Z on the same line with an ,I,J,or K.
HEAVY METAL
I'm getting a error at the control it is a fanuc control .
Is this a fanuc issue or a post edit. I don't want to post this thing point to point. Got me scratching my head. I 've tried a few things but no luck
N8054 G01 X.5958 Y.291 Z-.1612
N8055 G03 X.5934 Y.2959 Z-.1611 I-.0668 J-.0307~~~~~~~~~~~~~~~~~~~~~~~~~~~~
N8056 X.5749 Y.3303 I-7.3227 J-3.9044
Helix is an option on the older controls 6M 10M 0M ect.
I've not had issues with any current machines running Helixes
Your code shows a very small arc move.
The change in X is .0024
The change in Y is .0049
The change in Z is only .0001
I would look in your control deninition under tolerances and set the minimum arc length to like .01" the default is something like .0005" (way too small IMHO)
In the arc settings set the error checking to length of arc.
Allan
You likely have a helix option in regular mode then, but when in High Speed (hpcc or similar) mode it (helix) used to be a separate option. Turn it off and re-run it the program, see if that helps. If that's it then point to point is your only option when using high speed...
Is it alarm #28?
For Fanuc 16i
Check parameter 8485 bit 2. If it is zero helical interpolation is disabled in hpcc mode. Change it to a 1 to enable it.
Allan
From the Fanuc Manual:
NOTE
1 G00, auxiliary functions, subprogram call (M98, M198), and macro
call M and T codes can be specified in the HPCC mode only when
bit 1 of parameter MSU No. 8403 is 1. If these codes are specified
when MSU is not 1, an alarm is issued.
(Alarm No.5012 for G00 and alarm No.9 for auxiliary functions and
subprogram calls)
2 To specify the following functions in HPCC mode, the following
parameters are required. Specifying any of the following functions
without setting the corresponding parameter causes an alarm.
Helical interpolation : Parameter G02 (No.8485*)
(Alarm to be issued: No.28)
Involute interpolation : Parameter INV (No. 8485)
(Alarm to be issued: No.10)
Scaling, coordinate rotation : Parameter G51 (No. 8485)
Canned cycle, rigid tapping : Parameter G81 (No.8485)
(Alarm to be issued: No.5000)
