equaly spaced holes
DODGERFAN
DODGER, I have it, all holes analyze symmetrical & eq. spaced to the tenth if you need it.
kind of a PITA but I will post it if needed
no splines either...
Thanks Keith, but I think I have it now. But if you feel like posting it anyway I'm sure alot of people will learn from it. Thanks man! B)
Analyzed the contour found perimeter to be 1488.709
divide by 26 = 57.25804
broke top line at midpoint
create point segment, distance = 57.25804
broke the top line again at the last point, that "leftover line segment" was 50.242
create point segment on the arc, distance = (57.25804 - 50.242) = 7.01604
keep only the second point created, delete the first at the arc's endpoint and all others but the 2nd
broke the arc at that point
create point segment on the arc, distance = 57.25804
repeat the process for the leftover section of the arc....
xform mirror the rest
How did you & John do it?
This should be way easier than it is
kinda like my spiral staircase example a while back
we need the ability to break a CHAIN at a distance (or equal # of breaks) & to be able to control where the first break occurs
Kieth i got he same result like this.
broke the line at centerpoint.
create spline/curves spline by selecting line beside break point
create point segments
amount of point are 27 (since start and end are same point)
delete multiples
If I have a spline that does not connect and i want equal number of points spaced equally along spline but not on the endpoints i take the number of points wanted + 2 and delete the endpoints.
Lil late to the party but this is how i did it.
Analyze contour
/13
drew arcs@intersection
measured error /13
redrew arcs with error figured in
points @ intersection
last hole had a couple tenths error but plenty close for me.
points could have also been placed @centers.
Mirror on Y and good to go.......
couldnt get break many to do what I wanted it to.
