Tool with no SPEED or M3
mr801
I use point toolpaths for TLO checks. My posts output the speed but M05 instead of M03 or M04. If you want it I'd be happy to help, lathe or mill? What kind of post are you using?
I use a unique feedrate to trigger it in the mill post, and the lathe post gets triggered by a misc. integer. (the mill post can be easily changed to become triggered by a misc integer).
Here is what I get:
14 L Z-.1 B+0 R0 F MAX M91
15 L X+0 Y+23.5 R0 F MAX M91
16 PLANE RESET STAY
17 L B+Q121 C+Q122 F MAX
18 ;TOOLPLANE NAME - TOP
19 ;MAX - Z+1
20 ;MIN - Z+1
21 * - TOUCH PROBE
22 TOOL CALL 150 Z S0
23 M5
24 L Z-.1 R0 F MAX M91
25 L X+0 Y+23.5 R0 F MAX M91
26 CYCL DEF 247 DATUM SETTING ~
Q339=0 ;DATUM NUMBER
27 CYCL DEF 7.0 DATUM SHIFT
28 CYCL DEF 7.1 X+0
29 CYCL DEF 7.2 Y+0
30 CYCL DEF 7.3 Z+0
31 CYCL DEF 32.0 TOLERANCE
32 CYCL DEF 32.1 T0.001
33 CYCL DEF 32.2 HSC-MODE:1
34 PLANE RESET STAY
35 L X+0 Y+0 F MAX M8
36 L B+Q121 F MAX
37 L C+Q122 F MAX
38 L Z+1 F MAX
39 TCH PROBE 412 DATUM INSIDE CIRCLE ~
40 Q321=+0; CENTER IN 1ST AXIS ~
41 Q322=+0; CENTER IN 2ND AXIS ~
42 Q262=+0.5; NOMINAL DIAMETER ~
43 Q325=+45; STARTING ANGLE ~
44 Q247=+90; STEPPING ANGLE ~
45 Q261=-.25; MEASURING HEIGHT ~
46 Q320=+0; SET-UP CLEARANCE ~
47 Q260=+1; CLEARANCE HEIGHT ~
48 Q301=+1; MOVE TO CLEARANCE ~
49 Q305=+0; NUMBER IN TABLE ~
50 Q331=+0; DATUM ~
51 Q332=+0; DATUM ~
52 Q303=+1; MEAS. VALUE TRANSFER ~
53 Q381=+0; PROBE IN TS AXIS ~
54 Q382=+0; 1ST CO. FOR TS AXIS ~
55 Q383=+0; 2ND CO. FOR TS AXIS ~
56 Q384=+0; 3RD CO. FOR TS AXIS ~
57 Q333=+0; DATUM ~
58 Q423=+4; COMPENSATION
This is what I want:
16 PLANE RESET STAY
19 ;MAX - Z+1
20 ;MIN - Z+1
21 * - TOUCH PROBE
22 TOOL CALL 150 Z
28 CYCL DEF 7.1 X+0
29 CYCL DEF 7.2 Y+0
30 CYCL DEF 7.3 Z+0
34 PLANE RESET STAY
36 L B+Q121 F MAX
37 L C+Q122 F MAX
38 L Z+1 F MAX
50 Q331=+0; DATUM ~
51 Q332=+0; DATUM ~
57 Q333=+0; DATUM ~
What code would you put in the post for tool 150 to make it post out without the speed(S0) or M3 or M5? I always use tool 150 for my probing.
You should be able to modify your post using very similar arguments from my above post. Basically (or exactly) you are telling your post that if the tool number is = to 150, then don't output that stuff. A quick glance at your code...looks like you have your speed callout and your spindle on callout on different lines....so they would be on different lines of your post. so you would add something like this to your "Tool Call" Line
blah blah blah ( if not( t$ = 150 ), *speed ), e$
and on your next line (Line 23)
blah blah blah ( if not ( t$ = 150 ), *spindle ), e$
[edit]
changed syntax
Here's how I turn the spindle off for probes;
      if virt_tlplnno = 2 | virt_tlplnno = 5 | virt_tlplnno = 6, n$, *sgcode,
      *sgabsinc, pfxout, pfyout, "(", no_spc$, pfcout, no_spc$, ")",
      [if (machine = 60 & t$ = 59) | (machine = 80 & t$ = 4), "M19"], e$
      if t$ <> tlngno$, result = mprint(stoollengthwarn)
     if (machine = 60 & t$ = 59) | (machine = 80 & t$ = 4), n$, "G43",
      *tlngno$, pfzout, e$
     else, n$, "G43", *tlngno$, pfzout, *speed, *spindle, e$
