Negative angle surface wall
Santa Fe
What would be your prefered toolpath to machine a wall surface that has a negative angle and all you have is a 3-axis machine and a Lolipop EM or a specaial grinded EM to reach the end of that negative angled wall.
I wonder if anybody has a different approach than mine. In the past I have used toolpaths like surface flowline, wire frame ruled, lofted.
I would like to see other opinions and what has worked for other programmers.
Appreciate all inputs.
Colin,
I did a quick solid 1" tall to try your input above. The solid has three walls, one at -6.5° then a fillet radius of R.28 that transitions to a vertical wall. Regardless of whatever I do in the settings, the backplot shows the toolpath going down verticaly, it does not follow the negative angle wall. What am I doing wrong. I am attaching the sample I did.
Do you have a sample file so I can look at what setting you check.
I put a sample file on the Forum FTP site. It is located under 'Training Files' and the file name is SFC_UNDERCUT.MCX-6.
I started by creating some surfaces from the solid faces (I find it easier to drive the surfaces and I like being able to turn everything else off)
I used a containment boundary to prevent the tool from cutting on the outside of the surfaces. I defined a .500 Lolipop cutter, and turned off the check boxes for gouge checking in the "Gap settings".
Check out the settings in "Direction". This option provides Lead In/Out motion on the surface. Sometimes you need to play with the angle settings to get the right motion. (I usually just generate the path and check it visually, then adjust that angle number and regenerate the path until it is correct.
