Drill depth - A2100
dourk
On my A2100 controls, they automatically account for the drill tip angle in the drill depth (if I program a 1" hole, .500 deep, it will actually go ~.800 deep).
Is there some way to compensate for this in MC lathe? Here's why...
Programming a bore that is .625 deep. I need the full dia of the drill .650 deep. If I add drill tip comp in MC, everything looks good, but then I drill to deep on the machine. If I program it knowing the machine will go farther, then when I run the bore in the drilled hole, the backplot shows the bore digging into undrilled material.
Usually I'll turn on drill tip comp while programming, then turn it off before I post. But, that's a pain.
Sure, I can turn it off. But I like it there. Too many jobs are in production to change it. And when I'm programming a quickie at the machine, I don't have to do any figuring out to get my drill to the right depth before I tap it.
Give Noel a cigar!!!
There is s parameter in the control for Auto Tip angle compensation.
[$CYCLE_PARAMS(2)HOLE_DEPTH]=2
The value should be 2 which is no comp I believe.
But, I WANT the comp in the machine. It's handy to have.
And I don't want to edit the > 300 programs that already use it.
I want mastercam to operate the way I do, not the other way.
I'm thinking maybe put something in the post so that I can have drill comp on, then the post reverts to the depth without the comp.
That's fine, you can turn tip comp off in Mastercam and set the machine parameter to comp for the angle in the tool page at the control. Personally i HATE it because I want control of the toolpath in Mastercam NOT at some piece of garbage control that freaks out when the weather gets too hot, or when the power surges, or when a brownout occurs. My Mori's don;t even skip a beat unless the power goes OUT, but that's another story.
Go into Mastercam's COnfig, go to the NC Settings Tab, go to the Operations Defaults, click save and an Operation's manager pops up with all the toolpaths in it. Go to the drilling cycle and turn off the tip comp or however you want to change it. Exit, save and continue working..
Harryman - that's about the simplest idea. Perfect. Thanks.
James -I have no problem with the A2100 control, other than the fact that it's soooo damn slow. Forever to boot. Forever to swap screens, etc. It has a ~lot~ of nice features that oughta be in other (fanuc/yasnac) controls in this day and age.
What I hate it the absolute junk iron it's bolted to. Cinci arrows/sabres are the flimsiest, weakest, unreliable machines I've ever used.
Well nobody ever accused fanuc controls of being feature laden... Why is it you were using drill tip comp in the control, written by hand? Is this something you could turn on and off via Gcode with a macro? If so turn it off at the start of your new programs generated with mastercam and turn it on in old programs. I kind of agree with James, I want the machine to do exactly what the gcode tells it, not it's interpretations which can change with the barrometric pressure and the position of the moon. I know a few guys that have attended a support group for the A2100 and I'll ask them.
HTH and good luck
...Is this something you could turn on and off via Gcode with a macro?
Yes. [$CYCLE_PARAMS(2)HOLE_DEPTH]=2 will allow you this control. Not sure if the control will accept it without a reboot. You know how those temermental PC's are.
...support group for the A2100...
Do they gather round in a circle and comiserate(sp?) on what a poor machine tool purchase decision they made???
James teh thank you sir may I have another, thank you sir may I have another...
brettj,
if you know how to tackle it in the post, you could try creating logic that would reverse calculate drill tip comp and subtract it from the actual drill depth. That way your 1" drill - .500 deep would actually be programed as Z-.300 so the control comp will send it 1/2" deep.
steve
Here's the drilling parameters you can use.
OPS: PRM_DRILL
10100 Drill cycle
10108 First peck increment
10109 Subsequent peck increment
10110 Peck clearance
10111 Retraction distance for chip break
10112 Dwell
10118 Pre-defined bore shift
10117 Add this amount to total depth
10115 Adjust depth per drill tip (True/False)
12018 Drill point sorting method used
15071 Custom drill cycle parameters
15072 Custom drill cycle parameters
15073 Custom drill cycle parameters
15074 Custom drill cycle parameters
15075 Custom drill cycle parameters
15076 Custom drill cycle parameters
15077 Custom drill cycle parameters
15078 Custom drill cycle parameters
15079 Custom drill cycle parameters
15080 Custom drill cycle parameters
15081 Use custom parameters is checked (True/False)
12019 Drill5ax output format axis type selected: 0=3 axis, 1=4 axis, 2=5 axis
12020 Use points and lines or points
12021 Tool axis option
12022 Tip position control
12023 Project type (to plane or surface)
12024 5-axis tool display length
12025 Drill5ax output format 4-axis type axis selected (0 = X, 1 = Y, 2 = Z)
12254 Plane vector for drill5ax plane option 12255 Plane vector for drill5ax plane option 12256 Plane vector for drill5ax plane option 15212 Output 1018 NCI (sub program) line in drill cycle (True/False)
15213 Subprogram output mode: true = incremental, false = absolute
Taken from Mastercam Version 9.1 MP Post Processor Reference Guide 7-111 Volume 3 Chapter 7
It is available through your reseller. I would STRONGLY reccommend getting it if you plan on doing ANY post processor customization.
