machining help
perseid88
We are primarily a drill and mill shop but today I have a different task that I need help with.
I need to surface mill a 5° bevel on the end of a part (carbon steel). We are only talking a few square inches but I don't know how to program this.
I have uploaded a yolk.dwg file (not the .dxf version, it can be deleted) of our part to the drawings folder of the FTP site. Each end (top and bottom) has a 5° slope to it.
I was thinking we would use a ball (bull?) end mill but I don't know what sort of toolpath will do that angled surface.
Up to this point, all of my programming has been limited to 95% drill with some pocket and contour.
Am I creating the angled surface and milling with some sort of stepdown to the prescribed angle or depth? or ...?
I guess I could buy a special flat end mill with a 5° angled bottom but we'd rather not.
Phil
[ 04-15-2010, 04:16 PM: Message edited by: perseid88 ]
I think your edit is correct because when I try surface/finish/flowline, I get the error that I don't have that in mill 1 and I need mill 2.
Goes to show yo how much straight drilling/milling we do. I never needed mill 2 before.
Any other options with mill level 1?
Phil
Just draw two lines parallel to each other with the 5° that you need, then choose toolpaths/wireframe/ruled, then select the two line described above, select your tool (the 3/8 ball will work fine) adjust feed and speed, go to ruled parameters and select zigzag, across distance use about .010 to start, set comp in computer to "off" and set the tip comp to "tip" that should do it for level 1 licence.
You can do this with a 2d contour cut with a bull nose or Ball end mill if you have enough clearance. Select the geometry at the bottom of the angle and in the depth cuts enter the angle in the tapered wall box and your step over in the depth cuts. You can use a square ended tool also but that requires a smaller step down to get a good finish. I like to use a Bull Nose with a small radius then I dont have to go to deep to get the tool tangent. You may have to move the geometry out and down a little (X 5 Deg) so the radius of the tool clears the bottom of the part. cheers.gif
Thanks all. Some of the suggestions above didn't provide the intended results or ended in an error somewhere.
It was the process from Santa Fe that got us to where we wanted to be.
Thanks also to my Mastercam rep who chimed in w/ a private message and offered to help.
