Reinitialize "sgfeed"
I've got an old V9 vintage mill/turn post we're using on a big VTL with C axis milling.
It needs to be done over, but there is a time issue.
When we are doing milling, the first mill tool path gets a  G94 ( inches per minute) output  with the first feed rate command
G0 G90 G54 X179.0506 Z15. C-4.861 T1818
Z5.
Z1.
G94 G1 Z.75 F20.
X178.0511 C-4.872 F2.
subsequent milling toolpaths do not..  which means the machine reads an F10. as 10 inches/rev  =  a very bad day
G97 S130 M3
G0 G90 G54 X175.2457 Z15. C172.015 T1818
Z5.
Z1.
G1 Z.5 F20.                       <-----------------------  No G94 = train wreck
X174.2458 C172.007 F2.
X173.2462 C172.
oddly enough , all C face drilling toolpaths are good.
it's just milling toolpaths that are acting up
can someone tell me how to fix this?
I am no expert but I think this might work.
Create a variable.  In the tool change section set it to 1.  Then use a statement so it will force the output if the variable is 1 and then reset the variable to 0.
Something like
If newvariable=1, *sgfeed, else, sgfeed
'sgfeed' is a target variable for a string select function. The String Select function uses a numeric variable to control the output of the target variable through modality.
'sgfeed' uses 'ipr_actv$' as the selector variable. So all you need to do is go into the tool change post block for milling, and set 'prv_ipr_actv$' to a different value (ck9 is usually used for this purpose).
Then in 'plinout' 'sgfeed will be encountered on the output line. You will get a 'G94', since that is how your post is configured, and then MP will automatically update the 'prv_' value of 'ipr_actv$' when 'sgfeed' is output. This prevents getting a 'G94' on every line.
Yes things like this are were outside post builder have such a fit. They never realize how much background stuff the MP.DLL is doing during the posting operations.
