Help with 4th axis drilling
Mic6
Hey Guys, First time drilling with a rotary axis in my VMC.  I included a sample file I'm working on.  Do I use 5axis drill or normal drill toolpath with rotary positioning?  I have a multi-axis seat.
The current file I used 5axis drill.  I tried using lines and surface for tool axis control.  I tried hole axis vectors and points for cut pattern, but I'm not really getting anywhere and I keep getting the error below.
rotary sample.mcx-8
Download the Mpmaster and give it a test drive, you'll like it!
Did that this morning.  Been copying over some of the mods I had to my Generic Haas post, but some don't work.
Here is your file with your operation. I moved the point to the bottom of your vector lines that define the tilt and and repicked as a window point set to use points and lines. and regen.
Thanks Jay, I'll give it a look.
Hey Jay, I used your parameters in my file in which I was previously using a plane for each group of holes in a 2D toolpath and the actual parts drilled correctly.  The multiaxis drill worked and showed correctly in MC backplot, but the A axis moves in the machine were backward(opposite of backplot)  Maybe that's a post or machine setting issue?
