can anybody write a CNC program for lathe please.?
bala_51083
  • Replies 144
  • Created
  • Last Reply
Top Posters In This Topic
When you click on the button for plunge parameters you will have additional options. depending on the set-up of the holder, your CNMG432 insert only has 5 degrees of clearance to turn the back side of the arc. I see in one of your screenshots that you have a DNMG tool selected though. If the tool is set-up like the screenshot, you will then have plenty of room to get at the entire arc, provided your chuck jaws aren't in the way.
On that Plunge Paramerters page, if you are using a VNMG tool click the 3rd option in the top row.
Then you will need to enter a clearance angle in the right window of the 2nd row. Consult your tooling manufacturer catalogue for your toolholder's clearance. VNMG is probably around 45 degrees.
Parameters for the VNMG331 tool you are picking;
depth of cut .04 or .05 depending on feed rate
Stock to leave x.01 z.002 for front of radius
stock to leave x.01 z-.002 for back section of radius.
I would program these with two different toolpaths.
uncheck equal steps. it will make the cut depths from the finish diameter and the first cut will be light. Having the last cut come out as light/shallow is preferable for accuracy.
I use 47 degrees for back clearance on the vnmg tool and it works well without giving alarms or over commiting the tool to stuff it can't do.
does the program i got thru mastercam make the part.plzz let me know guys.
O1001
G20
(PROGRAM NAME - ARCDATE=DD-MM-YY - 29-09-06 TIME=HH:MM - 20:51)
(TOOL - 1 OFFSET - 1)
(LROUGH OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431)
G0T0101
G97S734M13
G0G54X9.3621Z7.9301
G50S3600
G96S1800
G99G1Z2.0384F.02
X9.5621
Z2.0284
X9.5821
X9.7235Z2.0991
G0Z7.9301
X9.1621
G1Z2.0384
X9.3821
X9.5235Z2.1091
G0Z7.9301
X8.9621
G1Z2.0384
X9.1821
X9.3235Z2.1091
G0Z7.9301
X8.7621
G1Z2.0384
X8.9821
X9.1235Z2.1091
G0Z7.9301
X8.5621
G1Z2.0384
X8.7821
X8.9235Z2.1091
G0Z7.9301
X8.3621
G1Z2.0384
X8.5821
X8.7235Z2.1091
G0Z7.9301
X8.1621
G1Z2.0384
X8.3821
X8.5235Z2.1091
G0Z7.9301
X7.9621
G1Z2.0384
X8.1821
X8.3235Z2.1091
G0Z7.9301
X7.7621
G1Z3.9493
G3X7.894Z3.2294R3.9626
G1Z2.0384
X7.9821
X8.1235Z2.1091
G0Z7.9301
X7.5621
G1Z4.3641
G3X7.7821Z3.8929R3.9626
G1X7.9235Z3.9636
G0Z7.9301
X7.3621
G1Z4.6566
G3X7.5821Z4.3301R3.9626
G1X7.7235Z4.4008
G0Z7.9301
X7.1621
G1Z4.8926
G3X7.3821Z4.6304R3.9626
G1X7.5235Z4.7011
G0Z7.9301
X6.9621
G1Z5.0937
G3X7.1821Z4.8708R3.9626
G1X7.3235Z4.9415
G0Z7.9301
X6.7621
G1Z5.2702
G3X6.9821Z5.0748R3.9626
G1X7.1235Z5.1455
G0Z7.9301
X6.5621
G1Z5.4281
G3X6.7821Z5.2535R3.9626
G1X6.9235Z5.3242
G0Z7.9301
X6.3621
G1Z5.5711
G3X6.5821Z5.413R3.9626
G1X6.7235Z5.4837
G0Z7.9301
X6.1621
G1Z5.7018
G3X6.3821Z5.5574R3.9626
G1X6.5235Z5.6281
G0Z7.9301
X5.9621
G1Z5.8221
G3X6.1821Z5.6892R3.9626
G1X6.3235Z5.76
G0Z7.9301
X5.7621
G1Z5.9334
G3X5.9821Z5.8105R3.9626
G1X6.1235Z5.8812
G0Z7.9301
X5.5621
G1Z6.0367
G3X5.7821Z5.9226R3.9626
G1X5.9235Z5.9933
G0Z7.9301
X5.3621
G1Z6.1329
G3X5.5821Z6.0267R3.9626
G1X5.7235Z6.0974
G0Z7.9301
X5.1621
G1Z6.2226
G3X5.3821Z6.1236R3.9626
G1X5.5235Z6.1943
G0Z7.9301
X4.9621
G1Z6.3066
G3X5.1821Z6.2139R3.9626
G1X5.3235Z6.2847
G0Z7.9301
X4.7621
G1Z6.3851
G3X4.9821Z6.2984R3.9626
G1X5.1235Z6.3691
G0Z7.9301
X4.5621
G1Z6.4586
G3X4.7821Z6.3774R3.9626
G1X4.9235Z6.4482
G0Z7.9301
X4.3621
G1Z6.5274
G3X4.5821Z6.4514R3.9626
G1X4.7235Z6.5221
G0Z7.9301
X4.1621
G1Z6.5919
G3X4.3821Z6.5207R3.9626
G1X4.5235Z6.5914
G0Z7.9301
X3.9621
G1Z6.6522
G3X4.1821Z6.5856R3.9626
G1X4.3235Z6.6563
G0Z7.9301
X3.7621
G1Z6.7086
G3X3.9821Z6.6463R3.9626
G1X4.1235Z6.7171
G0Z7.9301
X3.5621
G1Z6.7613
G3X3.7821Z6.7031R3.9626
G1X3.9235Z6.7738
G0Z7.9301
X3.3621
G1Z6.8104
G3X3.5821Z6.7562R3.9626
G1X3.7235Z6.8269
G0Z7.9301
X3.1621
G1Z6.8561
G3X3.3821Z6.8056R3.9626
G1X3.5235Z6.8763
G0Z7.9301
X2.9621
G1Z6.8985
G3X3.1821Z6.8517R3.9626
G1X3.3235Z6.9224
G0Z7.9301
X2.7621
G1Z6.9377
G3X2.9821Z6.8944R3.9626
G1X3.1235Z6.9651
G0Z7.9301
X2.5621
G1Z6.9738
G3X2.7821Z6.9339R3.9626
G1X2.9235Z7.0046
G0Z7.9301
X2.3621
G1Z7.007
G3X2.5821Z6.9704R3.9626
G1X2.7235Z7.0411
G0Z7.9301
X2.1621
G1Z7.0372
G3X2.3821Z7.0038R3.9626
G1X2.5235Z7.0745
G0Z7.9301
X1.9621
G1Z7.0646
G3X2.1821Z7.0343R3.9626
G1X2.3235Z7.105
G0Z7.9301
X1.7621
G1Z7.0892
G3X1.9821Z7.062R3.9626
G1X2.1235Z7.1327
G0Z7.9301
X1.5621
G1Z7.1111
G3X1.7821Z7.0869R3.9626
G1X1.9235Z7.1576
G0Z7.9301
X1.3621
G1Z7.1303
G3X1.5821Z7.109R3.9626
G1X1.7235Z7.1797
G0Z7.9301
X1.1621
G1Z7.1468
G3X1.3821Z7.1285R3.9626
G1X1.5235Z7.1992
G0Z7.9301
X.9621
G1Z7.1608
G3X1.1821Z7.1453R3.9626
G1X1.3235Z7.216
G0Z7.9301
X.7621
G1Z7.1721
G3X.9821Z7.1595R3.9626
G1X1.1235Z7.2302
G0Z7.9301
X.5621
G1Z7.1809
G3X.7821Z7.1711R3.9626
G1X.9235Z7.2418
G0Z7.9301
X.3621
G1Z7.1871
G3X.5821Z7.1801R3.9626
G1X.7235Z7.2508
G0Z7.9301
X.1621
G1Z7.1908
G3X.3821Z7.1866R3.9626
G1X.5235Z7.2573
G0Z7.9301
X-.0315
G1X-.0313Z7.192
G3X.1821Z7.1906R3.9626
G1X.3235Z7.2613
G0X7.944
Z3.2294
X7.894
G3X7.7484Z2.4733R3.9626F.01
G1X7.694Z2.3334
Z2.0384F.02
X7.914
X8.0554Z2.1091
G0Z2.3848
X7.714
G1X7.5793Z2.0384F.01
X7.714F.02
X7.8554Z2.1091
G0X9.6121
G28U0.W0.M05
T0100
I'm coming in here late bala but have you asked your reseller for help or training?
You have got good advice here on how and why and now even to check the G-code.
Seems your getting the whole job done through the forum.
I noticed the time on your screen shots 2.07 AM eek.gif Get some sleep dude cheers.gifcheers.gif
I agree. If you could post a example that has run on the beast, then we would know what exactly you need for format.
Also, when picking how to cut, you can choose "canned rough" and then "canned finish" to get the type of G-code output like has already been posted. The generic MPLFAN post processor you are using might just need a few tweaks to get it to post useable code. Having to read a mile of straight G-code is really inconvenient when you could write it in 1 page to do the same thing.
Lathe canned cycles are the most powerful metal removal tools.........
