HST re-machining
NaRbO
I'm trying to do a rest mill operation in X4 Mu3. The regular surface restmill won't work at all, it gives me a tool path calculation error. The HST toolpath starts calculating but so far it hasn't finished. I've let it go for about 1 hour.
I already programmed the first half of the mold with no problems. Didn't take anywhere near an hour for any of the toolpaths.
I'm using a 4mm tool chasing a 10 mm tool. stepover is 55% with .004 stepdown. Going a total of .371 depth in the deepest area. Tolerance is set to .0025. I'm just referencing the tool diameter and radius for the rest mill. also I have it set to ignore small cusps with an adjust distance of .005.
I referenced an stl file instead and now it works.
I find this happens to me all the time with mastercams restmill. Its never consistent. Sometimes I HAVE to use STL or nothing will happen and other times I HAVE to use tool diameter cause it won't read the STl properly and ends up machining a ton of air.
Thanks for the replies everyone
I just did another rest mill. This time I used a 3mm tool with a .5mm corner rad. the first tool was a 4mm with a 1mm corner rad. I updated the stl after verifying the 4mm. every radius on the part is accessable to the 4mm tool except for a few sharp corners where i need the .5 mm corner rad and some ribs.
So after backplotting the toolpath, i see the 3mm goes almost everywhere the 4mm went and doesn't even touch the ribs at all. I've already tried using the tool diameter and one other operation, no dice.
