BBaker3
Tool Manager crashes in 2018
New Installation, but had been running 2018 on a different pc.
First time to access Tool Manager.
I can load a library, but double clicking on cutting tools to bring up a list in the center window, crashes the application.
Tried two different libraries, same result.
Task Manager reports ToolManager.shell is "not responding".
Barry in St Louis
I have the exact same issue.  Anyone know how to fix it?
I have seen this issue occur on laptops with integrated graphics. The Tool Manager, for whatever reason, tries to use the Intel integrated graphics first, and when it needs to draw something on the screen, like when you double click on Cutting Tools or Holders after opening a library, it instantly locks up. I went up and down driver revisions for the Intel integrated graphics on my laptop and couldn't solve the issue that way.
The solution is to force the use of your dedicated graphics card for the Tool Manager application. This applies to desktops with integrated graphics as well- This is the process for NVIDIA cards:
1. Right click on the desktop and choose Nvidia Control Panel.
2. Go to Manage 3D Settings on the lefthand side.
3. Choose the Program Settings tab on the right.
4. Select Add under "Select a program to customize", and navigate to the location of your tool manager. By default for 2018, that is C:\Program Files\Mcam2018\Extensions\ToolManager.exe
5. Under "Select the preferred graphics processor for this program:", select High-Performance NVIDIA processor to force Tool Manager to open with the NVIDIA card and skip the Intel integrated graphics.
6. Hit apply in the bottom right corner. Repeat these steps for any other installed versions of Mastercam to ensure each tool manager version works with the dedicated card. You should now immediately be able to open up the tool manager and view libraries without crashes.
See the attached image for reference
  • Like 4
That's the ticket!!!  Works great!
Thank you
 hi thanks for tips ,
i am having same issue .
BTW, do you know how to change   3d graphic setting  in INTEL ? i dont have nvidia graphic card...
cheers
Hi Juyong,
If you only have Intel integrated graphics, you could try different driver versions and see if you find one that works. Mastercam is not supported on integrated graphics cards, however.
20 hours ago, Chally72 said:
Hi Juyong,
Looks like M/C 2020 will not even start if you have integrated graphics, it does a system check first. In older versions you could disable hardware acceleration to at least run the software but there is no settings for this any more.
Hi Radical1,
The option to turn off the Hardware acceleration is now located in the Mastercam Launcher (found in the installation folder in the Mastercam folder from the Windows Start menu). Here is a screenshot:
Hope this helps.
Patrik
