Toolpath insert arrow making me crazy!
In V9 if you made a toopath at least you new where it went ,to the bottom of the active tool group.Now if the red arrow is not where you want the toolpath to be placed it's frustrating in Lathe beacause you have to regen everything after where its inserted.
I'm The Arrow Guy, so you can yell at me.
In V9, the operation was always appended to the end of the list (which is probably what you want 80% of the time). In X, we have these machine groups which controls a lot more than what's just visible on the screen, and the arrow's postion determines which is the "active machine" at the time. Its position also determines where the next operation will be inserted.
When posting, the arrow jumps between machine groups because the post needs to access the machine info to do its thing. The arrow is supposed to return to the original position it started after posting though.
The red arrow is a good idea and I find it very useful. It does jump around too much and can cause some serious trouble if you're not paying attention. Like place a finishing OP ahead of the roughing OP rolleyes.gif
I was going to suggest making it draggable, but I just tried that and it already is draggable.
Making it always default to the end of the active
Toolpath Group would fix all the complaints I have with it.
You mean just when doing a "file / get", load the file and position the arrow at the end of the group? It kinda does that now, except it's all the way at the bottom.
I fixed it so the window doesn't scroll to the arrow when regenerating an operation, and it only moves between machine groups now when posting (it used to move into each group regardless of machine).
Once you get used to it,or more the point remeber its there.Its handy for creating new toolpaths in the group where you want it.Rather than creating a toolpath cutting it and then pasting it where you want it.
Its also handy for jobs that have both Lathe and milling machines in the one mc file.
  • 4 weeks later...
when you edit an operation then regenerate it the screen jumps to the insert arrow no matter where it is.
I hope this is one of the issues that gets fixed. If the insert arrow is at the bottom and you have enough ops that they run off the bottom of the screen, every time you regenerate a toolpath, it jumps down to the bottom where the arrow is. Scrolling back up every time is a real pain.
I also don't like the way the arrow breaks up the "visual flow" of operations. It's like there's a divider there where it doesn't belong.
Thad
  • 3 months later...
With the arrow positioned at the bottom of all operations in tha machine group, if you go and copy and operation somewhere up in the list, the insert arrow will no longer be at the end but positioned 1 up, since you've added another operation.
I agree that if would could activate an option that would allow the insert arrow to ALWAYS remain at the end of ALL operations, this would help retain a bit opf the V9 way of doing things.
