okuma osp200m hi-cut feature
Hey guys new to the forum hear, been a machinist for close to five years now and worked in a job shop that is dominately okuma mills and lathes.
Were located in southern Illinois and use master and conversational for our programming, we have been getting alot of work of profiling nest and numerous other parts that are made out of delrin. Im trying to wrap my head around this hi-cut codes (nobody here really goes outside of the box when machining) and im just curious on how exactly it works.
I understand it anticipates corners straights and what not to hold tolerance but for roughing i would like to turn it off and have it on for finishing,
If someone could explain this to me like im a dummy that would be perfect.
We have custom post for our Okuma mills, but i didn't really seen any true options for the hi-cut, is this something you have to manually enter into the program or what?
I have alot of questions about this and would definately appreciate any help I could get from you masters on here!
Thanks again,
Cody
This may be a little over the top but hey it works for me
1st Define the strings
hsmset :1 #High speed cutting 0=off 1=Hicut pro G131 2=Supernurbs G131 3=HiCut G187
hsmon : 0 # G131 flag
Then in the tool change blocks
if opcode$ = three | opcode$ = 16, e$ #GHW
else,
if hsmset = 1, #High-cut pro
if mi8$ = one & mi7$ = one, result = mprint(shspmill)
if mi7$ | mi8$ > 0 & cas_off, n$, "M510", e$
if mi7$ = one, n$, "G131", "J2", [if mr1$ <> 0, *mr1$, else, "E0.025"], "F20000", "(HICUT PRO ROUGHING)", e$
if mi8$ = one, n$, "G131", "J1", "E0.01", "F20000", "(HICUT PRO FINISHING)", e$
if mi7$ | mi8$, hsmon = 1
if hsmset = 2, #Super Nurbs
if mi7$ = one, n$,"G131", "J0", [if mr1$ <> 0, *mr1$, else, "E0.025"], "D0.010", "I0", "F20000", "(SUPERNURBS ROUGHING)", e$
if mi8$ = one, n$,"G131 J0 E0.01 D0.005 I0 F20000", "(SUPERNURBS FINISHING)", e$
if hsmset = 3, #High-Cut
if mi7$ = one, n$,"G187", [if mr1$ <> 0, *mr1$, else, "E0.025"], "F20000", "(HICUT ROUGHING)", e$
if mi8$ = one, n$,"G187 E0.01 F20000", "(HICUT FINISHING)", e$
And then in the retract blocks
if hsmon = 1,
if hsmset = 3, n$, "G186 (HICUT OFF)", e$
else, n$, "G130 (SUPER NURBS OFF)", e$
if cas_off, n$, "M511", e$
hsmon = 0
also in the error messages
shspmill : "ERROR-CHECK HIGH SPEED MILLING PARAMETERS"
add this to the MI numbers
7. "Super Nurbs High Speed [1 = ON]"//1
8. "Super Nurbs Ultra high Accuracy [1 = ON]"
Hope this helps
so the post needs to be edited to be able to control the hi-cut then?
i dont fully comprehend the misc integers and reels as nobody here has ever touched them so when being trained i was never explained to how they work.
sorry like i said im basically clueless when it comes to this haha
Hello Sarver,
I'd recommend talking with your Reseller to inquire about the OSP_P200M post. There is a post available from CNC Software to your Reseller (They have the option to charge for the post, so it might not be "free"). This post is included in the "Mastercam X7 Post Installation" program.
The OSP_P200M post is already configured to output code for either Hi-Cut Pro, or Super NURBS (set by a switch in the post).
Hope that helps,
Colin
well i did notice today our custom post, does turn super nuerbs on and off when profiling it still seems like these machines could be running muchharder while roughing during profiling.
Is there a way to see true feed rate on the machine and not just whatever is called out in the program?
thanks
The "Feed Axis Data" page will show you all of that. Also one of the things with the Okuma open API on the THINC controls is you can make your own custom interfaces. I built this one the other day for a HMC that had all the desired data collected on that page
That is really cool. I would really like to be able to do that sort of thing myself.
Got to dig Okuma controls :)
We have been doing more and more of it! Once we got the first few applications built it got easier to do. Debugging the apps seems like it takes the longest. :D
So are you at Hegmans?
I was in Charlotte at the Thinc facility about two months ago. What a great place. I had a blast, and learnt a lot. I definitely want to head back there some time!
