Post help - Need to use variable for D# in comp.
Bruce Caulley
After reading all the info in this post, I got my mpmaster to spit out D#3026 and h#3026 just fine. Last night I was posting a 5axis curve toolpath with comp off and this is what I get.
Anyone know what might be causing it?
Thanks, Damian
(.03 CORNER RAD)
(WCS NAME - TOP)
(TOOLPLANE NAME - OP3 HORIZ)
(CPLANE NAME - OP3 HORIZ)
(TOOLPATH GROUP - TOOLPATH GROUP-1)
(COMPENSATION TYPE - WEAR COMP)
T4 M06 ( .031"C/R, 1/8" SHK 2F CARBIDE CORNER-ROUNDING TOOL .036"LOC,. 75" PROJ.)
G90G10L12P#3026R0
M11 (UNLOCK)
G00 G17 G90 G54 A3.641 X0. Y-1.161 S8100 M03
G43 H#3026 Z3.0312 T5
D#3026 Z1.1312
G94 G01 D#3026 Z1.0312 F6.
G93 D#3026 A1.975 F200.05
D#3026 A.308 F200.06
D#3026 A-1.36 F199.77
D#3026 A-3.028 F199.87
D#3026 A-4.696 F199.97
D#3026 A-6.362 F200.11
D#3026 Z1.0311 A-8.03 F199.84
D#3026 A-9.699 F199.69
D#3026 A-11.366 F200.01
D#3026 Z1.0312 A-13.032 F200.13
D#3026 A-14.699 F200.08
D#3026 A-16.365 F200.09
D#3026 A-18.029 F200.29
D#3026 A-19.697 F199.96
if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
This logic seems wrong, I can't put my finger on it, but something seems off here. I think where you do the cc_pos$ you have it doing nothing really it would have to equal something or be greater than or something the statement will always be what it is thus the output will always be true with no way to be false.
sorry about that. here is the rest of the code.
i tried # on the line mentioned and it still output wrong. I also failed to mention that if i post this toolpath only the code is good when i post the whole prog i get the D on every line of one tool only.
pccdia #Cutter Compensation
#if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
sccomp
if prv_tloffno$ > 1,
if prv_tloffno$ <> tloffno$, "D", no_spc$, 35, no_spc$, "3026"
if cc_pos$, !tloffno$
Hey Tim,
We program with resident tool's 1-83. the rest are open for special tools. the d#3026
and h#3026 just helps the operator from making
any mistake by editing the wrong info. all h and t #'s come from the actual tool in the spindal. we also use it in a g10 call before and
after each tool to adjust the comp for specific
parts instead of for all job that might be running. ( G90G10L12P#3026R0 )
i did find one thing out, if i imput the tool info like this it will work.
t1
h3026
d3026
t2
h3026
d3026
ect
prev was
t1
h1
d1
t2
h2
d2
and i never had a problem. seems weird for it to act up all of a sudden.
thanks again for your help, Damian
FINISH CORNERS AND .03 RAD IN POCKETS)
(WCS NAME - TOP)
T3 M06 (DEFINE TOOL NAMES)
G90G10L12P#3026R0
M11 (UNLOCK)
G00 G17 G90 G54 A0. X1.0513 Y-1.2763 S9000 M03
M10 (LOCK)
G43 H#3026 Z2. T4
D#3026 Z1.13
G94 G01 D#3026 Z.9257 F6.
G41 D#3026 Y-1.2563 F9.
G03 X1.0313 Y-1.2363 I-.02 J0.
G02 X.9013 Y-1.1063 I0. J.13
G01 Y-1.0938
X.9008
X.4388
X.4387 Y-1.0942
Y-1.1063
G02 X.3088 Y-1.2363 I-.13 J0.
G03 X.2888 Y-1.2563 I0. J-.02
G01 G40 Y-1.2763
X1.0513
Z.8214 F6.
G01 Y-3.3388
X.4338
Y-3.8112
X.9063
Y-3.575
G03 X.8862 Y-3.555 I-.02 J0.
G01 G40 X.8662
Y-3.595
Z.1695 F6.
G41 D#3026 X.8862 F9.
G03 X.9063 Y-3.575 I0. J.02
G01 Y-3.3388
X.4338
Y-3.8112
X.9063
Y-3.575
G01 G40 X.8662
Z.2695 F24.
G00 Z2.
ROUGH GROOVES)
M11 (UNLOCK)
G00 G90 A3.641 X0. Y-1.325
G43 H#3026 Z2.9368
M11 (UNLOCK)
Z1.0368
G01 Z.9368
G93 A1.593 F1000.
Z.9367 A-.453 F1000.
A-2.501 F1000.
Z.9366 A-4.549 F1000.
Z.9365 A-6.599 F1000.
A-8.646 F1000.
Z.9364 A-10.697 F1000.
A-12.749 F1000.
A-14.798 F1000.
A-16.846 F1000.
A-18.898 F1000.
A-20.949 F1000.
Z.9365 A-22.999 F1000.
A-25.048 F1000.
Z.9366 A-27.097 F1000.
Z.9367 A-29.145 F1000.
A-31.193 F1000.
Z.9368 A-33.239 F1000.
A-35.289 F1000.
A-37.336 F1000.
Z.9367 A-39.386 F1000.
A-41.437 F1000.
Z.9366 A-43.486 F1000.
Z.9365 A-45.537 F1000.
A-47.586 F1000.
Z.9364 A-49.633 F1000.
A-51.681 F1000.
A-53.731 F1000.
A-55.778 F1000.
A-57.827 F1000.
A-59.873 F1000.
Z.9365 A-61.923 F1000.
A-63.973 F1000.
Z.9366 A-66.02 F1000.
Z.9367 A-68.068 F1000.
Z.9368 A-70.116 F1000.
A-72.168 F1000.
A-74.218 F1000.
A-76.27 F1000.
Z.9367 A-78.321 F1000.
A-80.372 F1000.
Z.9366 A-82.418 F1000.
Z.9365 A-84.469 F1000.
A-86.52 F1000.
Z.9364 A-88.57 F1000.
A-90.617 F1000.
A-92.67 F1000.
A-94.718 F1000.
A-96.764 F1000.
A-98.811 F1000.
Z.9365 A-100.859 F1000.
EDIT
M01
(.03 CORNER RAD)
(WCS NAME - TOP)
G90G10L12P#3026R0
M11 (UNLOCK)
D#3026 Z1.1312
EDIT
D#3026 A-12.082 F200.11
D#3026 Z1.0311 A-10.413 F199.84
D#3026 A-8.744 F199.69
D#3026 A-7.077 F200.01
D#3026 Z1.0312 A-5.411 F200.13
D#3026 A-3.745 F200.08
D#3026 A-2.078 F200.09
D#3026 A-.414 F200.29
D#3026 A1.253 F199.96
D#3026 A3.641 F139.61
G00 D#3026 Z1.1312
D#3026 Z3.0312
G91 G28 Z0.
(.03 RAD)
M11 (UNLOCK)
G00 G90 A3.641 X.3237 Y-1.211
M10 (LOCK)
G43 H#3026 Z2.
M10 (LOCK)
D#3026
D#3026 Z1.1625
G94 G01 D#3026 Z1.0313 F6.
G41 D#3026 Y-1.191
G03 X.2938 Y-1.161 I-.03 J0.
G01 X.2437
X0.
X-.05
G03 X-.08 Y-1.191 I0. J-.03
G01 G40 Y-1.211
Z1.1313
G00 Z1.25
Y-1.439
Z1.1625
G01 Z1.0313
G41 D#3026 Y-1.459
G03 X-.05 Y-1.489 I.03 J0.
G01 X0.
X.2437
X.2937
EDIT
Z1.1625
G01 Z1.0312
G41 D#3026 Y-3.709
G03 X-.901 Y-3.739 Z1.0313 I.03 J0.
G01 X-.801 Z1.0312
X0.
X.1
G03 X.13 Y-3.709 Z1.0313 I0. J.03
G01 G40 Y-3.689 Z1.0312
Z1.1312
G00 Z2.
M05
G91 G28 Z0.
G90G10L12P#3026R0
M01
You gotta do it in two parts;
Do this in pheader AFTER everything;
    strtlmd = strtlmd + no2asc(35)
result = nwadrs(strtlmd,tloffno$)
Then this in pccdia;
#Force Dxx#
sccomp
tloffno$ = 518
if cc_pos$, tloffno$
That should do it.
So close James, but you didn't mention declaration of strtlmd string needs to be a D.
Declaration:
strtlmd "D"
Concatenate D + # and reassign addr to tloffno$:
(at end of pheader)
Assign parameter # to tloffno$:
#Force Dxx#
sccomp
tloffno$ = 3026
In the string/variable declaration section, before any postblocks.
# Misc strings
snull "" # Null character string
sdot "." # dot string
stest1 "" # Test string 1
stilde "~" # Tidle string
snocomm "DEFINE TOOL NAMES"
stoper "" # String for tool notes
spostname "" # Post name
snullop "UNDEFINED OPERATION"
slicense "IN-HOUSE SOLUTIONS"
scomment_holder ""
srev ""
strtlmd "D" #<--------------------------------------------
Then in pheader postblock.
pheader$         #Call before start of file
if met_tool$ = one, #Metric constants and variable adjustments
ltol$ = ltol_m
vtol$ = vtol_m
mtol$ = mtol_m
maxfeedpm = maxfeedpm_m
result = nwadrs(srotary, cabs)
result = nwadrs(srotary, cinc)
result = nwadrs(srotary, indx_out)
pgetprogname
"%", e$
spaces$=0
sprog_ext = progno$
sav_progno2 = progno$
*progno$, " (", sprogname$, sprog_ext, "..MP", ")", e$
"(REV ", *srev, ")", e$
#*progno, " (", sprogname, "..MP", ")", e
spathnc$ = ucase(spathnc$)
smcname$ = ucase(smcname$)
#"(PROGRAM NAME - ", sprogname, ")", e
#"(DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, ")", e
#"(MASTERCAM - V", *vers_no, ")", e
#"(MC9 FILE - ", smcpath, smcname, smcext, ")", e
#"(POST - ", spostname, ")", e
#"(MP - V", *dll_vers, ")", e
stck_matl$ = ucase(stck_matl$)
#"(MATERIAL - ", stck_matl, ")", e
#"(PROGRAM - ", sprogname, sextnc, ")", e
#"(DATE - ", *smonth, "-", *day, "-", *year, ")", e
"(", *smonth, "-", day$ , "-", year$ , ")", e$
#"(TIME - ", *time, ")", e
#"(POST DEV - ", *slicense, ")", e
spaces$=sav_spc
if seqno$ = 0, omitseq$ = yes$
sav_rot_on_x = rot_on_x
rot_on_x = 0
sav_progno = progno$
#seqno = 10
#seqinc = 10
#n = seqno
strtlmd = strtlmd + no2asc(35) #<-----------------------------------
Finally, in pccdia postblock.
#Force Dxx#
sccomp
tloffno$ = 3026 #<-------------------------------------
Yup. I agree 100%. James is under the impression that a # character can't be used in fmt statements.
you can't use the "#" in a post. You have to use the ACSII equivalent. (i.e. 035 ). MC sees that as a comment and ignores everything after it.
I'm just making his method work. LOL Interesting, albeit unnecessary.
i added Guru's info and it had an error.
im sure im just doing somthing wrong.
so i started over and just used Guru's
pccdia block and everything post ok, just missing the # on every d call. i tried adding the line of code for paul and it erored out
again. i think im pretty close if i can get
pauls fmt to work.
i am always impressed at the amount of knowlage on this board and the many different ways to do things.
fmt "D#" 4 tloffno$ #Diameter offset number
Damian - All that really needed to be done here is this:
1)modify the fmt for tloffno$
2)Assign a value to tloffno$
Don't add in the fmt line it's already there.
Your error is probably a duplicate fmt line.
# Toolchange / NC output Variable Formats
fmt T 4 t$ #Tool No
fmt T 4 first_tool$ #First Tool Used
fmt T 4 next_tool$ #Next Tool Used
#fmt D 4 tloffno$ #Diameter Offset No #<----Original fmt
fmt "D#" 4 tloffno$ #Diameter Offset No#<--Modified
fmt H 4 tlngno$ #Length Offset No
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
#Force Dxx#
sccomp
tloffno$ = 3026#<------
  • 14 years later...
Bringing this old thread back to life.  My old handle was @dforsythe and i no longer have that email to retrieve it.  so I'm now @riverhunter some 15 years later and am now back on mastercam so I'm trying to duplicate something i did back in 2009.  looks like @Rob @ Target Machinehasnt been around lately so ill ask the rest of the group.
the code below works great for getting the code D#517.  my question is how do i do this for  tlngno$ so i can get G43 H#517.  the tlngno$ is buirred in the ptlchg_com so im not sure how to approch it.
#pbld, n$, "G43", *tlngno$, pfzout, scoolant, e$
pbld, n$, "G43", "H#517", pfzout, scoolant, e$  This forced it, but throws an exception error.
On 12/4/2009 at 4:11 AM, Rob @ Target Machine said:
#Force Dxx#
sccomp
