G Code Tapping Problem
Wally
The main man is out today and I`m lost. Could someone please help? We are running a Matsuura MC-500V. The operator has a Tapmatic head for an 8-32 helicoil tap. He`s asking me for what kind of "G" code to use. Thanks up-front for any help. banghead.gif
We run a g85 with the feed reduced by 5 % and as Phil said start .4 or .5 above the part. Also if it is a blind hole stay shallow on the first one and check the depth.Also because it is not a g84 you must make sure the spindle and feed rate overides are set to 100% because the spindle isnt synched in a g85 cycle.I learned that one the hard way.
HTH Noel
Some of our older machines do not have rigid tapping so we use G85 (feed in feed out)
Also with heads like this adjust R a little higher then normal (R.25)
Next thing I do is run rpm a little higher than calculated.
For example fo 2-56 S650 F10.8
G85G99X.1Y.3052Z-.14R.25F10.8
Hope it helps, Mark
