post selected vb script
Here is a vb script for posting out only the selected operations and creating a setup sheet.
'// Author: Roger Peterson
'// Date: 10/15/04
'// File Name: post_selected.vbs
'// Description: Post out all selected operation. Scan file to determine which operations are selected,
'// ghost any operation not selected, post to selected post processors, un-ghost operations that were
'// previously ghosted. Prompts the user to select the directory for the nc file and again for the
'// directory for the doc file. Constant spost2 holds the path and name of the second post to be used.
'// If you desire to use a .set file you must rename it so it has a .pst extension.
'// Comments: Requires March Maintenance release
' -- Start Script
Dim sprompt
Call Main()
' Sub Declaration
Sub Main()
Dim posting(999)
Dim selected(999)
Dim intOpCount, idx, intCount
Const spost2 = "c:mcam9millpostsset.pst"
Const sdoc = ".doc"
Const snc = ".nc"
Const snci = ".nci"
Const spst = ".pst"
Dim spathnci
Dim snamenci
Dim spathnamenci
Dim namepos
Dim ncipos
Dim sname
Dim spathnc
Dim strPath
Dim spathdoc
Dim contposting
Dim spostoriginal
Dim spost1
Dim spathpst
'--resume the script on errors
On Error Resume Next
' -- Determine how many operations are in the active file?
intOpCount = GetOperationCount(vbNullString)
' -- If the file does not contain any operations, exit the script
If intOpCount = 0 Then ShowString "No operations in the current mc9 file": Exit Sub
' -- Initialize
intCount = 0
' which and how many operations are selected
For idx = 1 To intOpCount
If GetOperationSelectedFromID(vbNullString, idx) Then
selected(idx) = 1
intCount = intCount + 1
Else
selected(idx) = 0
End If
Next
' which and how many operations are NOT ghosted
If GetOperationPostingFromID(vbNullString, idx) Then
posting(idx) = 1
Else
posting(idx) = 0
End If
Next
' -- If no operations are selected exit post
If intCount = 0 Then
ShowString "No operations are selected, You will be returned to Mastercam "
Exit Sub
'Else
' ShowString intCount & " of " & intopcount & " operations are currently selected"
End If
' -- Turn posting off on all ops not selected
If Not GetOperationSelectedFromID(vbNullString, idx) Then
'ShowString " operation # " & idx & " not selected"
Call SetOperationPostingFromID(vbNullString, idx, True)
End If
Next
'Get NCI file name information
spathnci = GetPathFromExtension("nci")
spathnamenci = GetNciNameFromOperationID(vbNullString, 2)
namepos = Len(spathnci)' Determine the length of the nci path - not included is the name of the nci file
namepos = namepos + 1 ' Add one so is not included in the name
snamenci = Mid(spathnamenci, namepos) ' snamenci includes just the name of the nci file and not the directory path
ncipos = InStr(1, snamenci, snci, 1)
ncipos = ncipos - 1 ' Subtract one so when removing the extension the . is also removed
If ncipos Then
sname = Left(snamenci, ncipos) ' This removes .nci from the name
End If
'get post to be used so it can be reset at the end of script
' -- Get the currently set post processor
spostoriginal = GetPostName
spathpst = GetPathFromExtension("pst")
spathpst = spathpst & spostoriginal & spst
'-- Tell the user the post name, the name of the nci file, and how many operations have been selected
'-- and ask if they would like to continue or go back and change the settings
contposting = askYesNo("Postname: " & spostoriginal & " " & vbCrLf & "NC and DOC filenames: " & sname & vbCrLf & intCount & " of " & intopcount & " operations are currently selected" & vbCrLf & vbCrLf & "Select Yes To continue posting, No To return To Mastercam ")
If contposting = 0 Then
Call SetOperationPostingFromID (vbNullString, idx, posting(idx))
Next
Exit Sub
End If
'get directories for nc and doc files
' -- Prompt user for a folder to post nc file-------------------------------------------------
strpath = vbNullString
sprompt = "Select folder for nc file:"
While strPath = vbNullString
' -- Invalid path....
strPath = BrowseForFolder
Wend
strpath = AddBackSlash(strpath)
spathnc = strpath
' -- Prompt user for a folder to post doc file------------------------------------------------
sprompt = "Select folder for doc file:"
Wend
spathdoc = strpath
'post .pst and .set files to their specified directories
'---post to the current nci file name, using post #1------------------------------------------
Call RunPostAll(spathnc, True)
'---post to the current nci file name, using post #2------------------------------------------
Call SetPostName(vbNullString)
Call SetPostName(spost2)
Call RunPostAll(spathdoc, True)
' -- Set posting (Operations ghosted) back To original settings
Next
Call SetPostName(spathpst)
Call SetPostName(spostoriginal)
End Sub
' Function Declaration
Function BrowseForFolder()
Const WINDOW_HANDLE = 0
Const NO_OPTIONS = 0
Dim objShell, objFolder, objFolderItem
Set objShell = CreateObject("Shell.Application")
Set objFolder = objShell.BrowseForFolder(WINDOW_HANDLE, sprompt, NO_OPTIONS, "Desktop")
Set objFolderItem = objFolder.Self
If Err.Number <> 0 Then
BrowseForFolder = vbNullString
Err.Clear
Exit Function
End If
BrowseForFolder = objFolderItem.Path
End Function
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
Coolness, thanks Roger.
Burce,
The script posts the Mastercam file TWICE,
with 2 different posts. If you use the .SET
file for making setup sheets, copy the name
of that post and place it in
Const spost2    = "c:mcam91millpostsyourpostname.set"
Now when you run the script, it will post the
file with the default (from job setup) post,
and then with the post you specify, which will
create the .DOC file.
Hey guys, spost2 holds the name of the second post you would like to use.
I have had some difficulties posting to a .set file on some pc's, so rename your setup sheet .set file to set.pst and it should work fine. Or you can use any name and just modify spost2. I would post it on the ftp but I am having problems with posting files to the ftp site.
I just tied to put this script in to bryan's menu Chook.
I tried different names for the script and came to the conclusion that
I can not have the letter "s" in the name of the script.
example it is called setpost.vbs and i get an error that it can not find etpot.vbs.
so I renamed a different script to have an "s" in it and got the similar error.
if i rename the setpost.vbs to etpot.vbs it will work fine.
has anyone else seen this before.
thank you
Jody
