Okuma OSP300M post question
jeff
How can I have my post look at the first tool # that Mastercam spits out, and have it be written as the tool # that I have in red bold below?
I have this after my tool list in my post:
      "IF[VATOL NE 1]N1",e$
      "IF[VATOL EQ 1]N2",e$
      "M1M329",e$
      "T1M6",e$
      "N2",e$
What this does, or what I am trying to accomplish is to "dummy proof" and have the program index to the first tool in the program upon cycle start. No matter what tool is in the spindle, and no matter if there is a Next Tool staged. I know an M64 will clear the staged tool, but it gives an error if there isn't a staged tool.
The variable that holds the current tool number is "t$". It is formatted to output "T" in front of the value, so I'd recommend creating a User-Defined variable, and setting it equal to the value of "t$". Then you can output your Tool Check/Skip function, and it will take the current value of the tool. "next_tool$" holds the "pre-stage" tool number, and I believe 'first_tool$' holds the "first tool number", so you can output a Tool Change to that tool, at the end of the program.
I already have a tool change to my first tool at the end of program. But sometimes we need to index to a tool for an insert change, broken end mill, etc... and as we all know, we've seen operators push cycle start and crashing because they forgot to index back to the starting tool. lol
That's what I'm trying to prevent.
Why can't all MTB's have it in thier tool change logic to check spindle tool against the tool change and stage commands......  That way you can always command a stage and or tool change for a tool already in the spindle and carry on without a bunch of extra crap to have in the running program.
I think I'm starting to grasp it a little bit.
How do i write my post so that it changes "first_tool$" to the actual tool number? I know that I would have to somehow get rid of the quotation marks in order for this to work.
"IF[VATOL NE first_tool$]N1"
I want my program to read
IF[VATOL NE whatevertoolnumber]N1
7 minutes ago, huskermcdoogle said:
I think you need commas.
"IF[VATOL NE", first_tool$,"]"N1"
You are correct! :)
This is what I have now, and am going to try it:
      "IF[VNTOL GT 0]N1",e$
      "IF[VATOL NE " *first_tool$ "]N2",e$
      "IF[VATOL EQ " *first_tool$ "]N3",e$
      "N1M64",e$
      "N2M329",e$
      *first_tool$ "M6",e$
      "N3",e$
      "M279(CHIP AUGER ON)",e$
Jeff,
We normally set up a G116 library file with a custom macro that has all the logic to check the tool requested, spindle tool, and next tool - then make the appropriate action. We then just change our Mcam post to put out G116 T*** instead of T*** M6.
OATC1
(TOOL CHANGE MACRO)
(COMMAND IS G116 T?? Q??)
(T=DESIRED TOOL #, Q=NEXT TOOL #)
(G116 T0 WILL CLEAR TOOL FROM SPINDLE)
(FEB 5, 2004)
M329
M5
G0Z5000
IF[PT EQ 0]NMT
IF[VTLCN EQ PT] NFIN
IF[VNTOL EQ PT] NCH
IF[VNTOL EQ 0] NCHG
M64
NCHG T=PT M6
NFIN IF[VNTOL EQ 0] NTL
IF[VNTOL NE PQ] NCLR
GOTO NEND
NCH M6
GOTO NFIN
NCLR M64
NTL T=PQ
GOTO NEND
NMT IF[VNTOL EQ 0]NRID
M64
NRID M63
M6
NEND RTS
On 4/28/2017 at 4:28 PM, YoDoug® said:
Jeff,
OATC1
(TOOL CHANGE MACRO)
(FEB 5, 2004)
M329
M5
G0Z5000
IF[PT EQ 0]NMT
IF[VNTOL EQ PT] NCH
IF[VNTOL EQ 0] NCHG
M64
NCHG T=PT M6
GOTO NEND
NCH M6
GOTO NFIN
NCLR M64
NTL T=PQ
GOTO NEND
M64
NRID M63
M6
NEND RTS
My brain just exploded. lol
I'll dive into this and see if I can implement this.
Where does the library file go?
On 4/28/2017 at 3:04 PM, huskermcdoogle said:
Still need commas!
      "IF[VATOL NE ", *first_tool$, "]N2",e$
      "IF[VATOL EQ ", *first_tool$, "]N3",e$
      "N1M64",e$
      "N2M329",e$
      *first_tool$, "M6",e$
      "N3",e$
Or did it work without?
This is how it's spitting out the code, it looks fine to me, but it's giving an error on the 2nd line. It doesn't like the way it's worded I guess.
IF[VNTOL GT 0]N1
IF[VATOL NE T20]N2
IF[VATOL EQ T20]N3
N1M64
N2M329
T20M6
N3
You are getting a "T" prefix character for the 'first_tool$' variable. You need to create your own "user-defined" variable, with a different Format Assignment, to output just the numeric value, and not output the "T" prefix.
At the top of your post, create a new variable:
my_tool : 0
Then, go to the Format Assignment area of the post, and add this line (after the other FMT lines...):
fmt ""  4  my_tool
Now, before your block of output code, set your variable equal to the 'first_tool$' variable, and use it for output:
      my_tool = first_tool$
      "IF[VATOL NE ", *my_tool, "]N2",e$
      "IF[VATOL EQ ", *my_tool, "]N3",e$
      "N1M64",e$
      "N2M329",e$
      "N3",e$
The Library file (.LIB extension) goes into the MD1 directory. When you are in auto or MDI there is a button on the screen bottom for Library programs. The procedure to register is in the special programming manual. I can also send you a pdf on it if you PM me your email address.
my_tool : 0
fmt ""  4  my_tool
      "N1M64",e$
      "N2M329",e$
      "N3",e$
OHH!! I didn't even notice the T in there!   :bonk:
7 hours ago, Greg Williams said:
Just change the parameter to alarm D, problem solved
MC user Parameter
no7 ATC/Tool exchange
Tick no 22 "The same T command as act tool is made alarm D"
Interesting. Is the D alarm something that lights the Red light but still allows the program to run?
EDIT: tested it.. yes it does run with the alarm :)
