Most common 4th axis technique
Chuckles the Clown
We program around center line and have the table/vice/fixture modeled exactly where it is at on the machine. Just define t-planes around the axis of rotation. This works quite well till someone stuffs it and you have to get everything back where it was. I think this has been covered before, but it will be interesting to see the feed back.
Jeremiah
I find it best to go to the Top Cplane, and then select Cplane, Rotate, Y-UP, and input the index angle. I then Name that plane the same as the degrees of rotation, ex: 30.
I repeat this process to define all the angles of rotation before I program anything.
Then when programming, I select the rotation angle (by name). I also put a note in the comments field, ex: 30 DEGREES.
That makes it easy when I post to see the note (30 DEGREES) and on the next line or so read out the angle (A30.0) so I make sure everything is right.
Sounds a little labor intensive, but it really is not, and it's very reliable.
Consider saving an .mc9 file with all the common angle rotations pre-defined (0, 30, 45, 60, 90 ...). Import the Views from Job Setup so you don't have to do what I described above every time.
Sounds like you and I do it the same Charles.
Depends on if I am positioning then doing 3 axis milling or full 4 Axis.
Depends how the operator wants to do it.
If he wants to mess with finding fixture offsets or he lets Mastercam do it and adjust it small amounts.(Model the set-up in Mastercam)
If you find the center of rotation and feed the software good numbers,it comes out right.
Forgive my ignorance James, I also set WCS for every work offset, but my B axis command gets taken care at the post. Would you explain about how you deal with the A/B?
No need to feel ignorant. I believe Charles stated it as clearly as I ever could so check out his posting.
Charles,
I do the same,the only problem is that after i finish all the ops,i have to go every op one by one to the t/c plane and unmark the "working coordinate system" box.
If i will not unmark it,the post will not output the rotation (B).
what's annoying is that i can't select all,edit common parmeters,and uncheck this box to everything.it doesn't work.i have to do it one by one!
I also recommend that if you have a lot of planes to work on,write a number on the planes and when you save the name in the wcs,write the number too,and you'll not have to remember the angles.
Thank you guys, I'll give it a try and check how it works with our post because as it is set right now I construct and work from the front view and that was the method I used. I'll give it a try from the top, this is exactly what I enjoy so much from this board, you learn something new every day. smile.gifsmile.gif
Thank you, F. Javier
