTOUR....)
(T8 * 1.8MM COOLANT FED DRILL - NO. 50 * DRILL/CBORE)
(T15 * NO. 8-32 TAPRH * TAP........)
(T13 * 3/64 FLAT ENDMILL * CONTOUR....)
(***** TOOL LIST END ******)
N1(OUTER PROFILE)
G0G40G49G80G90
T1(1/2 FLAT VARIMILL ENDMILL)
M6
G17
G54G90B0.(FRONT TOOL PLANE)
G0G90X1.7689Y.5859S1220M3T8
G43H1Z.25M8
G5P10000
M198P1001(CALLS SUB PROG O1001)
M5
G5P0(HPCC OFF)
G91G28Z0.M9
G49
G90
M75
G65P9863Z5.(TOOL BREAKAGE DETECTION)
M1
N8(DRILL CORNERS)
G0G40G49G80G90
T8(1.8MM COOLANT FED DRILL - NO. 50)
M6
M75
G17
G0G90X-.7419Y.9319S6735M3T15
G43H8Z.1M12
M198P1002(CALLS SUB PROG O1002)
M5
G91G28Z0.M9
G49
G90
M75
M1
N15(TAPL OUTER CORNERS)
G0G40G49G80G90
T15(NO. 8-32 TAPRH)
M6
M75
G17
G0G90X-.7419Y.9319S1024M3T13
G43H15Z.1M8
M198P1003
M5
G91G28Z0.M9
G49
G90
M75
M1
N13(EDGE BREAK)
G0G40G49G80G90
T13(3/64 FLAT ENDMILL)
M6
M75
G17
G0G90X.6361Y.1328S5570M3T1
G43H13Z.25M8
G5P10000
M198P1004(CALLS SUB PROG O1004)
M5
G91G28Z0.M9
G5P0(HPCC OFF)
G90
M99
O1001(T1 * 1/2 FLAT VARIMILL ENDMILL * CONTOUR)
G0G90X1.7689Y.5859
Z.25
Z.1
G1Z0.F10.
X1.2689
G3X.7689Y.0859I0.J-.5
Z.1
G0Z.25
M99
O1002(T8 * 1.8MM COOLANT FED DRILL - NO. 50 * DRILL/CBORE)
G0G90X-.7419Y.9319
Z.1
G99G81Z-1.R.1F2.83
X.5189
Y-.7601
X-.7419
G80
G0Z.1
M99
O1003(T15 * NO. 8-32 TAPRH * TAP)
G0G90X-.7419Y.9319
Z.1
M5
M19
M33S1024
G99G84Z-1.R.1F.0313Q.125
X.5189
Y-.7601
X-.7419
G80
G0Z.1
M99
O1004(T13 * 3/64 FLAT ENDMILL * CONTOUR)
G0G90X.6361Y.1328
Z.25
Z.1
G1Z0.F3.
X.5893
G3X.5424Y.0859I0.J-.0469
Z.1
G0Z.25
M99
just thought I would ask. thanks anyways cnc apps guy ..
Hi Guys,
The subprograming codes are ISO standerdised so any machines they are same, the codes G98 is for Calling suprogram and G99 End of subprogram.
So the main program will have M98 with program no. and noof repets.
You can out put sub programs in mastercam for countur/pkts also by just clicking the icon onthe Depthcuts -> check the botton on for sub programs you can see the codes.
The Advantage of subprograming is to reduce the length of the program.
Hope this info is usefull.
Rao
Hey Rick, another reason it's not for public distribution right now is the post is not ready for prime time. There's a lot of errors (so far nothing affecting the ourput I need) but definitely someting I need to go line by line on when I get some time to do some serious debug time. It's probably going to need a few more hours.
