slow spindle
Elad
We need a faster spindle.
Our fastest spindle has 8000 rpm and it is not enough for engraving.
Buying a new spindle is not an option,it cost a lot.
What is the best way to make our spindle faster and what are the prices??how does it work with tool change??
Hi ,Elad!
I`ve done engaving with 3900 with Okuma5000v with geared spindel biggrin.gif .Now I do it on 8000 on deckel -maho dmc63v and will do it on 15000 rpm if I`ll have. wink.gif
All the secret is good proportion between rpm and feed and a good cutter,
I prefere to do cutters myself smthn like pyramid with 4 sides.
Works good and fast enough on steel and copper.
And for engaving and milling you can find end mills starting from 0.25-0.3 mm .I use them when angle is not allowed.
Regarding various accelerators many of them nonreliable .
Thanks everybody for the replies.
i did engraving letters at 8000 rpm and at the first 2-4 parts it looked great,but then the cutter finished.
I was told that i need a minimum 15,000 rpm for engraving if i want the cutter to work more then 5 minutes in the material.
my depth cuts was 0.2 mm in aluminum,with 8000 rpm and F200.
