Using C axis rotary 5x mazak
CNCZACK
Ive been banging my head against the wall on this part. fairly simple mill off normally done in a 4x rotary on a mill. I decided to see how these would run on our 5x mazak. it is an older machine so some 5x toolpaths do not work correctly. when i tried using the same axis sub on this but it didnt seem correct at all . i tried 5x curve but the floor doesnt seem to clean up correctly with a finish 2x contour. not to mention my post doesnt have time continuous on the c axis.
there has to be a simpler or better way to go about doing this. any suggestions?
5X ROTARY 1.MCAM-CONTENT
If you go to Machine - Machine Definition, in the bottom right window expand spindle group - Pic 1 (probably left as that is normally the main spindle)
Right click on Lathe Spindle C Axis - Properties, bottom right there are options for continuous positioning - Pic2
Try adding a 4 Axis only Axis combination to the MMD and then change that operation to use that axis combination. Also need to set the operation up to only output in a 4 axis.
O2020 (53698GCA)
(PROGRAM   - 53698GCA.eia)
(DATE      - 2023.11.21)
(TIME      - 5:28 AM)
(MATERIAL  - STEEL INCH - 1030 - 200 BHN)
(**TOOL LIST**)
(T11  - 0.5 FLAT ENDMILL     - D11  - D0.5000")
G00 G17 G20 G40 G80 G90
G91 G28 Z0.
G28 X0.
M01
N1(MILL OFF 1)
(0.5 FLAT ENDMILL)
(OPERATION NO - 40)
(OPERATION TYPE - CURVE 5AX)
G10.9 X0
M200
T11 T11 M6
G91 G00 G28 Z0.
G17 G90 G00 G54
M212
C2.8075
M211
S2139 M3
G94
M08
G43.4 H11 X7.4963 Y.25 Z0.
X3.9962
G01 X3.4963 F15.
Z-.25 F21.39
Z-.35
Z-.4499
Z-.5498
X3.4983 Y.1251 Z-.63 C4.851
X3.4962 Y0. C7.7202
X3.4963 C9.3575
C10.9948
C12.6328
X3.4962 C14.2708
X3.4963 C15.9083
C17.5465
X3.4962 C19.1848
X3.4963 C20.8233
C22.4616
X3.4962 C24.0999
X3.4963 C25.738
C27.3762
X3.4962 C29.0147
C30.6521
C32.2903
C33.9282
X3.4963 C35.5662
X3.4962 C37.2039
X3.4963 C38.8412
C40.4796
C42.1171
X3.4962 C43.7545
X3.4963 C45.3926
C47.0304
X3.4962 C48.6689
X3.4963 C50.3072
X3.4962 C51.9443
C53.5822
X3.4963 C55.2202
X3.4962 C56.8573
X3.4963 C58.4947
X3.4962 C60.1327
X3.4963 C61.7704
X3.4962 C63.4081
X3.4963 C65.0461
C66.6836
C68.322
X3.4962 C69.9596
C71.5966
C73.2345
X3.4963 C74.8726
X3.4962 C76.5102
C78.1478
X3.4963 C79.7857
C81.4233
C83.061
C84.6982
X3.4962 C86.3363
X3.4963 C87.9737
X3.4962 C89.612
X3.4963 C91.2504
C92.8882
X3.4962 C94.5261
C96.1643
X3.4963 C97.8023
X3.4962 C99.4394
X3.4963 C101.0771
C102.7148
X3.4962 C104.3529
X3.4963 C105.9907
C107.6286
X3.4962 C109.2671
C110.9042
C112.5415
C114.1793
X3.4963 C115.8169
X3.4962 C117.4545
X3.4963 C119.0926
C120.7302
X3.4962 C122.3676
C124.0062
X3.4963 C125.6439
X3.4962 C127.281
X3.4963 C128.9187
X3.4962 C130.5561
X3.4963 C132.1931
C133.831
C135.4695
X3.4962 C137.1069
X3.4963 C138.7448
C140.3823
X3.4962 C142.0202
X3.4963 C143.6573
X3.4962 C145.2942
X3.4963 C146.9317
X3.4962 C148.5701
X3.4963 C150.2083
C151.8465
C153.4835
X3.4962 C155.1211
C156.7595
C158.3973
C160.0343
X3.4963 C161.6722
C163.3091
X3.4962 C164.9464
X3.4963 C166.5836
C168.2218
C169.8588
C171.4968
C173.1349
X3.4962 C174.7723
C176.4104
C178.048
X3.4963 C179.6851
C181.3235
X3.4962 C182.9617
C184.5989
X3.4963 C186.2363
X3.4962 C187.8741
X3.4963 C189.5125
C191.1495
C192.7869
C194.4242
C196.0622
X3.4962 C197.6992
C199.3362
C200.9746
C202.6128
X3.4963 C204.2507
X3.4962 C205.8884
X3.4963 C207.5259
C209.1636
X3.4962 C210.8017
X3.4963 C212.4389
X3.4962 C214.0773
X3.4963 C215.7157
X3.4962 C217.3529
X3.4963 C218.9913
X3.4962 C220.6299
X3.4963 C222.2674
X3.4962 C223.9047
C225.5427
X3.4963 C227.1803
C228.8185
X3.4962 C230.4564
C232.0949
C233.7333
X3.4963 C235.3706
X3.4962 C237.0079
C238.6455
C240.2836
C241.9214
C243.5591
X3.4963 C245.197
X3.4962 C246.8354
C248.4736
C250.112
C251.7497
C253.3872
X3.4963 C255.0248
X3.4962 C256.663
C258.301
C259.9393
C261.5773
C263.2153
X3.4963 C264.8527
C266.491
X3.4962 C268.1285
X3.4963 C269.7668
C271.4052
C273.043
C274.6806
C276.3187
C277.9564
C279.5943
C281.2316
C282.87
C284.5075
X3.4962 C286.1459
C287.7842
X3.4963 C289.422
C291.0605
C292.698
X3.4962 C294.336
C295.9737
C297.6113
X3.4963 C299.2493
C300.8868
C302.525
X3.4962 C304.1622
C305.7996
X3.4963 C307.4373
X3.4962 C309.0755
C310.7132
C312.3516
X3.4963 C313.9886
C315.6263
X3.4962 C317.2636
C318.9015
X3.4963 C320.5388
C322.1764
X3.4962 C323.8149
C325.4531
C327.0917
C328.7293
C330.3666
C332.0038
C333.6414
C335.2794
X3.4963 C336.9166
C338.5544
C340.1915
C341.8291
X3.4962 C343.4672
X3.4963 C345.1054
C346.7433
X3.4962 C348.3806
C350.0179
X3.4963 C351.656
X3.4959 Y-.1247 C354.4242
X3.4917 Y-.2496 C357.1925
X3.4963 Y-.25 Z-.5802
Z-.4802
Z-.3803
Z-.2804
Z-.25
Z0.
G00 X3.9962
X7.4963
M09
M5
G49
G91 G28 Z0.
G28 X0. Y0.
M01
Scratch the above just making it a only 4 Axis operation worked also.
O2020 (53698GCA)
(DATE      - 2023.11.21)
(TIME      - 5:28 AM)
(**TOOL LIST**)
G91 G28 Z0.
G28 X0.
M01
N1(MILL OFF 1)
(0.5 FLAT ENDMILL)
(OPERATION NO - 40)
G10.9 X0
M200
T11 T11 M6
G91 G00 G28 Z0.
G17 G90 G00 G54
M212
C2.8075
M211
S2139 M3
G94
M08
X3.9962
G01 X3.4963 F15.
Z-.25 F21.39
Z-.35
Z-.4499
Z-.5498
X3.4962 Y0. C7.7202
X3.4963 C9.3575
C10.9948
C12.6328
X3.4962 C14.2708
X3.4963 C15.9083
C17.5465
X3.4962 C19.1848
X3.4963 C20.8233
C22.4616
X3.4962 C24.0999
X3.4963 C25.738
C27.3762
X3.4962 C29.0147
C30.6521
C32.2903
C33.9282
X3.4963 C35.5662
X3.4962 C37.2039
X3.4963 C38.8412
C40.4796
C42.1171
X3.4962 C43.7545
X3.4963 C45.3926
C47.0304
X3.4962 C48.6689
X3.4963 C50.3072
X3.4962 C51.9443
C53.5822
X3.4963 C55.2202
X3.4962 C56.8573
X3.4963 C58.4947
X3.4962 C60.1327
X3.4963 C61.7704
X3.4962 C63.4081
X3.4963 C65.0461
C66.6836
C68.322
X3.4962 C69.9596
C71.5966
C73.2345
X3.4963 C74.8726
X3.4962 C76.5102
C78.1478
X3.4963 C79.7857
C81.4233
C83.061
C84.6982
X3.4962 C86.3363
X3.4963 C87.9737
X3.4962 C89.612
X3.4963 C91.2504
C92.8882
X3.4962 C94.5261
C96.1643
X3.4963 C97.8023
X3.4962 C99.4394
X3.4963 C101.0771
C102.7148
X3.4962 C104.3529
X3.4963 C105.9907
C107.6286
X3.4962 C109.2671
C110.9042
C112.5415
C114.1793
X3.4963 C115.8169
X3.4962 C117.4545
X3.4963 C119.0926
C120.7302
X3.4962 C122.3676
C124.0062
X3.4963 C125.6439
X3.4962 C127.281
X3.4963 C128.9187
X3.4962 C130.5561
X3.4963 C132.1931
C133.831
C135.4695
X3.4962 C137.1069
X3.4963 C138.7448
C140.3823
X3.4962 C142.0202
X3.4963 C143.6573
X3.4962 C145.2942
X3.4963 C146.9317
X3.4962 C148.5701
X3.4963 C150.2083
C151.8465
C153.4835
X3.4962 C155.1211
C156.7595
C158.3973
C160.0343
X3.4963 C161.6722
C163.3091
X3.4962 C164.9464
X3.4963 C166.5836
C168.2218
C169.8588
C171.4968
C173.1349
X3.4962 C174.7723
C176.4104
C178.048
X3.4963 C179.6851
C181.3235
X3.4962 C182.9617
C184.5989
X3.4963 C186.2363
X3.4962 C187.8741
X3.4963 C189.5125
C191.1495
C192.7869
C194.4242
C196.0622
X3.4962 C197.6992
C199.3362
C200.9746
C202.6128
X3.4963 C204.2507
X3.4962 C205.8884
X3.4963 C207.5259
C209.1636
X3.4962 C210.8017
X3.4963 C212.4389
X3.4962 C214.0773
X3.4963 C215.7157
X3.4962 C217.3529
X3.4963 C218.9913
X3.4962 C220.6299
X3.4963 C222.2674
X3.4962 C223.9047
C225.5427
X3.4963 C227.1803
C228.8185
X3.4962 C230.4564
C232.0949
C233.7333
X3.4963 C235.3706
X3.4962 C237.0079
C238.6455
C240.2836
C241.9214
C243.5591
X3.4963 C245.197
X3.4962 C246.8354
C248.4736
C250.112
C251.7497
C253.3872
X3.4963 C255.0248
X3.4962 C256.663
C258.301
C259.9393
C261.5773
C263.2153
X3.4963 C264.8527
C266.491
X3.4962 C268.1285
X3.4963 C269.7668
C271.4052
C273.043
C274.6806
C276.3187
C277.9564
C279.5943
C281.2316
C282.87
C284.5075
X3.4962 C286.1459
C287.7842
X3.4963 C289.422
C291.0605
C292.698
X3.4962 C294.336
C295.9737
C297.6113
X3.4963 C299.2493
C300.8868
C302.525
X3.4962 C304.1622
C305.7996
X3.4963 C307.4373
X3.4962 C309.0755
C310.7132
C312.3516
X3.4963 C313.9886
C315.6263
X3.4962 C317.2636
C318.9015
X3.4963 C320.5388
C322.1764
X3.4962 C323.8149
C325.4531
C327.0917
C328.7293
C330.3666
C332.0038
C333.6414
C335.2794
X3.4963 C336.9166
C338.5544
C340.1915
C341.8291
X3.4962 C343.4672
X3.4963 C345.1054
C346.7433
X3.4962 C348.3806
C350.0179
X3.4963 C351.656
Z-.4802
Z-.3803
Z-.2804
Z-.25
Z0.
G00 X3.9962
X7.4963
M09
M5
G49
G91 G28 Z0.
G28 X0. Y0.
M01
im not sure i know how to add it to the MMD is this under the control definition?
O2020 (53698GCA)
(DATE      - 2023.11.21)
(TIME      - 5:28 AM)
(**TOOL LIST**)
G91 G28 Z0.
G28 X0.
M01
N1(MILL OFF 1)
(0.5 FLAT ENDMILL)
(OPERATION NO - 40)
G10.9 X0
M200
T11 T11 M6
G91 G00 G28 Z0.
G17 G90 G00 G54
M212
C2.8075
M211
S2139 M3
G94
M08
X3.9962
G01 X3.4963 F15.
Z-.25 F21.39
Z-.35
Z-.4499
Z-.5498
X3.4962 Y0. C7.7202
X3.4963 C9.3575
C10.9948
C12.6328
X3.4962 C14.2708
X3.4963 C15.9083
C17.5465
X3.4962 C19.1848
X3.4963 C20.8233
C22.4616
X3.4962 C24.0999
X3.4963 C25.738
C27.3762
X3.4962 C29.0147
C30.6521
C32.2903
C33.9282
X3.4963 C35.5662
X3.4962 C37.2039
X3.4963 C38.8412
C40.4796
C42.1171
X3.4962 C43.7545
X3.4963 C45.3926
C47.0304
X3.4962 C48.6689
X3.4963 C50.3072
X3.4962 C51.9443
C53.5822
X3.4963 C55.2202
X3.4962 C56.8573
X3.4963 C58.4947
X3.4962 C60.1327
X3.4963 C61.7704
X3.4962 C63.4081
X3.4963 C65.0461
C66.6836
C68.322
X3.4962 C69.9596
C71.5966
C73.2345
X3.4963 C74.8726
X3.4962 C76.5102
C78.1478
X3.4963 C79.7857
C81.4233
C83.061
C84.6982
X3.4962 C86.3363
X3.4963 C87.9737
X3.4962 C89.612
X3.4963 C91.2504
C92.8882
X3.4962 C94.5261
C96.1643
X3.4963 C97.8023
X3.4962 C99.4394
X3.4963 C101.0771
C102.7148
X3.4962 C104.3529
X3.4963 C105.9907
C107.6286
X3.4962 C109.2671
C110.9042
C112.5415
C114.1793
X3.4963 C115.8169
X3.4962 C117.4545
X3.4963 C119.0926
C120.7302
X3.4962 C122.3676
C124.0062
X3.4963 C125.6439
X3.4962 C127.281
X3.4963 C128.9187
X3.4962 C130.5561
X3.4963 C132.1931
C133.831
C135.4695
X3.4962 C137.1069
X3.4963 C138.7448
C140.3823
X3.4962 C142.0202
X3.4963 C143.6573
X3.4962 C145.2942
X3.4963 C146.9317
X3.4962 C148.5701
X3.4963 C150.2083
C151.8465
C153.4835
X3.4962 C155.1211
C156.7595
C158.3973
C160.0343
X3.4963 C161.6722
C163.3091
X3.4962 C164.9464
X3.4963 C166.5836
C168.2218
C169.8588
C171.4968
C173.1349
X3.4962 C174.7723
C176.4104
C178.048
X3.4963 C179.6851
C181.3235
X3.4962 C182.9617
C184.5989
X3.4963 C186.2363
X3.4962 C187.8741
X3.4963 C189.5125
C191.1495
C192.7869
C194.4242
C196.0622
X3.4962 C197.6992
C199.3362
C200.9746
C202.6128
X3.4963 C204.2507
X3.4962 C205.8884
X3.4963 C207.5259
C209.1636
X3.4962 C210.8017
X3.4963 C212.4389
X3.4962 C214.0773
X3.4963 C215.7157
X3.4962 C217.3529
X3.4963 C218.9913
X3.4962 C220.6299
X3.4963 C222.2674
X3.4962 C223.9047
C225.5427
X3.4963 C227.1803
C228.8185
X3.4962 C230.4564
C232.0949
C233.7333
X3.4963 C235.3706
X3.4962 C237.0079
C238.6455
C240.2836
C241.9214
C243.5591
X3.4963 C245.197
X3.4962 C246.8354
C248.4736
C250.112
C251.7497
C253.3872
X3.4963 C255.0248
X3.4962 C256.663
C258.301
C259.9393
C261.5773
C263.2153
X3.4963 C264.8527
C266.491
X3.4962 C268.1285
X3.4963 C269.7668
C271.4052
C273.043
C274.6806
C276.3187
C277.9564
C279.5943
C281.2316
C282.87
C284.5075
X3.4962 C286.1459
C287.7842
X3.4963 C289.422
C291.0605
C292.698
X3.4962 C294.336
C295.9737
C297.6113
X3.4963 C299.2493
C300.8868
C302.525
X3.4962 C304.1622
C305.7996
X3.4963 C307.4373
X3.4962 C309.0755
C310.7132
C312.3516
X3.4963 C313.9886
C315.6263
X3.4962 C317.2636
C318.9015
X3.4963 C320.5388
C322.1764
X3.4962 C323.8149
C325.4531
C327.0917
C328.7293
C330.3666
C332.0038
C333.6414
C335.2794
X3.4963 C336.9166
C338.5544
C340.1915
C341.8291
X3.4962 C343.4672
X3.4963 C345.1054
C346.7433
X3.4962 C348.3806
C350.0179
X3.4963 C351.656
Z-.4802
Z-.3803
Z-.2804
Z-.25
Z0.
G00 X3.9962
X7.4963
M09
M5
G49
G91 G28 Z0.
G28 X0. Y0.
M01
this is the piece thats left behind
No one ever showed me how to do all of this. You learn by trying and seeing what you can figure out. However just changing the operation to be only 4 Axis worked so the MMD change is not needed. Think about why that CUSP is left? What did you do with the toolpath to make it leave the CUSP?
Not enough room to allow the tool to fit into the corner?
