"PIN CONNECTION"
terryrea
Since you are going from a 9-pin connector to a 25 pin connector, I don't think you cross the 2-3 wires.
Here is the correct configuration for a 9-25 pin:
9-pin side...25-pin side
2-----------------2
3-----------------3
5-----------------7
9-pin (computer) side jumpers
jumper 7&8
jumper 1&4&5
25-pin (machine) side jumpers
jumper 4&5
jumper 6&8&20
By jumper, I mean just tie those pins together at the plug.
Most machines use the following configuration:
Data Bits: 7
Parity: Even
Stop Bits: 1 or 2
Try to keep the cable less than 75-100 feet: the shorter the better.
If you get garbage on the line, you're most of the way there. Just play with the baud rate and stop bits.
Go 4800-9600 for longer cables. If the cable is less than 15 feet or so, you can get 39K or better.
Definitely use a shielded cable, and shut the shield to ground (pin 1).
If you have a wierd machine where 2&3 are crossed, try just swapping the 2&3 wires (that is, if you get nothing transmitting), but leave everything else the same.
When troubleshooting, change only one thing (wire, comm parameter, etc) at a time. That way, if it doesn't work, you can switch that thing back. And when it does work, you'll know what the problem was!
Sorry for the long reply, but feel this needed it.
[ 01-28-2002: Message edited by: Charles Davis from San Diego CADCAM ]
