Peel Mill Help
gcode
I'm trying to use a peel mill type toolpath to rough out a closed slot.
Picture a U
1.25" wide.. the legs are 1" long and the end is a full radius..
the open end is the edge of the stock
I want to use a 1/2" tool and its kicking my butt.
I can chain the 2 straight lines and it works great.. but doesn't rough the closed radius.
I can fake it by putting another full radius on it and using high speed area mill
but that cuts a ton of air.
Is there an efficient way to do this??
Yes
I drew 2 rectangles then trimmed the open end of the slot out of one rectangle.
The tool's first pass went all the way down the C/L of the slot , then stepped out to rough the slot
You've got the slot closed and its doing what I want.
I'll give that a try..
Try using the square as profile 1 and use the entire horse shoe shape as profile two. That will give you what you want. Green as profile and blue as other.
I usually cheat and just close the end of the slot and use the same geometry twice for the two profiles but I dont know if that is a good standard practice to use.. :D
Weird..
I got it working the way I want it.. and the geometry is basically the same as what failed earlier this afternoon.
I'd tried a jillion things with the toolpath, changing from blend to peel to core to area etc etc.
I'll bet that if I'd just deleted it and rechained with a fresh toolpath, it would have worked correctly.
