Post help - Need to use variable for D# in comp.
Bruce Caulley
Ahoy!,
One last post tweak before I am off to UG land.
On our makinos I would like to use a # variable for the D number when using compensation. The reasons for this are many and varied wink.gif
This is what I need:
 G41 D#101 Y-48.8 F3400.
From the post:
 pccdia          #Cutter Compensation
#Force Dxx#
if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
sccomp
if cc_pos$, tloffno$
Any help appreciated.
Bruce
Bruce something like
format this
comp_off : 0
#Force Dxx#
comp_off = tloffno$ +100
sccomp
if cc_pos$, "D", no_spc$, 35, no_spc$, comp_off, e$
That should comp number in the 100 series variable always related to the tool # + 100, You'll have to test it.
John,
I am actually trying to hardcode a #101, but your method got me going in the right direction. I now have the following:
Post:
#Force Dxx#
sccomp
#if cc_pos$, tloffno$
if cc_pos$, "D", no_spc$, 35, no_spc$, "101", comp_off, e$
Code:
 M11 B67. M10
M98 P
G0 G90 X-127.992 Y-40.
G43 H#100 Z129.69
G1 Z128.69 F2000.
G41 D#101
Y-48.8 F3400.
G3 D#101
X-119.192 Y-40. R8.8
G1 D#101
Y40.
G3 D#101
X-127.992 Y48.8 R8.8
G1 G40 Y40.
Z129.69 F10000.
M319
G91 G28 Z0.
G90
M01
M99
How can I get rid of the extra #101's?
Bruce
Bruce,
Add it here
scc1 G41 D#101 #Cutter compensation left
scc2 G42 D#101 #Cutter compensation right
Add Change this
pccdia
#Force Dxx#
sccomp
And since you are heading of to UG land I thought I would give you a very small preview
set cam_post_dir [MOM_ask_env_var UGII_CAM_POST_DIR]
if { ![info exists mom_sys_post_initialized] } {
source ${cam_post_dir}ugpost_base.tcl
proc MOM_before_each_add_var {} {}
proc MOM_before_each_event {} {}
# set cam_debug_dir [MOM_ask_env_var UGII_CAM_DEBUG_DIR]
# source ${cam_debug_dir}mom_review.tcl
MOM_set_debug_mode OFF
#### Listing File variables
set mom_sys_list_output "OFF"
set mom_sys_header_output "OFF"
set mom_sys_list_file_rows "40"
set mom_sys_list_file_columns "30"
set mom_sys_warning_output "ON"
set mom_sys_group_output "OFF"
set mom_sys_list_file_suffix "lpt"
set mom_sys_output_file_suffix "nc"
set mom_sys_commentary_output "ON"
set mom_sys_commentary_list "x y z 4axis 5axis feed speed"
set mom_sys_control_out "("
set mom_sys_control_in ")"
set mom_sys_post_initialized 1
Original code ->
#Force Dxx#
sccomp
Your code ->
#Force Dxx#
sccomp
Your issue of repeating output is due to the fact that the conditional logic has been “broken”. The ‘if cc_pos$’ worked before because ‘tloffno$’ variable is formatted for modal output. So even though ‘if cc_pos$’ is repeatedly TRUE, ‘tloffno$’ is output only when its value has changed. In your new code, after the ‘if cc_pos$’ is “literal” output, so you’ll get it output againhttp://www.emastercam.com/ubb/ultimatebb.php
eMastercam.com Forums and again…
Try this…
Change ->
To ->
if prv_tloffno$ <> tloffno$, "D", no_spc$, 35, no_spc$, "101", comp_off, e$
can you edit the toolchange macro to do this? I have done this on a Matsuura MAM72-63V with a 30i controller. in the program itself there are no "H" or "D" codes...just a G43 and D41's.
at the end of the macro these lines were added
H#518
D#517
This sets both the H and the D for whatever tool is in the spindle.
this was done for tool life management and using backup tools.
That's Matsuura's TLM. It only works for Matsuura.
But using variables for H & D is really the way to go because it makes absolutely sure you'll not get errant offsets and you can do other things on the control side with that information as well.
JM2C
Thanks fellas. I have changed the post to this:
#Force Dxx#
sccomp
#if cc_pos$, "D", no_spc$, 35, no_spc$, "101", comp_off, e$
if prv_tloffno$ <> tloffno$, "D", no_spc$, 35, no_spc$, "101" #, comp_off, e$
And now get this:
 G0 G90 X-127.992 Y-40.                  ptlchg0$ p__5:869 620.
G43 H#100 Z129.69 ptlchg0$ p__5:869 620.
D#101 ptlchg0$ prapidout 620.
G1 D#101 Z128.69 F2000. plin$ plinout 622.
G41 D#101 Y-48.8 F3400. plin$ plinout 624.
G3 D#101 X-119.192 Y-40. R8.8 pcir$ pcirout 626.
G1 D#101 Y40. plin$ plinout 628.
G3 D#101 X-127.992 Y48.8 R8.8 pcir$ pcirout 630.
G1 G40 D#101 Y40. plin$ plinout 632.
D#101 Z129.69 F10000. plin$ plinout 636.
M319 peof$ peof$ 638.
G91 G28 Z0. peof$ peof$ 638.
G90 peof$ peof$ 638.
M01 peof$ peof$ 638.
M99 peof$
Bruce
  • 1 year later...
Ahoy!,
I need to resurrect this as I am tweaking a post for my new machine.
I have changed the post as I thought I had done the previous Makino, but I am getting an extra D in the output. I know it is simple and is staring me in the face, but it is amazing how much stuff you forget when you haven't been using it for a while!!!!!
 Z10.
G1 Z0. F1.5
G41 D#501 D215 Y25.933 <================ Don't need D215!!!!!
G3 X-6.711 Y19.933 R6.
G1 X21.771
G2 X24.771 Y16.933 R3.
G1 Y-8.974
G2 X21.771 Y-11.974 R3.
G1 X-35.192
G2 X-38.192 Y-8.974 R3.
G1 Y16.933
G2 X-35.192 Y19.933 R3.
G1 X-6.711
G3 X-.711 Y25.933 R6.
G1 G40 Y31.933
Z10.
G0 Z50.
M9
M5
sccomp
if prv_tloffno$ <> tloffno$, "D", no_spc$, 35, no_spc$, "501"
thanks
Bruce
if prv_tloffno$ <> tloffno$, "D", no_spc$, 35, no_spc$, "501", "PROBLEM"
Add this word problem and repost and see if that is the line that causing you the problem. I still think the tloffno$ on the second line needs to come out completely, but do this and lets see what happens.
That is the line that is outputting. I have put a ! in front of the second tloffno$ to stop it from outputting when using wear or control. If I remove the line completely I get D# on every line regardless.
I am thinking I may need to add some logic to the motion output sections ? headscratch.gif
I'll z2g a dummy file and send it your way Ron.
thanks
Bruce
Bruce here you go sir:
sccomp
if prv_tloffno$ > 1,
if cc_pos$, !tloffno$
I tried it on all 3 methods and it posted like it should.
