Overlapping entities
Brendan P
I did do a search and with no luck didn't get my answer.
I am running a 2D lathe part that was converted from autocad lt.
When I run my toolpath,I keep getting the "there are overlapping entities in the chained geometry"
But If I analize chain,there is nothing there!
I even tried the findovlp.dll chook,and it finds no overlapping entities!!
WTF
has anyone had this happen before?
V9.1 maint.
this is serious sh!t
I have had this happen a few times. usually when I am chaining solid or surface curves. somtimes there seems to be two entities when theres not. I have to redraw the chain to make it work. does anyalize chain start and stop nearest your chain point? if it jumps to a different end point somfins wacked
Thanks guys.
Steve,I just tried the dxf thing,but the same result.
I am a little bit busy today,and I just had to work around it for now.
I would like to email you the file,just to see if you can find anything.
I will have to send it in a little bit when I free up.
if they are splines that are giving you trouble, try reducing the amount of control points in them by Analyze>Edit=Y
then set your desired tolorence (I usually use somewhere between .0005 & .001). This usually clears up any trouble Im having with splines...seems MC starts getting funky when the ammount of control points in a spline gets up there...
