VMC with C Axis (Rotary axis around Z)
Mick
I have a rotary axis fitted to the table of a VMC, and it is a C axis, rotating about Z
We're using it to drill a large bolt hole circle, and the bolt hole circle is larger than the Y travel of the machine, so we want to move the tool in X and C to achieve the required BHC.
Because of the setup of the C axis, and the part, we have the C axis mounted to the right side of the machine, and the workpiece origin is the centre of rotation.
How can I force Mastercam to keep the tool in the X- position and rotate C? When I create the toolpath, it wants to move to X+ and then rotate accordingly. Even when I choose the first hole position in the X- position.
Has anyone ever enountered this?
Mick,
Here's how I set it up,... select a point for the drill toolpath in the neg X, 09:00 looking from the top, then use a toolpath transform for the rotary output,...
I set the type to "rotate" method to "toolplane" source "NCI" then in the rotate page set the number of instances, I set the angle to start at zero and the second is the angle between, the rotation view is set to "Top"
I'm using the MpMaster to output the code below, I changed the axis of rotation in the "A" axis properties in the machine def
N50 G28 Z0.
N55 T1 M06 ( 1/2 SPOTDRILL)
N60 G00 G17 G90 G54 A0. X-5.75 Y0. S1675 M03
N65 G43 H1 Z.125
N70 M08
N75 G94
N80 G99 G81 Z-.125 R.125 F16.5
N85 G80
N90 G91 G28 Z0.
N95 G00 G90 A45. X-5.75 Y0.
N100 G43 H1 Z.125
N105 G99 G81 Z-.125 R.125 F16.5
N110 G80
N115 G91 G28 Z0.
N120 G00 G90 A90. X-5.75 Y0.
N125 G43 H1 Z.125
N130 G99 G81 Z-.125 R.125 F16.5
N135 G80
N140 G91 G28 Z0.
N145 G00 G90 A135. X-5.75 Y0.
N150 G43 H1 Z.125
N155 G99 G81 Z-.125 R.125 F16.5
N160 G80
N165 G91 G28 Z0.
N170 G00 G90 A180. X-5.75 Y0.
N175 G43 H1 Z.125
N180 G99 G81 Z-.125 R.125 F16.5
N185 G80
N190 G91 G28 Z0.
N195 G00 G90 A225. X-5.75 Y0.
N200 G43 H1 Z.125
N205 G99 G81 Z-.125 R.125 F16.5
N210 G80
N215 G91 G28 Z0.
N220 G00 G90 A270. X-5.75 Y0.
N225 G43 H1 Z.125
N230 G99 G81 Z-.125 R.125 F16.5
N235 G80
N240 G91 G28 Z0.
N245 G00 G90 A315. X-5.75 Y0.
N250 G43 H1 Z.125
N255 G99 G81 Z-.125 R.125 F16.5
N260 G80
N265 M09
N270 M05
N275 G91 G28 Z0.
N280 G28 Y0. A0.
N285 G90
N290 M30
Another Option:
Still using the MpMaster files I've also switched the zero position for the rotary to neg X
I selected the points for the drill toolpath and make certain the points are ordered with the first point at 09:00, after all the parameters are set go o "axis control" in the "rotary axis control" set the rotation type to "3 axis" and set the rotation around Z
N5 G00 G17 G20 G40 G80 G90
N10 G91 G10 L2 P1 X0. Y0. Z0. ( G54 A0. )
N15 G28 Z0.
N20 T1 M06 ( 1/2 SPOTDRILL)
N25 G00 G17 G90 G54 A0. X-5.75 Y0. S1675 M03
N30 G43 H1 Z.125
N35 M08
N40 G94
N45 G99 G81 Z-.125 R.125 F16.5
N50 A-45.
N55 A-90.
N60 A-135.
N65 A-180.
N70 A-225.
N75 A-270.
N80 A-315.
N85 G80
N90 M09
N95 M05
N100 G91 G28 Z0.
N105 G28 Y0. A0.
N110 G90
N115 M30
Thanks for the replies.
Cjep, I will check that out. I used the same settings for my post, but it didn't output the X- at all. I will check out MpMaster, and see how that goes.
In the meantime, I hacked the post to output the X- correctly, but I don't like the way I did it, because it doesn't really reflect in backplot what you get posted.
Alvaro, the only drawback with that option is that a drill cycle is output for every angular move (major code bloat :) ).
Also, if the the bolt holes aren't in a repeating pattern, then the probelm still exists. I'm going to dig a little deeper with this :)
