PORT TOOLS
HEAVY METAL
I always give the porting tool a G04 dwell for a couple of revs just to be sure The sealing surface is smooth and flat. A G82 would work as well I suppose but porting tools are sort of differant critters. I usually have them touch off from the large spotface dia. How do you superstars handle this? smile.gif
Matt
1) The ports they are talking about are typically for fluid connections (hydraulic, fuel, cooling fluids, oil, etc) and often have 'standard' configurations. If you look in your MSC book under 'port tools' or 'porting tools' you should probably see what they're talking about.
2) Are you any relation to Mike Berube, esteemed salesman for The Robert E. MOrris Company?
C
I wasn't aware of a written procedure, but have always used the porting tool to size the minor diameter before tapping (hole drilled slightly undersize). I would think that would give optimal concentricity between the thread pitch diameter and the diameters formed by the porting tool.
Depending on the hydraulic port, AN, SAE, ISO, MS, NASA, Rosan etc they all have published but obscure standards. Most aircraft manufacturers have their own often detailed specifications and procedures.
If a spec is called out the porting tool manufacturer will usually fax you a copy.
If you are doing a lot of them or cutting some uncoperative material like nastalloy or inconel a form drill really helps. Reducing operation count and the load on your slow, expensive, and if brazed carbide, fragile porting tool at the bottom.
In aluminum 3 steps form drill, port, then tap
Steel and exotics, stub drill undersize, semi finish, finish the port, then tap. Use of a sulpher/chlorine extreme pressure lube and high end spiral flute tap for the last two operations insures success.
Most of the way down the hole you can get a pretty good feed rate where the tool is at most reaming. But at the bottom a really slow feed when the tool is acting as a counterbore and dwell (as was suggested) can be critical to achieve the required surface finish for sealing at the bottom.
After all the job I save might be my own
