V9 post edit help
Roger
Can someone help me with editing the generic fanuc post for V9 Mastercam? The machine is a Mori-Seiki MV-45 mill with a Fanuc 6m control.
I've alredy changed it to stage the tools, what I need now is to output T5001 for tool 1, T5002 for tool 2 etc., and just M6 for the tool change. Since the tool is already in position.
Here is a sample program that was in the control that shows what is needed.
O1618
(1618)
(STAND PART VERTICAL HOLDING ON .840/.850 DIA WITH EAR TO RIGHT )
(2397-1T MILL .1 05/28/09 REV-ORIG)
(1/2 DIA STOP PIN ROTATE PART TO PIN FOR ALIGNMENT)
N1G90G49G94G57G40
G0T5010M5
G0X0.78Y0.4135
G43Z2.0H9
G1Z-.5F100.0
M0
G0Z2.0
G0G91G28Z0M19
G28X0Y0
M01
M06
(1/2 DIA ROUGHING ENDMILL ROUGH PROFILE )
N2G90G49G94G55G40
G0S3000M3T5011
G0X0.78Y-0.6385
G43Z2.0H10M8
G0Z0.6
G1Z-1.2F200.0
G41G1Y-0.1885D26F18.0
G1X0.4059
G2X0.0Y-0.4475I-0.4059J0.1885F22.5
G2X-0.4475Y0.0I0.0J0.4475
G2X0.0Y0.4475I0.4475J0.0
G2X0.4059Y0.1885I0.0J-0.4475
G1X0.78F18.0
G40G1Y0.6385
G0Z2.0
M9
G0G91G28Z0M19
G28X0Y0
M01
M06
(3/8 DIA ENDMILL FINISH .840/.850 DIA)
N3G90G49G94G55G40
G0S2400M3T5001
G0X0.7675Y-0.551
G43Z2.0H11M8
G0Z0.6
G1Z-1.2F200.0
G41G1X0.955D27F20.0
G3X0.5675Y-0.1635I-0.3875J0.0F15.0
G1X0.3896F20.0
G2X0.0Y-0.4225I-0.3896J0.1635F25.0
G2X-0.4225Y0.0I0.0J0.4225
G2X0.0Y0.4225I0.4225J0.0
G2X0.3896Y0.1635I0.0J-0.4225
G1X0.5675F20.0
G3X0.955Y0.551I0.0J0.3875F15.0
G40G1X0.7675F20.0
G0Z2.0
G0Y-0.551
G0Z0.6
G1Z-1.2F200.0
G41G1X0.955D27F20.0
G1X0.3896F20.0
G1X0.5675F20.0
G40G1X0.7675F20.0
G0Z2.0
M9
G0G91G28Z0M19
G28X0Y0
M1
M6
A big thank you to those that are willing to help.
Wish I could help with adding the 20, the last time I looked at a V9 screen was 2003 (i think).
But for the post, I see you already have the "T5001" being posted... just not in the right spot.
If you can find the ltlchg postblock, post a screen shot of it.... (not sure if the variables are the same as they are now, need to see it).
BTW, this is a pretty simple thing to modify, a call to your reseller & they can probably do it for you pretty quick. And it will be done correctly (no guessing)
175 views, but only one person replied.........That's sad.....I was working for this guy today, and answer part of my question on adding values to your tool number in the job set-up field before you do any toolpaths.
I started programing back with version 7 MC, so going back to V9 it's hard to remember how to do things.
I guess I'm going to have to install V9 on my computer, and mess with the post myself. Anyone want to point me in the right direction? :yes
Well, the best way is to call your reseller. But if you want to give it a try, here is a couple thing you can do.
I dont have V9 any more in my computer, so i will try my best.
First of, BACK UP you post then try to locate this section in your post
# FORMULAS - global formulas
toolcountn = toolcount + 1 # Index!
toolcountp = toolcount - 1 # Index!
tloffno_roger1 = tloffno + 5000
tloffno_roger2 = tloffno + 20
then find this section:
# Toolchange / NC output Variable Formats
fmt T 4 t #Tool No
fmt T 4 first_tool #First Tool Used
fmt T 4 next_tool #Next Tool Used
fmt D 4 tloffno #Diameter Offset No
fmt D 4 tloffno_roger2 #Diameter Offset No + 20
fmt H 4 tlngno #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
# Tool Comment / Manual Entry Section
ptoolcomment #Comment for tool
tnote = t
toffnote = tloffno_roger1
toffnote = tloffno_roger2
tlngnote = tlngno
tldianote = tldia
"(", pstrtool, *tnote, *toffnote, *tlngnote, *tldianote, ")", e
pstrtool #Comment for tool
if strtool <> sblank,
# Motion output components
pbld #Canned text - block delete
if bld, '/'
pfbld #Force - block delete
pccdia #Cutter Compensation
#Force Dxx#
if prv_cc_pos <> cc_pos & cc_pos, prv_tloffno_roger2 = c9k
sccomp
if cc_pos, tloffno_roger2
pfxout #Force X axis output
if absinc = zero, *xabs, !xinc
else, *xinc, !xabs
You should get it going somewhere.
Good Luck.
