mm to inch
dannysdad
I don't think he wants to change the geo, just the drafting.
If I am right, you will want to...
-create
-drafting
-multi edit
-pick the drafting you want to scale
-enter
-second yellow box down will be for "scale"
if your dimensions are metric and you want to change them to inches, you need to enter "1mm"
-hit enter and your drafting should now be the inch equivelent.
-create
-drafting
-multi edit
-enter
Keith,
That worked, kinda.
It changed almost all the mm dimensions to inch. There was a vertical dimension "D16" that did not convert. Simple fix, I will just erase it and put in a new inch dimension. It erased, but when I went to re-dimension, it is still dimensioning in mm.
I went through the procedure again and it changed to inch.
