Tool Speed and Feed Problem
archer
Hey People,
Got a question. We are running 9.1 MR0304 and have been using a post that will post to a Fadal VMC. The problem that we are running into is having two operations of the same type using the same tool (e.g. 2 contours, etc..) and trying to get one operation to run at one Feed and Speed, while the other one(usually a clean up) to run either slower, or faster. We are changing the program, but when it gets posted, the program ignores the different speeds that were in the mc9 file. What can I look for in the post to see where this is being overlooked? Any help will help.
Dennis
The job setup is set as you describe. The problem is not that the tool parameter page is not set, its when we post the program. The tool stays the same speed throughout the entire operations. The first time the tool is used, say with a contour, we set the speed like 8500 and feed at 120 ipm. Then we go w/ another contour at full depth right after, we then set the speed slower and feed slower. The program doesn't reflect this change, it just runs it at the 8500 and 120.
