Compact flash and drip feeding
Chris Parish
Hello:
I have modified the proper settings for a Hardinge w/ fanuc 18i
But now when I use the "main program" (listed at the very end of this message)...to call up the program from the card, I get an error of
T "CMD" not vaild with "M6" on the control
.....Can anyone help me with this??
Parameter Settings: #138.7 = 1
DNC operation with memory card is:
0 = disabled
1 = enabled
#3404.2 = 1
Address P in M98 block of subprogram call function is:
0 = indicating a file number
1 = indicating a program number
#6300.4 = 1
External program number search
0 = disabled
1 = enabled
#6080 = 0
I/O Settings:
Channel = 4
ATA Card:
File name on card must match program number, DO NOT use filename extension. (.txt)
Example:
card filename - O0001
program number - O0001
Use % at beginning and end of program file.
Program Call:
Create program in NC memory:
O0001
M198P2 (calls O0002 on ATA card)
M30
I could of sworn I was told that you couldn't call to a card from a main Program w/ Fanuc??
Maybe EONS ago, but any i Series Control should be able to do it with ease by changing a few parameters.
Did it today for the 1st time - poor mans data server ref one of James's old threads here. Works like a charm :cheers:
We commonly run M198 for an optirough style path (big code) but this mother hubbard was such a big prog the whole thing had to be run as an external sub.
