Post output M911 M912
Hello all: I am trying to mod MPFAN post to output three digit M codes in canned text. This would allow us to use the post on our MAZAK Horizontals. When I add the M codes to canned text and select them for output at posting I get a 2 digit output only. I have tried reformating the output variable with no success. Any suggestions?
Mcam X5, solids, multiaxis, port expert, etc.
toolpaths, manual entry, as code.....
or is this something that you need permanent in the post?
Yes it should be. I am trying to make this as easy as possible for the programmers. Here, most of our people do their own programming. Unfortunately not all of them are sophisticated Mcam programmers. Thus the making it easy part. I was hoping that I could mod canned text so that a simple selection and placement could be made.
I am far from a 'guru', but I can offer this:
Find this line in your post:
fs2 6 3 0 3 0l #Integer, force three leading
Copy and paste, then modify to this:
fs2 23 3 0 3 0 #Integer, three leading not forced
Then modify this line:
fmt M 5 cantext$ #Canned text
to this:
fmt M 23 cantext$ #Canned text
Canned Text give you a method for outputting M codes to your NC File (as you've already figured out).
The issue is that you need to write some additional code into your post to output these specific strings. Just changing the text field in the Control Definition does not change the output from the Post.
There are 200 optional canned text entries that you can manipulate. By default (without post modifications), the Canned Text number you use gets converted into an M Code (M + cantext$). So if you use Canned Text number 112, it would get converted into M112 when output to the NC File.
The solution (since you want M codes greater than M200) is to modify your post. This will also let you move those M codes up in the Canned Text list.
Canned Text 1 and 2 are used to control Machine Stop (M00) and Optional Stop (M01). Canned Text 3 and 4 are used to control Block Delete.
So I recommend starting with Canned Text #5 and higher.
In this example, I'm using Canned Text 5, 6, 7, and 8. I've modified 5/6 to output M600 and M601, and 7/8 to output M912 and M913.
First, make a backup of your Post file before you begin.
The first thing inside the Post you need to do is create your output strings (initialize string variables). I've added 4 new string variables to the list below:
#Cantext string definitions (spaces must be padded here)
sm00         : "M00"
sm01         : "M01"
sm600        : "M600 "
sm601        : "M601 "
sm912        : "M912 "
sm913        : "M913 "
strtextno    : ""
strcantext   : ""
Next you need to modify the pcant_out Post Block to include your new Canned Text options. Specifically, you need to change the 'greater than' condition to be greater than '8'. Then add the code to handle Canned Text 5-8. Do not worry about Canned Text 3 and 4. These are used to control block delete (calls to 'pbld').
pcant_out       #Canned text - build the string for output
     #Assign string select type outputs
     if cant_pos < three, #cant_pos indicates canned text output
       if cantext$ = three, bld = one
       if cantext$ = four, bld = zero
       #Build the cantext string
       if cantext$ = one, strcantext = strcantext + sm00
       if cantext$ = two, strcantext = strcantext + sm01
       if cantext$ = 5, strcantext = strcantext + sm600
       if cantext$ = 6, strcantext = strcantext + sm601
       if cantext$ = 7, strcantext = strcantext + sm912
       if cantext$ = 8, strcantext = strcantext + sm913
       if cantext$ > 8,
         strtextno = no2str(cantext$)
         strcantext = strcantext + strm + strtextno
     else, #cant_pos indicates coolant output
The final step is to modify the Canned Text entries in the Control Definition. That way when a user opens the Canned Text menu, they will see option #7 shows "M912" (or whatever you set it to be).
[/code]
Nice Colin, your replies are always so helpful. I figured this out by using the debugger but now that you mentioned it here it's become clearer; Thx. I see where the formating of the M string for canned text would have no effect on the output desired as G999 is beyond the 200 entries allowed, thus the need for "Gxxx". I was the one that introduced the G999 R. C. Hinds never mentioned what M code he actually wants. Customizing is the way to go though since even if he wanted an M code within the 200 limit he would have to use that value way down the list.
Colin do you recommend removing this from the post?
       if cantext$ > four,<-------------- now turned into five
No, I would not recommend removing that line. I would recommend changing the "greater than" value to be greater than the highest value you are using.
Say you used Canned Text options 5-14. Each Canned Text option would be configured to output something different. In that case, I would just change the 'greater than' value to '15'.
You could change the action (what happens if the condition is true), to warn the user if something 'unsupported' was used. This would be done with an mprint statement.
RC,
You can usually get help on these modifications from your Reseller, or someone on this board can probably help you out. This is a fairly basic post change. You'll be adding several variable initializations, and making some changes to the pcant_out post block. The last part is modifying the fields in the Control Definition.
This is an awful lot of work to do a pallet change. Since there are no other inputs that need to go with a pallet change, and no real reason for it to be tied into any actual toolpath, wouldn't it be easier to just do a manual entry toolpath? That's what we do.
  • 11 months later...
Hey, I'm trying to do the same thing, but use Canned Text 6 and 7 for M3 and M4. Here's what I tried:
sm00		 : "M0"
sm01		 : "M1"
strtextno    : ""
strcantext   : ""
# Generate string for spindle
sm04    : "M4"	   #Spindle reverse
sm05    : "M5"	   #Spindle off
sm03    : "M3"	   #Spindle forward
spindle : ""		 #Target string
    if cantext$ = five, strcantext = strcantext + sm05
    if cantext$ = six, strcantext = strcantext + sm03
    if cantext$ = seven, strcantext = strcantext + sm04
    if cantext$ > seven,
and my code comes out like this:
M5M3M4M05
Any ideas where I went wrong? Thanks!
