Welcome to eMastercam.com
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. This message will be removed once you have signed in.
Login to Account Create an Account
A286 steel?
  • Please log in to reply
18 replies to this topic
#1
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
Has anyone ever machined A286?
#2
Jeremy Herron@DBS Solutions™
    Advanced Member
  • eMC Learning Group
  • PipPipPip
  • 967 posts
Tons. What you want to know?
#3
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
How machinable is it? What would be a good comparison?
#4
strabe
strabe
    Advanced Member
  • Members
  • PipPipPip
  • 768 posts
Cutting granite with a butter knife is comparable.
#5
strabe
strabe
    Advanced Member
  • Members
  • PipPipPip
  • 768 posts
Actually it's worse than 304 but better than Hastelloy.
#6
strabe
strabe
    Advanced Member
  • Members
  • PipPipPip
  • 768 posts
Machinability is 33% using 1212 as a base of 100%
#7
    Advanced Member
  • PipPipPip
  • 967 posts
It is a superalloy with more iron than most. Here is a .pdf with material compostions.
#8
    Advanced Member
  • PipPipPip
  • 967 posts
If you normally turn your your superalloys with ceramics, plan on using carbide on A286, milling you can rough with ceramics anf finish with carbide. 125-175 sfm as a staring point with carbide.
#9
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
Thanks for the info. Anything else to keep in mind for machining this stuff?
#10
    Advanced Member
  • PipPipPip
  • 967 posts
Are you mill or turning?
#11
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
I haven't even seen the print yet the Salesman was just asking me if we could do it.
#12
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
I'm guessing it will be a milled part, most everything we do is horizontal work.
#13
    Advanced Member
  • PipPipPip
  • 967 posts
It work hardens pretty easy. If you are familiar with milling superalloys with ceramics and you have alot of material to remove I have had some sucess with it. If not stay away from them because it a bit of a leap from the norm. If you run ceramics I suggest NTK and dry, otherwise I usually jack my coolant concentration up to 10-15% if I have a lot to run. Threadmill or rollform threads. Carbide drills if you can afford them. Variable helix variable pitch endmills for solid carbide. Stay away from square shoulder inserted cutters, button cutters are your friend here.
#14
Zoober
Zoober
    Anigilohi
  • Members
  • PipPipPip
  • 5,864 posts
I've always treated it like inco 625. Thin walls will move (push) with moderate tool pressure.
I am dying to test some HSS paths on some high temp.
We are eating Ti up with them. And tool life in the hours.
Like Jeremy says, do not work harden it!
#15
Buddy J
Buddy J
    Member
  • Members
  • PipPip
  • 140 posts
Nasty Nasty stuff!
Have a job with lots of small deep radiused slots. (.12W x .6L x .900 Deep on a 1.5 radius..Belive me, in this stuff, .900 is DEEP!) Lets just say I changed lots of tools.....some every part.
If Carbide isn't an option, Cobalt drills, depending on the brand and a lot of luck, hold up rather well.
About 40 SFM :o
I had to roll tap 0-80's in this stuff, after heat treat..Thank God for Molly-dee!
Good luck
You have my sympathy!
#16
andate caga
andate caga
    Member
  • Members
  • PipPip
  • 34 posts
Treat it like Inconel 625. I make lots of R&D parts out of this. It work hardens and grows back, moves all over the place. I would personally like to cut inco 625 over this. Every batch is different also. I do turn and mill work. Use of low stepover max depth of cut is the way to mill. Turning I use kc5510 grade from kennametal. Drilling I use Gurhing with firex coating 70sfpm.
This might sound conservative to some but my parts are six figures easy and we don't get a setup part.
I would never recommend HSS/cobalt unless your drilling a small a286 fastener out.
Dynamic high speed tool paths work really well with superalloys. Don't be afraid to use tool inspection points. I usually put a 30 min check when hogging.
#17
Storkman
Storkman
    Gigantic Member
  • Members
  • PipPipPip
  • 6,757 posts
It really depends on what heat treat condition it is. It can go from Granite to Kryptonite.
#18
JParis
JParis
    Merchant of Death
  • Moderators
  • 26,093 posts
true dat!
#19
BenK
BenK
    Advanced Member
  • Members
  • PipPipPip
  • 1,953 posts
Thanks for the info. Sounds like this stuff will be a good challenge for me, I'm always up for something new.
